dbeeby Samba Member
Posted: Sun Nov 16, 2025 10:52 am Post subject: Eurovan 2.8 VR6 Tensioner Pulley Assemblies |
Hello folks,
Can anyone verify what Gemini (Google AI) is telling me incorrect information about the Tensioner Pulley Assembly versions (021145299A v 021145299C) for an '03 Eurovan:
| Quote: |
The revision letter indicates design changes, which can include variations in arm length and the internal coil spring mechanism.
The key takeaway is that the "C" version, despite the physical difference in arm length compared to the "A" version, is engineered by the manufacturer to be a direct functional replacement that fits the specified vehicles without modification. |
Examples:
A. ΓRO PARTS 021145299A
C. 38175 Automatic Belt Tensioner Compatible With 92-02 VW Golf Jetta Passat Corrado VR6 2.8L V6
The "arm" of the Uro Parts tensioner 021145299A (which IDENTICALLY matches the one in my Eurovan, see photo below), is much longer than that of the 021145299C
Can anyone tell me if they are, in fact, interchangeable?
Regarding Pulleys:
Many vendors say that the Duralast 231071 (aka Meyle 100 145 0101) pulley will work on the '03 EV, but not if you have a 021145299A assembly. Only the Four Seasons 45032 will work:
Tom Clark Samba Member
Technoblau  Samba Member
Joined: January 23, 2023 Posts: 25 Location: Probably under a T4
Posted: Sun Nov 16, 2025 1:16 pm Post subject: Re: Eurovan 2.8 VR6 Tensioner Pulley Assemblies |
Just wanted to throw in that when I replaced the tensioner on our '01 24v, "299A" was the only one that fit. _________________ 2001 MV Weekender - Techno Blue - New Chains, Seals and Trans, β213k
2003 MV Weekender - Tornado Red - the new project, 302k! |
qval Samba Member
Posted: Sun Nov 16, 2025 5:04 pm Post subject: Re: Eurovan 2.8 VR6 Tensioner Pulley Assemblies |
I'm 99% sure you need a pulley with ribs and "taller than those ribs" edges. I'm also 99% sure that the belt tensioner is the same from 97-2003. SD Europarts sells both the whole tensioner and the pulley by itself, though those are kinda expensive.
But don't trust any generative AI without confirming elsewhere. They lie more often than not. _________________ 2000 MV weekender, 270k miles |
qval Samba Member
Posted: Sun Nov 16, 2025 5:14 pm Post subject: Re: Eurovan 2.8 VR6 Tensioner Pulley Assemblies |
Sometimes at AutoZone I have them try a1997 eurovan instead of 2000 because they should have the same parts but connectors are often oval instead of rectangular. Maybe they'll have a tensioner listed for a 97 or 99, or 2000 that looks right on their screen. _________________ 2000 MV weekender, 270k miles |
tdibiker Samba Member
Joined: January 19, 2014 Posts: 14 Location: Sylva, NC
Posted: Sun Nov 16, 2025 7:08 pm Post subject: Re: Eurovan 2.8 VR6 Tensioner Pulley Assemblies |
If your tensioner is still functioning, but your pulley is going bad or has broken, the one Europarts-SD sells is the Gates 36320 (edited). It can also be purchased locally. It's a bit bigger in diameter, but it's steel and works and fits well. _________________ 95 EVC 217k
03 EVMV 367k
04 Vista 89k
00 Jetta TDI 384k
07 Touareg V10 TDI 83k
97 F250 WVO 411k
00 996 Conv 180k
....and others
dbeeby Samba Member
Posted: Mon Nov 17, 2025 7:00 am Post subject: Re: Eurovan 2.8 VR6 Tensioner Pulley Assemblies |
| tdibiker wrote: |
| If your tensioner is still functioning, but your pulley is going bad or has broken, the one Europarts-SD sells is the Gates 3632. It can also be purchased locally. It's a bit bigger in diameter, but it's steel and works and fits well. |
Hey tdibiker, can you clarify about the gates pulley? Is that a 36320 or some other part number?
