76 muffler strap bolt size
Globedog12 Premium Member
Globedog12 is offline
PostPosted: Sat Nov 15, 2025 9:05 am    Post subject: 76 muffler strap bolt size Reply with quote
Can anyone tell me the bolt size for the muffler strap?
Po welded over the hole I want to get the correct tap size.
1976 VW Type 2 Original fuel injection
germansupplyscott
germansupplyscott is offline
PostPosted: Sat Nov 15, 2025 10:35 am    Post subject: Re: 76 muffler strap bolt size Reply with quote
m8 x 1.25
SL
PostPosted: Sat Nov 15, 2025 10:52 am    Post subject: Re: 76 muffler strap bolt size Reply with quote
germansupplyscott wrote:
m8 x 1.25
Thanks
lil-jinx
lil-jinx is offline
PostPosted: Sat Nov 15, 2025 11:35 am    Post subject: Re: 76 muffler strap bolt size Reply with quote
if the hole has been welded over,it will probably be too hard to tap,
1968 Dune Buggy sold dec 2024
1974 parts bus
PostPosted: Sat Nov 15, 2025 11:58 am    Post subject: Re: 76 muffler strap bolt size Reply with quote
I’m being pretty generous with the term weld. A filler metal of some sort was boogered on is probably a better description. I was able to cut the booger flush with the original tapped hole with a cutting disc on my grinder and the plug in the tapped hole drilled out pretty easily. Just waiting for the tap now.
lil-jinx
lil-jinx is offline
PostPosted: Sat Nov 15, 2025 12:10 pm    Post subject: Re: 76 muffler strap bolt size Reply with quote
you should be good to go then.
1974 parts bus
