Thumping Noise From Front Suspension
Mcwhit02
Mcwhit02 is offline
PostPosted: Wed Aug 13, 2025 12:43 pm    Post subject: Thumping Noise From Front Suspension Reply with quote
1972 Super Beetle. I get a thumping noise from what I am thinking is the front suspension on rough roads and bumps. What is the best way to diagnose/repair the issue?
Cusser
Cusser is offline
PostPosted: Wed Aug 13, 2025 2:08 pm    Post subject: Re: Thumping Noise From Front Suspension Reply with quote
Get front end up on lift or jack stands, and pry with long bar to look for loose part. Or let an experienced mechanic do that.
Mcwhit02
Mcwhit02 is offline
PostPosted: Wed Aug 13, 2025 2:44 pm    Post subject: Re: Thumping Noise From Front Suspension Reply with quote
Thank you
redhot
redhot is offline
PostPosted: Thu Aug 14, 2025 11:45 am    Post subject: Re: Thumping Noise From Front Suspension Reply with quote
If you are indeed sure of front suspension there are some easy checks/inspections that informs a lot. Such as strut bearing, wheel bearing, just knowing if balljoints and/or rubber bushings are very old or farily new etc.
Basically, looking at the diagram you will see a lot of possible culprits - while remember to include steering in addition to suspension...
Mcwhit02
Mcwhit02 is offline
PostPosted: Fri Aug 15, 2025 7:31 am    Post subject: Re: Thumping Noise From Front Suspension Reply with quote
Thank you. Where did you get the diagrams?
vamram Premium Member
vamram is offline
PostPosted: Fri Aug 15, 2025 12:14 pm    Post subject: Re: Thumping Noise From Front Suspension Reply with quote
I had a thump once when I was missing this bell-shaped metal bushing at that top of the strut. With it missing on a stock strut as in the manual pages above, you'll have like 1/2" of play that will thump. It's #5 in this page borrowed from the samba gallery:
Click to view image
Save the Supers!!
Mcwhit02
Mcwhit02 is offline
PostPosted: Fri Aug 15, 2025 2:15 pm    Post subject: Re: Thumping Noise From Front Suspension Reply with quote
Thank you
redhot
redhot is offline
PostPosted: Fri Aug 15, 2025 4:07 pm    Post subject: Re: Thumping Noise From Front Suspension Reply with quote
Mcwhit02 wrote:
Thank you
The diagrams comes from the different documents available via the TheSamba technical archives. If you hover above the images with the points, you should be able to see the address/link and navigate according. I think these were the "what is new" for the 1971 year list/postings.
Here is the common link; https://www.thesamba.com/vw/archives/manuals/71vwprogram.php
And also; thanks for just saying thanks to any one of the repliers trying to help - not always people extend such curtoesy in general, so worth itself to comend Very Happy
Mcwhit02
Mcwhit02 is offline
PostPosted: Mon Aug 18, 2025 10:58 am    Post subject: Re: Thumping Noise From Front Suspension Reply with quote
Thank you for the help
mrinnovation1
mrinnovation1 is offline
PostPosted: Mon Aug 18, 2025 11:08 am    Post subject: Re: Thumping Noise From Front Suspension Reply with quote
Tire belt separation will give you a thumping noise. Often it is not visible until the tire is taken off of the rim and you can see the inside. It happened to me some years back and was not always audible or felt thru the steering wheel. I could feel it on a right-hand turn. The tire was the left front.
Mcwhit02
Mcwhit02 is offline
PostPosted: Mon Aug 18, 2025 1:32 pm    Post subject: Re: Thumping Noise From Front Suspension Reply with quote
I'll check that out. Thanks
