Vanistan Seat Tilt Kit install?
RicMcK Premium Member
RicMcK is offline
PostPosted: Mon Nov 10, 2025 9:09 am    Post subject: Vanistan Seat Tilt Kit install? Reply with quote
I'm looking for advice on installing a Vanistan Seat tilt kit in a 89 westy. I'm looking for advice from anyone who has done this modification and any photos you might have.
I'm scared about getting out the angle grinder and cutting things out as it is a one way street.
I want to do this modification to access the space under the to add charge controller ... and or LiFe battery electronics. I will put this on the left seat (I know I will need to slide the seat off to be able to tilt the swivel up).
Rick McK
Seattle
89 Westfalia-2.2L WBX "VINNY"
2006 TDI Jetta
1936 Ford Pick up
70 tin top, 700k mi when sold in 91
58 split window bug - (first car) long gone.
vanis13
vanis13 is offline
PostPosted: Mon Nov 10, 2025 9:11 am    Post subject: Re: Vanistan Seat Tilt Kit install? Reply with quote
I've done this install on a passenger seat.
Have you asked the vendor? if so, what did Chris say?
jlrftype7
jlrftype7 is offline
PostPosted: Mon Nov 10, 2025 9:34 am    Post subject: Re: Vanistan Seat Tilt Kit install? Reply with quote
Has anyone posted a YouTube Video on doing the kit yet? I haven't searched for you, was just wondering out loud. Think Think
‘84 Tin Top - Hilga....Auto
Sodo
Sodo is offline
PostPosted: Mon Nov 10, 2025 12:02 pm    Post subject: Re: Vanistan Seat Tilt Kit install? Reply with quote
Not true. Cuts can be re-welded. Especially under the seat. Nobody is going to judge you for what they cannot see under the seat.
Except I will likely receive judgement because I was perhaps a little too enamored with my mod. I made my (passenger) seat tip sideways and have since come to realize that tipping forward is (likely) better. So I’m gonna cut that sideways stuff off and redesign for forward. Then I’m gonna find out if I like it better.
I recommend that you cut the swivel off, then make it simply “bolt on”.
With easy access to the bolts.
I suspect unbolting could be easier than sliding the seat off the track.
There’s something to be said for doing the same mod on the passenger side too.
....KTMs, GasGas, SPOT mtb
Rorke
Rorke is offline
PostPosted: Wed Nov 12, 2025 4:58 pm    Post subject: Re: Vanistan Seat Tilt Kit install? Reply with quote
I installed one on the passenger side.
It was possibly the most unnecessarily challenging projects I have experienced.
I emailed rewritten directions that I thought might help future installers. My edits were not well received or even discussed. I even offered to make a video of the proper install being done on my driver’s side.
I think the genuinely constructive criticism hit on a bad day. But i also got a bit frustrated and said fuck this.
Sorry I deleted my notes. They are probably in an old email or maybe on facebook vanagon technical depository group.
I do like having the space because I moved my start battery elsewhere. Then I metered that space with the under seat storage. It is the only solution I ever found for a huge cast iron pan.
Good luck. Reach out if you still need a hand. (Lots of guys have helped me plenty and I owe)
RicMcK is offline
PostPosted: Wed Nov 12, 2025 5:33 pm    Post subject: Re: Vanistan Seat Tilt Kit install? Reply with quote
So From what I understand this is were I should cut the pedestal (white lines). does this look correct? The extra holes in the pedestal are to see and mount my BlueSeas battery isolator/switch.
Rick McK
Seattle
2006 TDI Jetta
1936 Ford Pick up
Rorke
Rorke is offline
PostPosted: Fri Nov 14, 2025 2:01 pm    Post subject: Re: Vanistan Seat Tilt Kit install? Reply with quote
Rick,
Those lines are correct.
Here are tips.
You must grind as close to the track tabs as possible, even if you shave a little
off the inside of each tab, that is better than leaving too much extra on the van.
I used a grinder. I wish that I used a tool with a finer kerf. Not sure that term is the right one. But I wish I removed less material with the cut itself.
Ultimately, the base that you are removing must be cut to be as WIDE as possible. If it is cut too narrow, then when you mount the hinges, you will need to add spacers to the hinges that connect the mount to the base.
I did not know this, so I started to straighten my sides (removing even more material) then I said…maybe I should fit this first, then uninstall to clean up and paint. Good thing I did that.
You can see in the photos that I cut the base too narrow because I figured it was a rough cut. The directions were not clear as to why or where the cut should be.
If this helps you, I will be all stoked up.
RicMcK is offline
PostPosted: Fri Nov 14, 2025 6:44 pm    Post subject: Re: Vanistan Seat Tilt Kit install? Reply with quote
ROKE. THANK YOU for the Great advice, including the videos and photos. I'm planning on using the thinnest cut off blade I can find to cut the welds out. I see the importance of trying to keep the base plate as wide as possible. And it's great to know the washer- spacers thing worked, in case it is too narrow.
Thanks a bunch
Rick McK
Seattle
2006 TDI Jetta
1936 Ford Pick up
Sodo
Sodo is offline
PostPosted: Fri Nov 14, 2025 11:47 pm    Post subject: Re: Vanistan Seat Tilt Kit install? Reply with quote
Don't shoot sparks at carpet.