Thanks! |
Posted: Mon Nov 17, 2025 8:06 am Post subject: Re: Eurovan 2.8 VR6 Tensioner Pulley Assemblies |
| dbeeby wrote: |
| tdibiker wrote: |
Ooops, 36320 is the complete number. The Rialta Owners Group on FB has had a lot of luck with this pulley as a replacement. I've installed 2 so far. It is slightly larger in diameter than stock, but does not interfere with the tensioner and doesn't require a different belt, just a little more effort to get on. _________________ 95 EVC 217k
03 EVMV 367k
04 Vista 89k
00 Jetta TDI 384k
97 F250 WVO 411k
00 996 Conv 180k
....and others |
dbeeby Samba Member
Posted: Mon Nov 17, 2025 8:48 am Post subject: Re: Eurovan 2.8 VR6 Tensioner Pulley Assemblies |
| tdibiker wrote: |
| Ooops, 36320 is the complete number. The Rialta Owners Group on FB has had a lot of luck with this pulley as a replacement. I've installed 2 so far. It is slightly larger in diameter than stock, but does not interfere with the tensioner and doesn't require a different belt, just a little more effort to get on. |
Thanks TDIBiker for all of your help with this.
The Gates 36320 is a SEVEN GROOVE (good!) 76mm pulley, it cross references to a Litens 900467A, which the local auto parts store has in stock.
The original part (as far as I can tell) is the four Seasons 45032, which is also seven-groove, but is only 62mm
76mm vs 62mm seems significant, but you're sure this'll work with the standard belt? |
Posted: Mon Nov 17, 2025 9:00 am Post subject: Re: Eurovan 2.8 VR6 Tensioner Pulley Assemblies |
Sorry if this is a dumb question, but why not buy a Four Seasons 45032? Widely available at a reasonable price. Why would Rialta owners *not* be buying the original size/type? _________________ 2003 MV Weekender |
dbeeby Samba Member
Posted: Mon Nov 17, 2025 9:03 am Post subject: Re: Eurovan 2.8 VR6 Tensioner Pulley Assemblies |
| Tom Clark wrote: |
| Sorry if this is a dumb question, but why not buy a Four Seasons 45032? Widely available at a reasonable price. Why would Rialta owners *not* be buying the original size/type? |
Hey Tom... 100% reasonable question. I'm hoping to get on the road with a temporary solution today. I have the Four Seasons on order, but it won't be delivered for a few days yet.
I've tried all of the local autoparts stores and nobody has a 7-rib, 62mm pulley like the Four Seasons 45032. |
dbeeby Samba Member
Posted: Mon Nov 17, 2025 1:29 pm Post subject: Re: Eurovan 2.8 VR6 Tensioner Pulley Assemblies |
@tdibiker, I just couldn't bring myself to installing the Gates 36320 and a new belt.
At the autoparts store the guy went through all of the pulley boxes and we found a 62mm pulley, but it only had five grooves. But the size difference between the 62mm and 76mm pulleys was too much for me to feel comfortable installing the larger part and putting a bunch of strain on the accessories and their bearings.
I'll keep the Eurovan off the road until the right parts arrive, but thanks for all of your advice folks! |
bikes! Samba Member
Joined: April 27, 2014 Posts: 127 Location: Central CA Coast
Posted: Mon Nov 17, 2025 5:12 pm Post subject: Re: Eurovan 2.8 VR6 Tensioner Pulley Assemblies |
I had the Four Seasons 45032 on my 2002 weekender for a few years. Worked fine, until the plastic pulley started getting loose from the bearings causing a really annoying rattle at idle.
Replaced it summer of 2024 with ACDelco Gold 36320, which has an aluminium pulley and similar sealed bearings. I did not measure the diameter, but it is a bit larger than the 45032. But not so much larger that the stock belt wouldn't fit.
It's been running well for over a year. I checked it a few months ago when I had the van apart to replace the valve cover gasket. No play, no odd wear. _________________ VWs past: 66 Kombi, 76 Westfalia Camper, 17 GTI; present: 02 Eurovan MVW, 17 Alltrack SEL & 19 Golf R |
Posted: Mon Nov 17, 2025 7:32 pm Post subject: Re: Eurovan 2.8 VR6 Tensioner Pulley Assemblies |
Well, I'm not sure about the Four Seasons 45032, but I would assume the fact that it's also a plastic pulley is the reason for the Rialta group suggesting the Gates, which is steel. One of my plastic ones exploded with age, so I'm all for not having plastic.
