Big Flywheel Samba Member
Posted: Thu Aug 14, 2025 11:04 am Post subject: question about 25hp fuel pump install |
Hi all
I've rebuilt my 25hp fuel pump and understand that the pump should be installed with engine positioned at TDC ie fuel pump rod in fully extended position. Why TDC? ... is this to ensure the correct positioning of the rod on the cam as opposed to mounting the pump at BDC?
Thank you
CJ |
my3bugs Samba Member
Joined: June 18, 2003 Posts: 950 Location: Moreno Valley
Posted: Thu Aug 14, 2025 3:18 pm Post subject: Re: question about 25hp fuel pump install |
i think that is way for home re-builders to ensure the diaphragm is in the right preload place before you lighten the screws ....thats for folks without the proper preload tools .... at least thats how ya do the later pumps .
at TDC the rod is at its proper height for tightening the screws
there is an article here explaining some of that .
https://shamwerks.com/rebuilding-36hp-fuel-pump
dmooresc Samba Member
Joined: August 14, 2004 Posts: 35 Location: upstate SC
Posted: Thu Aug 14, 2025 6:52 pm Post subject: Re: question about 25hp fuel pump install |
hello CJ,
the factory workshop manual makes no mention of engine being at TDC when installing the pump. it does note the engine to be at "working temperature" when tightening the two mounting nuts
the factory tool 328b presses the rocker arm to the point the link pulls the diaphragm down to a flat position prior to tightening the cover. without this, the spring would have the diaphragm in a permanent, stretched convex situation.
best wishes,
Darryl |
Posted: Fri Aug 15, 2025 5:18 am Post subject: Re: question about 25hp fuel pump install |
Thank you both - I previously made a tool and preloaded the pump before screwing the two pieces together.
Thanks for clarification on the instructions given in the manual Darryl. I heard some people mention previously that it was important to install the pump with the engine at TDC but perhaps - as you both say - they were referring to preloading the pump on the engine.
All the best
CJ |
