Brake residual pressure valve delete? 1973 and on?
deronmoped
deronmoped is offline
PostPosted: Wed Nov 12, 2025 6:44 am    Post subject: Brake residual pressure valve delete? 1973 and on? Reply with quote
How come VW deleted the residual pressure valve from the 1973 and on Bays? Would it be good to add a aftermarket one?
Thanks, Deron.
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Nov 12, 2025 9:35 am    Post subject: Re: Brake residual pressure valve delete? 1973 and on? Reply with quote
Do you actually mean RPV on the master connections, or do you mean the Brake Proportioning Valve that limits rear fluid pressure on hard braking?
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
airschooled
Air-Schooled
airschooled is offline
PostPosted: Wed Nov 12, 2025 12:27 pm    Post subject: Re: Brake residual pressure valve delete? 1973 and on? Reply with quote
Thanks, Deron.
Because it’s cheaper to put a spring in the rear wheel cylinders. (I thought the change was 1971; discs do not need RPVs.) If your ‘73 rear wheel cylinders are good, they should have the spring. A couple of aftermarket cylinder makers don’t include the spring.
Without either method, the pedal bite point will be farther down. It does not affect braking or pedal feel once the brakes are engaged.
Robbie
www.airschooled.com
Road trip reports and tech blog:
raygreenwood
raygreenwood is online now
PostPosted: Wed Nov 12, 2025 1:05 pm    Post subject: Re: Brake residual pressure valve delete? 1973 and on? Reply with quote
airschooled wrote:
Thanks, Deron.
Robbie
To add to that.....NOT having a residual pressure valve as well as NO springs in the rear wheel cylinders makes for much more difficult bleeding. The residual pressure valve makes for easier bleeding when there is no spring in the wheel cylinder to keep minor pressure on the pistons.
Ray
Bnanwel
Bnanwel is offline
PostPosted: Wed Nov 12, 2025 4:01 pm    Post subject: Re: Brake residual pressure valve delete? 1973 and on? Reply with quote
FWIW, 72 has the RPV.
‘72 Karmann Ghia Conv.
‘73 Karmann Ghia Coupe
‘74 Karmann Ghia Coupe
‘70 Deluxe
‘72 Deluxe
deronmoped
PostPosted: Thu Nov 13, 2025 8:21 am    Post subject: Re: Brake residual pressure valve delete? 1973 and on? Reply with quote
I mean the residual pressure valve that was removed from the brake proportioning valve. My BPV does not have the RPV. My BPV does not have the bleeder too. My BPV is the model with the brake in and brake out connections on the top of it.
So I'm thinking I do not have the correct rear slave cylinders with the spring in them. I swapped the braking system out of a 1973 into my 1970 Bus a long time ago. So I'm going to have to see exactly what I have in the way of slave cylinders on the rears. As I know I replaced one of the slaves two years ago and probably went with a 1970 one.
deronmoped
PostPosted: Thu Nov 13, 2025 8:25 am    Post subject: Re: Brake residual pressure valve delete? 1973 and on? Reply with quote
1955 to 1971 wheel cylinders are sold. 1972 to 1979 wheel cylinders are sold. So I'm guessing there is a change in the 72 to 79 wheel cylinder as compared to the 55 to 71 units.
kreemoweet
kreemoweet is offline
PostPosted: Thu Nov 13, 2025 9:50 am    Post subject: Re: Brake residual pressure valve delete? 1973 and on? Reply with quote
No, 55-71 cylinders can not be used on a later bus brake setup, the mounting is different.
'67 bug: seized by the authorities
deronmoped
PostPosted: Fri Nov 14, 2025 6:55 am    Post subject: Re: Brake residual pressure valve delete? 1973 and on? Reply with quote
"No, 55-71 cylinders can not be used on a later bus brake setup, the mounting is different."
What if I kept my 1970 backing plates? I'm not sure what I swapped over when I converted my 1970 brakes to 1973 brakes. Probably the minimum, just enough newer parts to make the disc brake swap work.
I'm going to pull a wheel to find out.