I didn't measure mine to get the specific differences, but I'm fairly confident that it wasn't a 14mm difference. It was only slightly larger and it fit on the unloaded tensioner without interference. I just pulled a tape across the old one and it was 68mm across the outside edge. I didn't feel that the extra range that I had to rotate the tensioner to get the belt on was adding any extra tension as it seems to be a fairly constant tension across its range.
I've installed it on my 2003 EV and my 2004 Vista (03 EV cab) without any concerns.
Good luck on getting rolling again! _________________ 95 EVC 217k
03 EVMV 367k
04 Vista 89k
00 Jetta TDI 384k
97 F250 WVO 411k
00 996 Conv 180k
....and others |
qval Samba Member
Posted: Mon Nov 17, 2025 9:32 pm Post subject: Re: Eurovan 2.8 VR6 Tensioner Pulley Assemblies |
Also, I think you're worrying too much about 14mm. That's the diameter and the radius is 7mm. The pulley arm is probably 80mm-100mm long (or more), so you're only adding maybe 5-10% more tension into the belt. Your spring had probably lost that much by sitting under strain for 22+years _________________ 2000 MV weekender, 270k miles |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24393 Location: NYC/Upstate/ROW
Posted: Tue Nov 18, 2025 1:54 am Post subject: Re: Eurovan 2.8 VR6 Tensioner Pulley Assemblies |
| qval wrote: |
| Also, I think you're worrying too much about 14mm. That's the diameter and the radius is 7mm. The pulley arm is probably 80mm-100mm long (or more), so you're only adding maybe 5-10% more tension into the belt. Your spring had probably lost that much by sitting under strain for 22+years |
Calculate the added length of run as a fraction of belt length. It will be about 0.69% _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
dbeeby Samba Member
Posted: Tue Nov 18, 2025 7:43 am Post subject: Re: Eurovan 2.8 VR6 Tensioner Pulley Assemblies |
Hey @Abscate, @qval, @tdibiker, and @bikes!,
These are all really good points. I was really on the fence about it and I understand (now) that the difference in size (62mm vs 76mm) and quality (plastic vs steel) probably shouldn't have put me off the Gates 36320/Litens 900467A.
I'll update as soon as I get the van back on the road. Thanks again to everyone for their great advice. |
Posted: Tue Nov 18, 2025 6:12 pm Post subject: Re: Eurovan 2.8 VR6 Tensioner Pulley Assemblies |
Hey dbeeby,
I hope you get it back rolling soon! The amazing thing is how much great information there is on the forum and a few of the others. I've developed so much trust in the Rialta group and this group that I don't even question most things. That's why I wasn't even aware of the other pulley options. Still planning to measure mine but didn't do it today.
Cheers!
Kent _________________ 95 EVC 217k
03 EVMV 367k
04 Vista 89k
00 Jetta TDI 384k
97 F250 WVO 411k
00 996 Conv 180k
....and others |
Posted: Wed Nov 19, 2025 1:49 am Post subject: Re: Eurovan 2.8 VR6 Tensioner Pulley Assemblies |
Btw we abhore URO parts on our Volvo forum for anything except engine plastic. Iβm not sure I would trust anything mechanical. Rubber is certainly out. _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
dbeeby Samba Member
Posted: Sun Nov 30, 2025 1:39 pm Post subject: Re: Eurovan 2.8 VR6 Tensioner Pulley Assemblies |
Update: the Four Seasons 45032 pulley and a new Continental belt put the van back on the road this weekend.
But I have a warning for other members who do this repair:
DO NOT OVER-TORQUE THE PULLEY BOLT TO LOOSEN THE BELT TO PUT IT ON!
Basically the pulley bolt is reverse threaded -- when you "loosen" it you're "tightening" it. I put on the new pulley and re-installed the tensioner pulley assembly, but when I went to put the belt on I "loosened" the pulley bolt (so it was actually tightening it) to the point where the bolt started to turn again... basically, I had stripped out the threads on the pulley bolt hole.
Instead of using the pulley bolt, insert one of the mounting bolts (M8x1.25x80mm) from above to relieve the tension on the pulley.
I'm hoping this can help other members avoid having to spend $150 on a new tensioner pulley assembly. |
