silversync Samba Member
Joined: September 01, 2005 Posts: 195 Location: San Pasqual Valley, CA
Posted: Tue Nov 18, 2025 3:06 pm Post subject: Diagnosis: Failed and blocked cat |
A couple of months ago the Vanagon (Syncro) was driving very poorly. There was no power, almost like dragging a brake or some heavy trailer. The engine made lots of noise and revs, funky sounds, but can't go fast.
I took it to a shop and they diagnosed a failed and blocked catalytic converter. He said they measured 2 lbs back pressure; don't have much experience with that test but evidently that was conclusive. I assume that is measured through the O-Sensor hole?
The current state is the O2 sensor is removed, and it now makes power like before, but of course is noisy and smelly. The advice was to wait until next summer when the CA smog test is due, then get a new cat, O2 sensor, and set it up properly. It seems like it is running super rich, and gas mileage is probably way down. Not big problem, no trips planned, just around town utility uses.
I seem to remember installing the Cat around maybe 16-17 years ago. Does anyone know Cat failure rates? New CA Cat is showing $1,445.80 at Van Cafe (OMG). It will take some meditating to face that expense.  _________________ Roland: '89 Syncro, '02 911 C4S, '10 Audi A4 Avant |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10484 Location: Orbiting San Diego
Posted: Tue Nov 18, 2025 3:37 pm Post subject: Re: Diagnosis: Failed and blocked cat |
If they didn't open up the exhaust then they are likely making an
educated guess.
Pieces of the cat can break off and go into the muffler, partially blocking it.
In that case it isn't just that the cat is blocked, and replacing the cat might not do the full job without also getting the pieces out of the muffler.
It is also possible to have damage/blockage on the upstream area of the cat without any broken pieces passing through to the muffler.
In your situation I would remove the cat and look in both ends to see what is going on.
If justified bust the remains out of the cat, install it with a NEW O2 sensor and see how it runs.
If all now ok replace the cat now or when the right time comes.
If not running ok, don't ruin a new cat before the cause is remedied.
Mark |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17324 Location: Brookeville, MD
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5946 Location: Bemidji, MN
Posted: Tue Nov 18, 2025 4:29 pm Post subject: Re: Diagnosis: Failed and blocked cat |
| silversync wrote: |
| He said they measured 2 lbs back pressure; don't have much experience with that test but evidently that was conclusive. |
mebbe but mebbe not. the tool company OTC that makes a backpressure gauge says anything above 1.25 psi at IDLE is abnormal but allow 3psi at 2500 rpm. so, questions:
- what rpm was the backpressure measured?
- what gauge did they use? what is the psi scale on the gauge?
these questions piss off the mechanics because it would question their diagnosis. tread carefully but they are perfectly valid questions as there are garages that are not always competent.
just putting a plug in where the O2 sensor was would not change the noise nor funky sounds but it COULD make the engine run better being in open loop mode. this means there is something else going on besides, or in addition to a plugged cat. _________________ -dan
www.thefixitworkshop.com |
E1 Samba Member
Joined: January 21, 2013 Posts: 8805 Location: Westfalia, Earth
Posted: Tue Nov 18, 2025 4:42 pm Post subject: Re: Diagnosis: Failed and blocked cat |
Sending you down the road with essentially a big exhaust leak is not confidence-inspiring. They at least should have reinstalled the O2, even if unwired.
Was the cat getting blazing hot while running poorly?
Did they take temperatures?
I don’t know what back pressure should be, but presume it’d be really low if running poorly — with a good cat or not. Meaning, I can’t help but to wonder if their diagnosis is exactly backwards.
When we had a cat go bad, if anything it was very quiet, not loud or having funky sounds, and as the best description it ran like it was constipated… or, Ahem, ran like it had 20 horsepower. _________________ If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
The caveman’s first question to the headhunter: “Hey, you got any coffee?” |
Posted: Tue Nov 18, 2025 5:02 pm Post subject: Re: Diagnosis: Failed and blocked cat |
i missed the part where they left the bung open... that's just wrong as it can be a fire hazard for your van. and of course all the funky noises are gone because you can't hear them anymore over the hole roar.
thread a new O2 sensor in the hole and connect it. you may find that it runs and drives well after that. you need one regardless if you replace the cat or not so no money lost. shop probably didn't send the old one with you. _________________ -dan
Posted: Tue Nov 18, 2025 6:50 pm Post subject: Re: Diagnosis: Failed and blocked cat |
My dead cat photo from an old thread.
| crazyvwvanman wrote: |
Put a used engine into my 87 daily driver a few months ago. Ran great, very strong, better than I expected given the history of the motor. A couple weeks ago it started to stumble under load. Got worse by the day until I had to stop driving it except very close to home. A couple days ago the engine stopped while I was a few blocks away. It restarted and I crept home at a few mph. I had a good idea what the problem was from the rattling it had begun making at idle when the problem first came up. Today I pulled the cat and when I saw the chunks way inside the muffler intake pipe I pulled the muffler too. This is what shook out of the muffler. About half of the cat guts are missing from the cat.
