Generator reassembly help
tbonetoby14
tbonetoby14 is offline
PostPosted: Fri Oct 31, 2025 3:24 pm    Post subject: Generator reassembly help Reply with quote
First post here:
I recently got a new Bosch 12v generator for my 67 sunroof. It came with some woodroof keys on the pulley and fan sides but they seem to be too big for the pulley and fan hardware. I'm using the old pieces from the other generator I had on the bug and they don't seem to fit. I took one of them off and compared it to the old keys and the new ones seem to be wider and won't fit the keyways on the pulley or fan equipment. It also won't go back in the key grove as well as it was before I took it out. I've watched plenty of videos on reassembly and they all make it so easy. Am I doing something wrong? Do I need to get new hardware and a new pulley that fit the keys? Can anyone give me some insight on this please?
slayer61
slayer61 is offline
PostPosted: Fri Oct 31, 2025 3:47 pm    Post subject: Re: Generator reassembly help Reply with quote
I lost one of the woodruff keys when swapping mine. For like $12 at the local ranch and farm supply, I bought an entire assortment of metric ones and found the missing part in the kit. To me, it was easier and faster than trying to find an original replacement... as they say... YMMV
Cusser wrote:
... Most folks are idiots when it deals with electrical !!!
67rustavenger wrote:
3/4 race cam? What's missing, one of the lobes? Shocked
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo (pending)
Tim's stage II turbo heads (pending)
MSD Box and distributor
Car Craft turbo header
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
aquifer Premium Member
aquifer is offline
PostPosted: Fri Oct 31, 2025 3:49 pm    Post subject: Re: Generator reassembly help Reply with quote
Run a file or emery cloth over the keys to whittle them down a touch. Maybe scrape the edges of the keyways with a screwdriver too. Unless you mean that the keys are clearly a size or two too large, in which case you'll need to find the right size. But I suspect it's just imperfect machining.
Project vehicles:
1967 Beetle #1. Bought in 2024, mostly original, October 1966 build date. Java Green.
1967 Beetle #2. Bought in the mid 80's, restored myself in the late 90's, June 1967 build date. Java Green.
1998 Jaguar XJR. Bought in 2015, rust free AZ car, refurbished myself. Driven in nice weather.
Parts needed:
Original brown rubber floor mats for a '67
Original gazelle seat upholstery for a ‘67
esde
esde is offline
PostPosted: Fri Oct 31, 2025 4:01 pm    Post subject: Re: Generator reassembly help Reply with quote
I've definitely had to file keys and keyways to get a nice fit in the past..
modok wrote:
Cusser
Cusser is offline
PostPosted: Fri Oct 31, 2025 4:46 pm    Post subject: Re: Generator reassembly help Reply with quote
I seem to remember Ace Hardware by me having metric woodruff keys in the little drawers.
tbonetoby14
PostPosted: Fri Oct 31, 2025 5:04 pm    Post subject: Re: Generator reassembly help Reply with quote
Yall think it’s just a machining error that needs a little filing? The left key is the one that came with the generator. It just seems way bigger that the one from the original key. it also seems like that keyway on the shaft on the shaft is a bit bigger which is causing the old keys to now stay in place.
viiking
viiking is offline
PostPosted: Sat Nov 01, 2025 3:35 pm    Post subject: Re: Generator reassembly help Reply with quote
Held flat against an angle grinder or bench grinder gets it down close to what you need. Do a bit at a time and then make sure you are parallel. Use pliers etc to hold it to save your fingers.Then final finish with a file.
Alternatively just spend a lot of time with a file.
gt1953
gt1953 is offline
PostPosted: Sat Nov 01, 2025 7:15 pm    Post subject: Re: Generator reassembly help Reply with quote
File for sure as you will have more control...sure it may take longer but in end with the perfect fit.
72 type 1
72 Squareback
