electric fuel pump wiring
Bielakt13
Bielakt13 is offline
PostPosted: Wed Aug 27, 2025 9:52 am    Post subject: electric fuel pump wiring Reply with quote
I am installing an electric fuel pump into my 62 bug. I do not have a tachometer but want to be able to get the pump to shut off automatically should I roll or get in an accident. Is there an easy way to do this? Thanks!
daveblank
daveblank is offline
PostPosted: Wed Aug 27, 2025 10:09 am    Post subject: Re: electric fuel pump wiring Reply with quote
Get one of these. The tach signal comes from the negative side of the coil.
https://www.jbugs.com/product/RE12003.html?utm_con...gKMzPD_BwE
Bielakt13
PostPosted: Wed Aug 27, 2025 10:16 am    Post subject: Re: electric fuel pump wiring Reply with quote
Perfect, so i just need to run the green wire to the negative side of the coil?
67rustavenger
67rustavenger is offline
PostPosted: Wed Aug 27, 2025 10:21 am    Post subject: Re: electric fuel pump wiring Reply with quote
Correct.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Bielakt13
PostPosted: Wed Aug 27, 2025 10:38 am    Post subject: Re: electric fuel pump wiring Reply with quote
Thank you for the help!
