esde Samba Member
Joined: October 20, 2007 Posts: 6373 Location: central rust belt
Posted: Sat Aug 02, 2025 6:52 am Post subject: Re: Field find 1954 Canadian custom |
| Ovally wrote: |
Which brand of coil did you buy from Amazon?
And which brand did you buy from CIP?
Regards. |
For what it's worth, I have gotten bad coils from both vendors and several others. I imagine many companies buy and resell stuff from the same factories and wholesale suppliers, and much of the lower end stuff has quality control issues. Leaking and exploding coils, dead or intermittent spark.. they fail in every way imaginable.
I was just reading this and thought, well if all that didn't fix the issue it has to be something else..
And thats exactly what someone else suggested and you discovered. Nice to have so many minds helping to problem solve with you. _________________ modok wrote:
kintail Samba Member
Posted: Sat Aug 02, 2025 11:52 am Post subject: Re: Field find 1954 Canadian custom |
Reminds me of the time I put an NOS Steering lock in my 1967 Westfalia. Ran well for a bit after this was put in but then randomly the engine would cut out. Let it sit for a bit and then it would start again. Didn't know what the problem was.
Finally reviewed the last thing I did which was the steering lock and found that one low cost connector was the problem. Replaced with a new "brass" connector and problem solved.
Use this as my new approach to problem issues. Only took a couple of decades (or more) to figure this out. _________________ Scott
August 1954 Beetle Canadian Deluxe |
sunroof Samba Member
Joined: October 06, 2006 Posts: 2053 Location: Winnipeg
Ovally Samba Member
Posted: Sun Aug 03, 2025 2:09 am Post subject: Re: Field find 1954 Canadian custom |
CIP, you would expect good quality from Beru, but today's Beru isn't what it used to be.
The occasional flickering of the oil pressure light when the engine is warm and at low speed is normal, but it should go away when accelerating.
The original VW oil pressure switch (through 1960) closes at a pressure of 0.3-0.6 kg/cm². The green light then comes on.
The original oil pressure switch has an adjustment screw.
The adjustment is for grounding to occur causing the warning light to go on.
If the light stays on too long, it can be fixed by turning the adjustment screw counterclockwise.
BUT... before changing this setting, you should check the oil pressure, preferably with a mechanical oil pressure gauge.
Something like this, for example.
I don't know if the CIP oil pressure switch has this adjustment screw. You could check it.
Regards, Armand _________________ VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S MFI 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018 |
Redlabel6 Samba Member
Joined: October 17, 2016 Posts: 394 Location: Minnesota
lardawge Samba Member
Joined: October 05, 2020 Posts: 420 Location: California
Posted: Sun Aug 03, 2025 6:45 am Post subject: Re: Field find 1954 Canadian custom |
| Ovally wrote: |
I have never seen any genuine oil switch with an adjustment screw. The screw holds the wire. I have NOS ones on two engines at the moment.
@sunroof, it looks like cip1 has several different quality switches. This is one I have used successfully: https://www2.cip1.com/VWC-111-919-081 _________________ 11/2/54 L227 Strato Silver Ragtop - Build Thread
1/7/55 L275 Light Beige - Build Thread
9/1/56 (57 model) L331 Horizon Blue - For Sale |
Ovally Samba Member
Posted: Sun Aug 03, 2025 11:37 am Post subject: Re: Field find 1954 Canadian custom |
| lardawge wrote: |
I have never seen any genuine oil switch with an adjustment screw. The screw holds the wire. |
VW used various suppliers for oil pressure switches, such as Bosch, Messmer Radolfzell, ...
Have you checked under the screw?
When you remove the screw, there is another screw at the bottom in the cavity.
This is from a Dutch repair manual VW 54-59, with the cooperation of the VW factory.
I translated it into English in my previous post.
Oliedrukschakelaar = oil pressure switch
Afstelling = adjustment
See also this thread.
https://www.thesamba.com/vw/forum/viewtopic.php?t=395886
Regards. _________________ VW Bug Oval 1953
VW Bug 1200 D motor
Posted: Mon Aug 04, 2025 9:00 pm Post subject: Re: Field find 1954 Canadian custom |
So I pulled the oil pressure switch out to see if it has a calibration screw which of course it doesn't. I reinstalled it and it actually works the way it is supposed to except for dumping oil out now.
Friends have offered me a few to try.
Don _________________ Better and better mistakes! |
Posted: Tue Aug 05, 2025 6:05 pm Post subject: Re: Field find 1954 Canadian custom |
John G to the rescue
It has the adjustment screw and is dated 1 58.
I hope this works.
When I was in Hessisch Oldendorf in 2013 there was a fellow with a whole case of switches. I bought one and then sold it a few years later. If I could go back and whisper in my ear I would say buy the whole box.
