r.e.wing_fc3s Samba Member
Joined: April 16, 2010 Posts: 603 Location: Vanagon Capitol USA: Bellingham, WA
Posted: Wed Aug 13, 2025 12:40 am Post subject: What Vanagons came with reinforced main longitudinal frame rail? |
Some vanagon frame rails -the main longitudinal member running the length of the middle of the van with oval shaped holes - had additional metal inside the frame - easy to see from the bottom when looking up at the oval holes. I feel like this was a somewhat random addition. I thought orignally that this was only used on westies from the late 80's on. Then i saw an 89 tintop syncro with the reinforcement but not a 91 syncro tintop - maybe they just ran out?
My syncros frame has become flexy after much time on three and two wheels. It is now sometimes very difficult to engage low gear or reverse only when the van body is diagonally tweaked while offroading. Otherwise it shifts perfectly. Wondering if anyone else has experinced this or if those with the reinforced frame rails notice less flex. _________________ Reference Automotive: NW Washingtons Vanagon Specialist. (360)366-6965. referenceautomotive.com |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17406 Location: Brookeville, MD
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10505 Location: Orbiting San Diego
Posted: Wed Aug 13, 2025 9:58 am Post subject: Re: What Vanagons came with reinforced main longitudinal frame rail? |
He is talking about the 2 main hollow frame rails that run front to back under the van.
They have elongated oval holes in them that you can look and feel inside of.
On late model Syncros you can easily see an inner metal rib inside the 2 frame rails but earlier vans don't have them.
Don't know exactly when they were added.
Mark |
Posted: Wed Aug 13, 2025 3:05 pm Post subject: Re: What Vanagons came with reinforced main longitudinal frame rail? |
Yep. seems like some 2wd westys had them also. I have a 1989 syncro 16 joker highroof in the shop now and would certinaly think that vehicle would have them but it doesnt. _________________ Reference Automotive: NW Washingtons Vanagon Specialist. (360)366-6965. referenceautomotive.com |
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4643 Location: East Kootenay, British Columbia
Posted: Wed Aug 13, 2025 3:14 pm Post subject: Re: What Vanagons came with reinforced main longitudinal frame rail? |
I thought all Syncros had the reinforcement? My '89 16" Syncro certainly had them.
Is this Syncro original or a 2wd conversion?
As for the shifting it sounds more like it needs adjustment or maintenance.
Also, out curiosity, does the body show any tell-tale signs of body flex by the rear wheel wells?
https://www.thesamba.com/vw/forum/viewtopic.php?t=526392&highlight=syncro+body _________________ Currently:
Resist Kleptocratic Oligarchy (and Idiocracy)! |
Posted: Wed Aug 13, 2025 3:30 pm Post subject: Re: What Vanagons came with reinforced main longitudinal frame rail? |
I've had a lot of early Syncros, none had it.
Had a 90 Syncro, that did have it.
I'd love a get a close look at the VIN# of any 2wd Vanagon that has it.
I wonder if it would have a G in the 11th digit?
Mark |
WiboBusMan Samba Member
Joined: September 26, 2009 Posts: 172 Location: Canada
Posted: Fri Aug 15, 2025 6:12 pm Post subject: Re: What Vanagons came with reinforced main longitudinal frame rail? |
Pics here:
https://hanswibo.asuscomm.com/s/LxCBR3HFZyNGcLb
Top pic show that you see the floor panel through the oval hole.
Looking through the oval hole on the lower pic shows that the rail is capped on top of the rail.
W _________________ Science has sacrificed Truth on the altar of its narrative. |
tdivan82 Samba Member
Posted: Fri Aug 15, 2025 7:05 pm Post subject: Re: What Vanagons came with reinforced main longitudinal frame rail? |
| r.e.wing_fc3s wrote: |
| My syncros frame has become flexy after much time on three and two wheels. |
I don't have knowledge of the specific frame reinforcements in question, but I do know that metal fatigue on vehicles is a thing, especially those that see extreme use cases e.g. racing or off-roading. Take a paperclip and start bending it back and forth in your fingers. After a handful of times, the metal simply cracks and breaks. Vehicles are no different. It is interesting to see the side-by-side photos of the "reinforced" vs. "non-reinforced" frame rails. _________________ 82 Westy TDI (ahu) = 70 mph uphill + 28 mpg
See my Classified ads for some super deals on Diesel Vanagon parts!