Mark |
zerotofifty Samba Member
Posted: Tue Nov 18, 2025 8:51 pm Post subject: Re: Diagnosis: Failed and blocked cat |
Besure to install a NEW O2 sensor with your NEW catalyst. A weak or what is known as a lazy O2 sensor (one that reacts slowly) will not give the most optimal mixture, and having a less than optimal mixture may harm your NEW and very expensive catalyst. Going forth, replace your O2 sensor on a regular basis in order to achieve longest catalyst life. A bad O2 sender can kill a good catalyst.
What others said about chunks of catalysts blocking the muffler is correct, so check the muffler too. If the catalyst has indeed failed and is falling apart, then replace it or hollow it out and inspect the muffler for blockage too.
Note a failing catalyst that causes a minor clog may continue to break up, and cause further clogs, thus in the interest of not becoming stranded do to a total blockage, it is good to remove the catalyst and either gut it out, or install a new good one. If new catalyst installed, get a new O2 sensor too unluss you know your current one is fresh and not "lazy" The O2 sensor is only a bout 1/10th the price of the catalyst, dont be penny wise and pound foolish with the O2 sensor and catalyst.
PS when you do get a new catalyst, hold on to the old broken one, bust out its guts so it flows clear, then keep it as an emergency part incase your new catalyst gets stolen, at least you will have a temporary fix until the stolen unit is replaced.
Good Luck!!!! _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
Posted: Tue Nov 18, 2025 9:17 pm Post subject: Re: Diagnosis: Failed and blocked cat |
| silversync wrote: |
I seem to remember installing the Cat around maybe 16-17 years ago. Does anyone know Cat failure rates? New CA Cat is showing $1,445.80 at Van Cafe (OMG). It will take some meditating to face that expense.  |
Magnaflow California Catalyst $1084 (free two day shipping!) see link below A good deal less expensive than Van Cafe (Van Cafe wants $25 shipping, and do to the higher sales price has near $30 in extra Calif sales tax more than Magnaflow)
I run the Magnaflow catalyst on my 1986 Van, very clean test results. High quality, stainless steel body, fitting for O2 sensor, perfect direct fit.
link...
https://www.magnaflow.com/products/3391918-magnafl...er-3391918
There I just saved you near $400, you're welcome!!!! Enjoy the savings.
$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ _________________ Sorry About That Chief.
Words to live by. |
kamzcab86 Samba Moderator
Posted: Tue Nov 18, 2025 10:10 pm Post subject: Re: Diagnosis: Failed and blocked cat |
I put a vacuum gauge on the intake earlier this year, which indicated a potential restriction in my 2.1. Removed the O2 sensor, which was fouled. Removed the cat converter... restricted without visible physical damage:
Instead of going to the hassle of destroying ^that, I simply installed a straight pipe and new O2 sensor until emissions time (which, fortunately, doesn't require the expensive CA cat).
Considering the OP's O2 sensor was left removed, I would guess that the back pressure test was performed at the O2 sensor bung. From what I've read, back pressure should not exceed 1.25 PSI at 2500 RPM. _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
do.dah Samba Member
Joined: August 27, 2015 Posts: 868 Location: Washington
Posted: Wed Nov 19, 2025 12:44 am Post subject: Re: Diagnosis: Failed and blocked cat |
| I would just love if somebody with a blocked cat, would try one of the 'spray into o2 bung' cat cleaners, to see if the stuff actually does work? Ya know, in the name of science? |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24434 Location: NYC/Upstate/ROW
Posted: Wed Nov 19, 2025 2:08 am Post subject: Re: Diagnosis: Failed and blocked cat |
| do.dah wrote: |
It won’t, if it’s developed significant back pressure like above. Skip the acetone and shellac on the Internet too, and get some new parts _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
do.dah Samba Member
Posted: Wed Nov 19, 2025 10:21 am Post subject: Re: Diagnosis: Failed and blocked cat |
So, you've tried it? Or, are you just being a squak box and repeating what someone told someone that knew someone' bother-in-law' father?
Or, you'd rather spend hundreds of $ on a new part, rather than a few $'s trying a 'fix' that may or may not work?
Conventional 'wisdom' says they don't work. Without having actually tried it.
Scientific wisdom, tries it several times and tries to qualify a statement.
Pulling and replacing a cat on a vanagon, ain't that hard.
If the cat is intact, why not try a commercial 'spray in' cat cleaner? Worst that can happen is ya spent a few $'s and a little bit 'O' time removing it and replacing it......
| Abscate wrote: |
| do.dah wrote: |
It won’t, if it’s developed significant back pressure like above. Skip the acetone and shellac on the Internet too, and get some new parts |
Posted: Wed Nov 19, 2025 10:52 am Post subject: Re: Diagnosis: Failed and blocked cat |
| do.dah wrote: |
| Abscate wrote: |
| do.dah wrote: |
I tried it on my plugged BMW cats but ,y sample size of one is meaning less. Just like all the rest of the internet drivel. Cats don’t just plug up, they over heat and melt the substrate. A cleaner won’t help with that. If it’s just dirty , a good hot run will do the trick _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
E1 Samba Member
Posted: Wed Nov 19, 2025 10:58 am Post subject: Re: Diagnosis: Failed and blocked cat |
Cats indeed plug up if running rich for too long. Fuel burns off but not entirely, and gas is a product of oil after all.
I’ve read very good things about Cataclean and would try it in a minute if:
— The cat was overheating
(meaning outlet temps are at least 200F above inlet)
— Visual inspection showed it to be intact
I well recall a banned poster here claiming NO additives worked, which included fuel injector cleaners, oil stop leaks, fuel driers, Blah Blah Blah.
Entire industries are rarely if ever built upon nothing, and blowing others’ money on possibly-unnecessary parts replacement isn’t helpful here. _________________ If ever twice as rich, we’re gettin’ a double-wide
Posted: Wed Nov 19, 2025 12:26 pm Post subject: Re: Diagnosis: Failed and blocked cat |
| do.dah wrote: |
If the cat is intact, why not try a commercial 'spray in' cat cleaner? Worst that can happen is ya spent a few $'s and a little bit 'O' time removing it and replacing it...... |
I love science, but I'm not willing to put a clogged cat converter back on my van just to see if a can of "snake oil" will work. While the job "ain't that hard" in the grand scheme of working on these rigs, it's not a job I care to do unless I have to, especially since my almost 40-year-old exhaust system requires sealant on that stupid J-pipe "donut".
The only spray-in cleaner I can find is this https://www.amazon.com/MotorPower-Care-Diesel-particulate-Cleaner/dp/B07FMB7K6W , and its primary function is for DPF cleaning, which, according to some reviews, it does work for that purpose. For cat converters, not so much, depending on how clogged the matrix is: https://www.amazon.com/gp/customer-reviews/R2TU68GKCBVOCY/ref=cm_cr_dp_d_rvw_ttl?ie=UTF8 . If the cat converter is in the beginning stages of restriction, I'd be apt to try the stuff. Given the size of the restriction in mine, it's too far gone to bother with. _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
Posted: Wed Nov 19, 2025 3:01 pm Post subject: Re: Diagnosis: Failed and blocked cat |
Thanks all for the comments, useful for figuring out where to go from here.
| E1 wrote: |
| ......., and as the best description it ran like it was constipated… or, Ahem, ran like it had 20 horsepower. |
Yes, I didn't think of the word, but that is what it ran like. Not sure how these fail, one day running fine, a few days later the problem appears without warning or without any specific indications.
| DanHoug wrote: |
Of course I don't know. And am sometimes hesitant to over-do the question/answer when I pick up a car. The techs can annoyed with that.
| DanHoug wrote: |
thread a new O2 sensor in the hole and connect it. you may find that it runs and drives well after that. you need one regardless if you replace the cat or not so no money lost. shop probably didn't send the old one with you. |
Yes, it is not ideal. I have to mentally put this in the category of us Vanagon owners improvise more often that we would like.
| zerotofifty wrote: |
| Going forth, replace your O2 sensor on a regular basis in order to achieve longest catalyst life. A bad O2 sender can kill a good catalyst |
Really good advice, I never thought of renewing the O2 sensor until it is needed to make it run right or pass smog.
Thank you, you guys are the best, that is a big difference. _________________ Roland: '89 Syncro, '02 911 C4S, '10 Audi A4 Avant |
E1 Samba Member
Posted: Wed Nov 19, 2025 3:31 pm Post subject: Re: Diagnosis: Failed and blocked cat |
Any good businessman should never take offense to questions like that.
Rather, they know their work is good, they know they’re honest and not everyone is, and they understand reputations are built on it.
In my hand-painted pinstriping and lettering days, I routinely got asked “Will this come off in a car wash?” I knew others stripers over-thinned their paint to pull longer lines, and it often came off or faded within a few years.
I learned by 19 that the best way to avoid fielding questions was to address these things without being asked. Sadly, the days of vendors acting like this have faded dramatically, but the good news is the best ones present themselves as such pretty quickly — if customers know what to look for. _________________ If ever twice as rich, we’re gettin’ a double-wide
