Whaanga Samba Member
Joined: May 07, 2016 Posts: 645 Location: Rochester, NY
Posted: Sun Oct 26, 2025 9:00 pm Post subject: fuel vapor smell |
Hello,
Recently I replaced my single progressive Weber with a set of rebuilt dual Solex’s. It’s taken a while but they are now dialed in and working very well.
The only issue is I’m getting a fuel smell from the left side of the engine - which is especially noticeable from the air scoop. I noticed it with the single Weber, but it seems to be more prominent with the dual Solex’s. I’ve done my best to check the vent lines and the small rubber joints in the system (including the one under the spare tire) and they are all solid from when I replaced them a few years ago.
I would be grateful for suggestions of how I might track down the source of these fuel vapor smells I’m experiencing.
Thank You,
Jeff _________________ Late 1973 Bay w/a transplanted 914 Engine |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42955 Location: at the beach in Northern Wokistan
Posted: Sun Oct 26, 2025 9:51 pm Post subject: Re: fuel vapor smell |
look up under the spare tire well really hard with a flash light and you will probably find a broken vapor hose _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1797 Location: New Brunswick,Canada
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3445 Location: Hamble, Hampshire, UK
Posted: Mon Oct 27, 2025 10:20 am Post subject: Re: fuel vapor smell |
It could be a broken breather pipe joiner - the inaccessible one up behind the spare wheel tub can fail in a year or so: when you fill the tank to the top, there is fuel in the pipe on the left at the joiner, but not on the right hand side (it is downstream of the loop in the vent on the right) . Then it gets hard and cracks with heat rising .
Or it could be a sticking float valve in the left hand carburettor. _________________ Ancient vehicles and vessels
Posted: Wed Oct 29, 2025 7:31 pm Post subject: Re: fuel vapor smell |
Thanks for the replies. I took a look at the rubber joint for the caper system u see the spare tire well. The hose looks a little small so I swapped it out with one that was longer to cover both ends of the metal vapor lines.
The photo shows the hose before I swapped it out.
Posted: Wed Oct 29, 2025 8:46 pm Post subject: Re: fuel vapor smell |
| mikedjames wrote: |
Or it could be a sticking float valve in the left hand carburettor. |
If you use either the Gate Barricade low or high pressure 30r14 hose it should last for decades, 30r9 will also work well. |
SGKent  Samba Member
Posted: Wed Oct 29, 2025 9:45 pm Post subject: Re: fuel vapor smell |
| Whaanga wrote: |
look for damp around the carb. Keep an eye on the engine oil level and smell. _________________
George Carlin:
