Finally ready for paint got questions on interior 67 Westy
Saggs
Saggs is offline
PostPosted: Tue Oct 28, 2025 10:34 am    Post subject: Finally ready for paint got questions on interior 67 Westy Reply with quote
Finally getting ready for some epoxy primer after all the metal and body work.
Should I spray the inside first then mask off and do the exterior or shoot it all wide open?
Gonna do a two tone. Was going to paint the interior the same color as above the belt line.
Here’s where im at now:
Was thinking a Pampas green lower with a creamy white or the porcelain green top like the ‘61 Ghia color
"One man can make a difference...Jesus did."
BarryL Premium Member
BarryL is offline
PostPosted: Tue Oct 28, 2025 6:19 pm    Post subject: Re: Finally ready for paint got questions on interior 67 Westy Reply with quote
Saggs wrote:
Should I spray the inside first then mask off and do the exterior or shoot it all wide open?r
All at once is a lot of reaching contortions and trigger time. Plus there will be a lot of coarse overspray getting covered up in and out.
On the other hand if you're cool with that then it's done all at once.
Saggs
Saggs is offline
PostPosted: Wed Oct 29, 2025 10:41 am    Post subject: Re: Finally ready for paint got questions on interior 67 Westy Reply with quote
So would it make sense to mask off the interior and shoot them at separate times?
BarryL is offline
PostPosted: Wed Oct 29, 2025 6:17 pm    Post subject: Re: Finally ready for paint got questions on interior 67 Westy Reply with quote
I don't want to be the only one that answers you.
I've done one and I had all the doors off hanging so that is different and easier to mask.
You could mask the windows, have all the doors open with their outside masked, mask a wide strip on the outside body so you get all the jambs, then shoot the inside.
For the outside do the opposite but you could tape the jambs and shut the doors to spray the outside.
Yannvanh
Yannvanh is offline
PostPosted: Thu Oct 30, 2025 7:33 am    Post subject: Re: Finally ready for paint got questions on interior 67 Westy Reply with quote
we're in the same stage!
i need to do a little bit bodywork on the nose and then spray the whole outside in epoxy and final primer. (inside is already in final primer)
then i'm going to mask the outside and paint the inside myself before it goes to a painter who does the opposite and masks the inside so he can paint the outside!.
'66 vw splitbus project:
Instagram page:
yannicks_splitbus_project
Always there to help!
thom
thom is offline
PostPosted: Thu Oct 30, 2025 8:10 am    Post subject: Re: Finally ready for paint got questions on interior 67 Westy Reply with quote
Personally, I like to mask the outside and paint the inside first.
-Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type
matthew henricks
matthew henricks is offline
PostPosted: Thu Oct 30, 2025 8:15 am    Post subject: Re: Finally ready for paint got questions on interior 67 Westy Reply with quote
Seems like your asking two different questions.
For primer it probably does not matter if you do sections or all at once. Over spray will happen but your going to do some sanding anyways.
For top coat i sprayed my interior completely first. I then sprayed the bottom color and last the top. Seams other than the belt line (where it matters) were done at the door seals.
Have fun.
1964 Original Owner build Thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=702135&highlight=
Ambulance Fan's. https://www.thesamba.com/vw/forum/viewtopic.php?t=627707&highlight=
Parts i am looking for:
64 bug nice used front/rear Black LHD floor mat.
Saggs
Saggs is offline
PostPosted: Thu Oct 30, 2025 2:41 pm    Post subject: Re: Finally ready for paint got questions on interior 67 Westy Reply with quote
Thanks for the responses. I think I got a plan now. Did you paint your jambs to mirror the two colors at the belt line and is your interior color the same as the upper color if it’s a two tone?
matthew henricks
PostPosted: Thu Oct 30, 2025 5:11 pm    Post subject: Re: Finally ready for paint got questions on interior 67 Westy Reply with quote
Yes.
Don't have any good images to share but there are lots in the gallery. To me, the important tape line is the front nose. As i am sure you know the tape line is not hidden by the belt trim so you have to be precise at the nose to make it look good.
BarryL is offline
PostPosted: Thu Oct 30, 2025 6:25 pm    Post subject: Re: Finally ready for paint got questions on interior 67 Westy Reply with quote
Also what gun are you using? High Volume Low Pressure guns are more forgiving if you were to shoot the inside then move outside without masking.
Saggs
Saggs is offline
PostPosted: Fri Oct 31, 2025 5:30 pm    Post subject: Re: Finally ready for paint got questions on interior 67 Westy Reply with quote
Im using an hvlp gun. I’ve read to spray the lower color a bit over the belt line then tape off the lower and spray the upper color. I need to get my doors all lined up and the rear hatch dialed in.
Looking at the 61 ghia green with a cream colored upper color
SolarPoweredPickles
SolarPoweredPickles is offline
PostPosted: Sun Nov 02, 2025 12:41 pm    Post subject: Re: Finally ready for paint got questions on interior 67 Westy Reply with quote
Im certainly no painter but with that said Ive painted a ton of cars. I am almost the painting stage myself, I've chosen to do what I think you or someone else said based on my build time-line, what I have, and will need, my space and funds, etc.
Someone said they are priming and painting interior themselves, which is what Im doing, then I'll paint the outside another day or time, or possibly have someone do it for me, either way, I want the inside done first so I can put in my gauges, steering wheel, wiring, and tidy up some things to get it close to being a driver or roller, then finally paint the outside.
What kind of paint/color are you using? Not sure if I missed that. I've changed color options so many times in the last year Im at no rush now, aside from the inside, which my brain is locked in on a good off-white clean and simple, stock-ish vibe.
Vintage problems require vintage excuses.
Saggs
Saggs is offline
PostPosted: Tue Nov 04, 2025 5:27 pm    Post subject: Re: Finally ready for paint got questions on interior 67 Westy Reply with quote
Well im thinking of going with a Pampas Green like the ghia above for the lower color snd a beige or cream white ( maybe the L87) for the upper and roof area.
Probably using a single stage urethane.
