fuel vapor smell
Whaanga
Whaanga is offline
PostPosted: Sun Oct 26, 2025 9:00 pm    Post subject: fuel vapor smell Reply with quote
Hello,
Recently I replaced my single progressive Weber with a set of rebuilt dual Solex’s. It’s taken a while but they are now dialed in and working very well.
The only issue is I’m getting a fuel smell from the left side of the engine - which is especially noticeable from the air scoop. I noticed it with the single Weber, but it seems to be more prominent with the dual Solex’s. I’ve done my best to check the vent lines and the small rubber joints in the system (including the one under the spare tire) and they are all solid from when I replaced them a few years ago.
I would be grateful for suggestions of how I might track down the source of these fuel vapor smells I’m experiencing.
Thank You,
Jeff
Late 1973 Bay w/a transplanted 914 Engine
SGKent Premium Member
SGKent is offline
PostPosted: Sun Oct 26, 2025 9:51 pm    Post subject: Re: fuel vapor smell Reply with quote
look up under the spare tire well really hard with a flash light and you will probably find a broken vapor hose
George Carlin:
Skills@EuroCarsPlus:
lil-jinx
lil-jinx is offline
PostPosted: Mon Oct 27, 2025 4:56 am    Post subject: Re: fuel vapor smell Reply with quote
removing the left tail light allows access to that hose ,at least it allows you to see it,even if your arm don't fit thru it
1968 Dune Buggy sold dec 2024
1974 parts bus
lil-jinx
lil-jinx is offline
PostPosted: Mon Oct 27, 2025 5:00 am    Post subject: Re: fuel vapor smell Reply with quote
my left side solex will wet the throttle shaft ,when i pump the fuel with engine off,the gas hits the throttle plate and seeps out the front .not a problem when running.
1974 parts bus
mikedjames
mikedjames is offline
PostPosted: Mon Oct 27, 2025 10:20 am    Post subject: Re: fuel vapor smell Reply with quote
It could be a broken breather pipe joiner - the inaccessible one up behind the spare wheel tub can fail in a year or so: when you fill the tank to the top, there is fuel in the pipe on the left at the joiner, but not on the right hand side (it is downstream of the loop in the vent on the right) . Then it gets hard and cracks with heat rising .
Or it could be a sticking float valve in the left hand carburettor.
Ancient vehicles and vessels
Whaanga
Whaanga is offline
PostPosted: Wed Oct 29, 2025 7:31 pm    Post subject: Re: fuel vapor smell Reply with quote
Thanks for the replies. I took a look at the rubber joint for the caper system u see the spare tire well. The hose looks a little small so I swapped it out with one that was longer to cover both ends of the metal vapor lines.
The photo shows the hose before I swapped it out.
Wildthings
Wildthings is offline
PostPosted: Wed Oct 29, 2025 8:46 pm    Post subject: Re: fuel vapor smell Reply with quote
If you use either the Gate Barricade low or high pressure 30r14 hose it should last for decades, 30r9 will also work well.
SGKent is offline
PostPosted: Wed Oct 29, 2025 9:45 pm    Post subject: Re: fuel vapor smell Reply with quote
look for damp around the carb. Keep an eye on the engine oil level and smell.
George Carlin:
