Help, the "which exhaust do I need" game
Kevin Flint
Kevin Flint is offline
PostPosted: Thu Nov 06, 2025 12:48 pm    Post subject: Help, the "which exhaust do I need" game Reply with quote
Stroked 1800 with DP heads, SB2280 cam, 34 PICT and heater boxes. I'm interested in the quietest, stockest looking exhaust that will still take advantage of the added torque. Obviously I'm building a peppy grocery getter here, not a race car. Any thoughts on best exhaust? Extra points for actual experience. Thanks Sambans.
Max Welton
Max Welton is offline
PostPosted: Thu Nov 06, 2025 1:02 pm    Post subject: Re: Help, the "which exhaust do I need" game Reply with quote
Which type of VW do you have?
1967 Type-3 Fastback
Brian_e Premium Member
Brian_e is offline
One of the smaller vintage speed mufflers is exactly perfect for what you are wanting. The 1 1/2” ss143 with be the quietest, and it will help out with midrange torque.
It is also one of the few with a more correct manifold heat option, which if you are planning to keep the stock carb, you should 100% add the manifold heat option.
Brian
So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts
modok
modok is offline
PostPosted: Fri Nov 07, 2025 2:09 am    Post subject: Re: Help, the "which exhaust do I need" game Reply with quote
I agree with Brian E
garym999
garym999 is offline
PostPosted: Sat Nov 08, 2025 4:04 am    Post subject: Re: Help, the "which exhaust do I need" game Reply with quote
I have fitted the same this year to a fairly stock 1600DP as I was getting sick of rusting exhausts. It’s over kill for the engine but looks clean and tidy, is not noisy and opens up the top end a little too. I find the engine more happy to Rev.
I have heater boxes and a centre mount carb and the heat to the manifold is not quite as good. Also if you go for a VS do yourself a favour and buy some copper exhaust nuts and stainless studs. Given the cost of the exhaust they really could have afforded some decent mounting hardware. If you use their hardware you will find you have seized nuts and studs a while down the road when you need to take the exhaust off.
1975 South African Fleetline