Ovally Samba Member
Posted: Tue Aug 05, 2025 11:43 pm Post subject: Re: Field find 1954 Canadian custom |
Perfect!
Let's hope it still works.
Look, I'm not talking nonsense.
My Oval, bought new by my parents, still has such switch (0,3-0,6 kg/cm²) with an adjustment screw.
The adjustment screw does not affect the correct operation of the oil pressure switch.
You only set the oil pressure light to go out at low pressure.
This often happened when the customer complained that the light was too long on at idle.
(Before changing this setting, you must ensure that the engine oil pressure is correct.
Normal oil pressure when the engine is warm and idling min. 0,5 kg/cm².
At 70°C/158°F oil temperature and 2500 rpm min. 2,0 kg/cm²).
VW Bug 1200 D motor
Posted: Wed Aug 06, 2025 8:09 am Post subject: Re: Field find 1954 Canadian custom |
| Ovally wrote: |
Perfect!
Regards, Armand |
Good info. I don't think any of us would have figured that out without translation. I don't have the light flickering issue because both engines have been rebuilt and are using the later/larger oil pumps. If I ever run across that, it's nice info to have. Cheers! _________________ 11/2/54 L227 Strato Silver Ragtop - Build Thread
Posted: Fri Aug 08, 2025 6:18 am Post subject: Re: Field find 1954 Canadian custom |
This gives me a little thrill:
It works as it should and it doesn't leak. When I put the original engine together the switch that came with it did not work, would not shut the light off. I installed the one from my spare engine and it worked for a year or so and then started leaking oil. I then bought a new one from CIP. Almost immediately it failed and wouldn't turn the light off at idle. Investigating it I found the terminal was loose, it started working properly but started leaking a lot. Now I have one dated 1 58 that, cross your fingers, works and doesn't leak.
Another bit of good news: I bought an NOS vacuum advance from Frederik
https://www.thesamba.com/vw/classifieds/detail.php?id=2333581
Installed it yesterday, really dresses up the engine bay
Ever since I built this car it has had a little flat spot off idle, that seems to be gone. A win I think.
On another note. I plan to go on a bit of a drive starting Sunday and I wanted 12 volts in the car to charge electronics while I drove. I had built an inverter years ago and turned my electronics shop upside down looking for it. Nowhere to be found, then I remembered....
It was still in the car, I had disconnected it but left it in place.
Connected it up and...
Sweet, this will work.
Posted: Tue Aug 12, 2025 8:13 pm Post subject: Re: Field find 1954 Canadian custom |
Today I went over Roger's pass on my way to Vancouver
For the Great Canadian VW show this weekend.
Posted: Wed Aug 13, 2025 6:20 am Post subject: Re: Field find 1954 Canadian custom |
Looking at home in the mountains!! Have fun at the show and a great trip!! _________________ Scott
Posted: Fri Aug 15, 2025 3:03 pm Post subject: Re: Field find 1954 Canadian custom |
Drove the 99 from Kamloops to Whistler. Most fun I ever had in a beetle. A very swoopy road.
Dan22 Samba Member
Joined: August 30, 2019 Posts: 686 Location: Battle Ground, WA
Posted: Fri Aug 15, 2025 4:40 pm Post subject: Re: Field find 1954 Canadian custom |
Don, are you driving all the way from Winnipeg to Vancouver? That is a nice long haul.
And, what was the cause of your lifters getting stuck in your (other) motor? Maybe I missed that finding. _________________ 1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074 |
oldzwit Samba Member
Posted: Sun Aug 17, 2025 6:38 pm Post subject: Re: Field find 1954 Canadian custom |
| Pleased to meet you here in Vancouver at our Great Canadian VW show Don, glad the car was co-operative! |
Posted: Sun Aug 17, 2025 8:24 pm Post subject: Re: Field find 1954 Canadian custom |
| Quote: |
I haven't finished dismantling the engine but I got the lifters out and they were perfect. I actually did not see anything wrong with the motor. Big puzzle.
OTOH
Picked up some hardware today:
Sweet
my56samba Samba Member
Joined: July 01, 2017 Posts: 114 Location: victoria b.c.
Posted: Mon Aug 18, 2025 8:06 am Post subject: Re: Field find 1954 Canadian custom |
Great work on the car Don. I was at the Great Canadian show yesterday with my 54 ragtop and it was awesome that you drove your 54 half way across Canada to be here. It was cool to see your car in person and nice for you to bring home an award. I went back to your car a couple times hoping to find you but that didn’t work out. It was a really good turnout with lots of amazing VW’s to check out. Safe travels on your journey home.
Mark _________________ Dec 54 Ragtop Beetle
April 56 Baja Bug
June 56 23 Window Samba |
Posted: Mon Aug 18, 2025 8:09 am Post subject: Re: Field find 1954 Canadian custom |
Ah sorry I missed you. Darn