Each spark will melt several thread loops and you will make a bald-spot instantly.
I used videos from GoWesty website how to cut out the swivel.
16CVs
16CVs is offline
PostPosted: Sat Nov 15, 2025 11:25 am    Post subject: Re: Vanistan Seat Tilt Kit install? Reply with quote
I was at Go Westy years ago buying sone parts for my Westy conversion and one of the items was a base for a seat rotater. They actually had a plywood shield built that drops in place while they use a cutoff wheel to syoo sparks from hitting the carpet and glass.
Samba member # 14980
RicMcK is offline
PostPosted: Sat Nov 15, 2025 11:57 am    Post subject: Re: Vanistan Seat Tilt Kit install? Reply with quote
Thanks for the heads up about the sparks. I will do my best to cover up the carpets before I at it.
Rick McK
Seattle
2006 TDI Jetta
1936 Ford Pick up
Rorke
Rorke is offline
PostPosted: Sun Nov 16, 2025 7:32 am    Post subject: Re: Vanistan Seat Tilt Kit install? Reply with quote
I set up some cardboard boxes and damp towels. All around. Cover everything in site so it's not a concern and you can concentrate.
I skipped some basics about grinding like spark protection. But since this might get searched years from now by a beginner, here are other pointers.
Wear safety glasses. If the wheel dismantles, fragments travel faster than any Vanagon ever has. Gloves with wrist coverage is a good call for this reason too.
It's a good idea to keep the guard on. Although, it is a pain at times. I don't even know where mine is.
Use the proper wheel for the job.
Ideally, cut so the wheel pulls along the cut.
Let the wheel spin up before cutting. Pull away from the steelbefore slowing down.
Cut for 5-10 seconds, then cool for 2-3 seconds. Use light pressure. It's not a handsaw.
Two hands are better than one. Even though the tools are light, it can kick.
Bulli Klinik
Bulli Klinik is offline
PostPosted: Sun Nov 16, 2025 7:58 am    Post subject: Re: Vanistan Seat Tilt Kit install? Reply with quote
Don't forget to cover the glass as well.
Mike K
Bulli Klinik
Colorado Springs
jlrftype7
PostPosted: Mon Nov 17, 2025 10:51 am    Post subject: Re: Vanistan Seat Tilt Kit install? Reply with quote
I've seen that Plywood shield in their Video for working with the Seat Base/Swivel system... Cool Cool
Crooked Designer
Crooked Designer is offline
PostPosted: Mon Nov 17, 2025 11:19 am    Post subject: Re: Vanistan Seat Tilt Kit install? Reply with quote
All good advice, but I'd add to use a face shield if you have one. your eyes are not the only think you'll want to protect from those sparks.
'85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit
RicMcK is offline
PostPosted: Mon Nov 17, 2025 2:12 pm    Post subject: Re: Vanistan Seat Tilt Kit install? Reply with quote
Thanks for all the advice, it's bee super helpful.
It was a success Smile
I taped off the carpet around the Pedestal
Made a cardboard box to fit as best I could
Used the thinnest cutoff wheel I could find
Went SLOW
It wasn't perfect, but good enough Smile The left hinge is not as straight as I would like it, but it seems to work fine.
Now I need to clean everything up, paint, final assembly, wringing upgrades (Blue Seas 120A breaker, and new cable), 12V relay for fridge setup.
Next, will be lengthening (deeper) the battery box.
Rick McK
Seattle
2006 TDI Jetta
1936 Ford Pick up
MarkWard
MarkWard is offline
PostPosted: Tue Nov 18, 2025 4:22 am    Post subject: Re: Vanistan Seat Tilt Kit install? Reply with quote
Went SLOW
I don’t remember the driver’s swivel in our 82 camper being so welded in. Because I was removing my swivel, it was very important not to damage the factory seat tracks. I’m remembering maybe 4 stitch welds near each corner. Maybe it was changed in production.
Kdj
Kdj is offline
PostPosted: Tue Nov 18, 2025 8:00 am    Post subject: Re: Vanistan Seat Tilt Kit install? Reply with quote
Post some pictures when you get seat installed. Interested in how far it will tilt forward before hitting steering wheel. That will be a great use of space.
Rorke
Rorke is offline
PostPosted: Wed Nov 19, 2025 9:19 am    Post subject: Re: Vanistan Seat Tilt Kit install? Reply with quote
Rick,
Very nice job.
It your seat swiveling smoothly?
Mine has clearance issues. So I have to really force-tilt the seat to clear.
I feel like I have many hours to go on this install. All of which could have been avoided with improvements to the instructions and a slight modification to the product. Overall, it is clever and functional. Surely, anyone could do a very nice job on their third install. Haha.
MarkWard
MarkWard is offline
PostPosted: Wed Nov 19, 2025 10:09 am    Post subject: Re: Vanistan Seat Tilt Kit install? Reply with quote
Is it my eye? The parts don’t appear square to each other. Also, is this mod DOT approved? In an accident it is important the seat doesn’t detach. The restraint system depends on the seat being secure.