Posted: Wed Aug 20, 2025 6:15 pm Post subject: Re: What Vanagons came with reinforced main longitudinal frame rail? |
@wibobusman yaa thats good info. ill try and find pics of the 2wd with the capped rails and or a vin number _________________ Reference Automotive: NW Washingtons Vanagon Specialist. (360)366-6965. referenceautomotive.com |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7335 Location: Honolulu,Hawaii and France
Posted: Fri Aug 22, 2025 12:27 am Post subject: Re: What Vanagons came with reinforced main longitudinal frame rail? |
I posted about this a couple years ago, it came back only the last years had it, like 1990/1991 with a few 1991/1992 not having it, prolly slapped together with parts laying around, a classic move from VW to not waste anything. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Sodo Samba Member
Joined: July 06, 2007 Posts: 10943 Location: Western WA
Posted: Fri Aug 22, 2025 9:20 am Post subject: Re: What Vanagons came with reinforced main longitudinal frame rail? |
Pic of Syncro frames showing a '90 Syncro Westy with the logitudinal frame reinforcement.
1987 is a tintop Syncro.
I don't see how this would increase stiffness to "body twist".
Maybe a little.... _________________
'87 Tintop, EJ25, cooled filtered (original) gearbox
....KTMs, GasGas, SPOT mtb
All Vanagons should do this:
Add direct starter-to-chassis cable THEN delete ground strap at front transaxle mount.
The best time to do this mod was in 2010. The second best time is TODAY.
If your starter is slow, this is MORE important. |
jlrftype7 Samba Member
Posted: Fri Aug 22, 2025 10:25 am Post subject: Re: What Vanagons came with reinforced main longitudinal frame rail? |
| tdivan82 wrote: |
I don't have knowledge of the specific frame reinforcements in question, but I do know that metal fatigue on vehicles is a thing, especially those that see extreme use cases e.g. racing or off-roading. Take a paperclip and start bending it back and forth in your fingers. After a handful of times, the metal simply cracks and breaks. Vehicles are no different. It is interesting to see the side-by-side photos of the "reinforced" vs. "non-reinforced" frame rails. |
Range Rover Classics, the body style from 1970 to basically 1995, had a 'tell' of Off-roading usage after you'd been on the trails for a good long while.
The B pillar of the body would develop a tiny crack about 3/4s of the way up the Pillar, visible on the outside.
I wondered about this as I'd heard it from owners and other LR Techs while we owned our '94 RR Short Wheel Base.
Then we got it.... , after enough off-roading. Drivers side only. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
RoryGirl Samba Member
Joined: October 14, 2016 Posts: 1019 Location: WestWorld Nanaimo BC
Posted: Fri Aug 22, 2025 11:59 am Post subject: Re: What Vanagons came with reinforced main longitudinal frame rail? |
My 91 twin slider has the "flared" oval holes but no reinforcements.
Edit - 993 posts
_________________ 1991 Twin Slider VR6
1985 Audi 4k |
Microbusdeluxe  Samba Member
Joined: July 26, 2003 Posts: 1009 Location: Bellingham, WA
Posted: Thu Sep 04, 2025 3:18 pm Post subject: Re: What Vanagons came with reinforced main longitudinal frame rail? |
I'll weigh in here especially as my syncro is one of those referenced in this discussion. I have an '89 factory 16" syncro hightop Joker. I crawled under it today and here's what I saw.
The frame rails have the lip around the oval holes, but they definitely do not have the internal frame. I could shove my fingers 3-4" up into the frame rail and touch the underside of the floor. I had the photos from the article linked to the post by WiboBusMan with me as I examined it. Now I know my rig is an original factory 16 Westy. It has all of the other bells and whistles, reinforcement at the top of the B pillar on the passenger's side, plates welded & covering the webs in the interior, proper M plate codes, etc.
My guess is that Alika T3 has the correct take on it, that it was added in the 1990 production run, possibly to address the side panel crease. Anywho here's another piece of info for you.[/b] _________________ '69 Squareback RIP
'65 21 window deluxe sold before the price spike, damn it.
'70 rhd bay now a taxi in South Sudan
'81 Westy sold
'89 hightop Westy Joker syncro 16" now with Bostig! |
Posted: Fri Sep 05, 2025 11:24 am Post subject: Re: What Vanagons came with reinforced main longitudinal frame rail? |
| Microbusdeluxe wrote: |
My guess is that Alika T3 has the correct take on it, that it was added in the 1990 production run, possibly to address the side panel crease. Anywho here's another piece of info for you.[/b] |
Bah! I would have sworn that the Joker had the added reinforcement. Oh well, old decrepit brain fart.
On it being an original factory 16" - you should have received the "Birth Certificate" I provided when I sold it to Richard. Just FYI here it is:
