36hp Thermostat Assembly
RCJH77
RCJH77 is offline
PostPosted: Sat Nov 22, 2025 6:37 am    Post subject: 36hp Thermostat Assembly Reply with quote
I’m trying to install a thermostat assembly on my 36hp motor. The previous owner removed it and tossed most of the parts, so I’ve had to put it all together using info from this forum. I thought I had everything I need, but as I was mocking it all up last night, it seems something is not right. Hoping you all can help me identify the issue.
Here’s what I have and what it looked like when I set it up.
Notice the gap between the rod and the connecting arm that it needs to attach to. (I know the spring is missing. I have it, I was just trying to get a feel for how the rod passes through and attaches to the connecting arm.)
I’m no longer confident that I have the correct parts. Anyone know what I’’m missing, and if I’m not missing anything, what I’m doing wrong in the set up?
Ovally
Ovally is offline
PostPosted: Sat Nov 22, 2025 8:07 am    Post subject: Re: 36hp Thermostat Assembly Reply with quote
Here you see the thermostat assembly.
Regards.
VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S MFI 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018
RCJH77
RCJH77 is offline
PostPosted: Sat Nov 22, 2025 8:15 am    Post subject: Re: 36hp Thermostat Assembly Reply with quote
Right. I’ve seen those images. I do have the large piece that fits into the fan shroud as well. I forgot to include it in the picture. I also have the misc nuts and bolts.
The problem is this gap:
ppilotmike Premium Member
ppilotmike is offline
PostPosted: Sat Nov 22, 2025 8:51 am    Post subject: Re: 36hp Thermostat Assembly Reply with quote
great post! I can't wait to see the final answer to your question. Very Happy
Ovally
Ovally is offline
PostPosted: Sat Nov 22, 2025 9:03 am    Post subject: Re: 36hp Thermostat Assembly Reply with quote
I see, you need to remove the second rear bolt at the top of the engine. It's the one on the right, under the oil cooler in your photo, and that's where the rod needs to be mounted.
Regards.
VW Bug Oval 1953
VW Bug 1200 D motor
67rustavenger
67rustavenger is online now
PostPosted: Sat Nov 22, 2025 9:07 am    Post subject: Re: 36hp Thermostat Assembly Reply with quote
You have the cross bar mounted in the incorrect location in the above pic.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
RCJH77
RCJH77 is offline
PostPosted: Sat Nov 22, 2025 9:15 am    Post subject: Re: 36hp Thermostat Assembly Reply with quote
That is exactly what I was missing! Thanks, guys!
Eric&Barb
Eric&Barb is offline
PostPosted: Sat Nov 22, 2025 3:03 pm    Post subject: Re: 36hp Thermostat Assembly Reply with quote
That other hole you were using was only for hanging the engine from the overhead conveyor while on the assembly line.
In Stereo, Where Available!
RCJH77
RCJH77 is offline
PostPosted: Sat Nov 22, 2025 6:18 pm    Post subject: Re: 36hp Thermostat Assembly Reply with quote
I was wondering what it was for! Good to know.
Eric&Barb
PostPosted: Sat Nov 22, 2025 7:30 pm    Post subject: Re: 36hp Thermostat Assembly Reply with quote
Middle image shows the upper part of the hanger. Have yet to find an image showing up front of the fan shroud part of it.
tasb
The Distributor Distributor
tasb is offline
PostPosted: Sun Nov 23, 2025 12:10 am    Post subject: Re: 36hp Thermostat Assembly Reply with quote
That is an easy mistake to make. You might consider straightening the thermostat rod that passes through the head. In the shape it’s in it likely will bind against the fins of the head.
Roads Scholar
Member# 2059
PostPosted: Sun Nov 23, 2025 5:58 am    Post subject: Re: 36hp Thermostat Assembly Reply with quote
I love this forum, so much knowledge! Very Happy
