Oil Cooler/Heat Exchanger Seal
Igeo
Igeo is offline
PostPosted: Tue Nov 25, 2025 2:26 pm    Post subject: Oil Cooler/Heat Exchanger Seal Reply with quote
I keep seeing the recommendation to proactively change the rubber oil cooler seal with warnings describing sudden, dire, massive oil blow outs if I don't. Mine has unknown history but is dry in that area at 200K miles. I have the oil filter off and am circling around replacing it. Planning on using 10w-60 Castrol edge oil and a Mann Filter. Looks easy enough. Opinions welcome.
1987 Westfalia 2.1 WBX Manual
DanHoug
DanHoug is offline
PostPosted: Tue Nov 25, 2025 2:42 pm    Post subject: Re: Oil Cooler/Heat Exchanger Seal Reply with quote
absolutely change it. many times they don't give a 'slow leak' warning, they just split and puke.
-dan
www.thefixitworkshop.com
DigiMatrix
DigiMatrix is offline
PostPosted: Wed Nov 26, 2025 12:15 am    Post subject: Re: Oil Cooler/Heat Exchanger Seal Reply with quote
My vote is "yes change it!"
This is what mine looked like at approximately 190,000 kms. They usually blow on very cold days. I got lucky because I changed it knowing what they will do.
'91 Syncro Westfalia
soon to be 2.5 liter stroker WBX 10:1 comp
Digifant ECU with knock sensor and custom
cylinder selective knock control by me
dhaavers
dhaavers is offline
PostPosted: Wed Nov 26, 2025 6:38 am    Post subject: Re: Oil Cooler/Heat Exchanger Seal Reply with quote
DigiMatrix wrote:
…They usually blow on very cold days…
Agreed. Cold day, cold start…it’ll happen… Evil or Very Mad
- Dave
"The WonderVan"
Igeo
Igeo is offline
PostPosted: Wed Nov 26, 2025 6:57 am    Post subject: Re: Oil Cooler/Heat Exchanger Seal Reply with quote
OK OK I'll get on it. I would not have thought about it at all if it hadn't been for the post of the guy with the big pushrod tube leak. It's mentioned in that thread. Then the glow shift sandwhich adapter for my pressure sender came loose with the filter, revealing the nut holding the cooler being loose too. It's the universe telling me to change that o ring!
DanHoug
DanHoug is offline
PostPosted: Wed Nov 26, 2025 7:36 am    Post subject: Re: Oil Cooler/Heat Exchanger Seal Reply with quote
this was lousy "German Engineering"... the Japanese would never have employed an o-ring without captive retention. VW just squished the o-ring against a ramped bevel whereby 90psi of oil pressure can push outward and crack a brittle o-ring.
-dan
Igeo
Igeo is offline
PostPosted: Wed Nov 26, 2025 7:44 am    Post subject: Re: Oil Cooler/Heat Exchanger Seal Reply with quote
Would some anaerobic sealer like loctite 518 be a good dressing for the o ring?
zerotofifty
zerotofifty is offline
PostPosted: Wed Nov 26, 2025 10:48 am    Post subject: Re: Oil Cooler/Heat Exchanger Seal Reply with quote
Japan cars have many other issues, no nations cars are perfected.
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
zerotofifty
PostPosted: Wed Nov 26, 2025 10:52 am    Post subject: Re: Oil Cooler/Heat Exchanger Seal Reply with quote
That oil is very very thick, way beyond factory recommendation. Why you choose that for a moderate climate such as Oakland. I am across the Bay from you and use 20W 50 oil, and that is considered on the thicker end of recommended.
200k miles on a wasserboxer? that is on the high end, you must treat it well. is the oil your secret for longitivity? Wink
good to hear of an engine lasting long like yours! German engineering Laughing
Words to live by.
Wildthings
Wildthings is offline
PostPosted: Wed Nov 26, 2025 12:55 pm    Post subject: Re: Oil Cooler/Heat Exchanger Seal Reply with quote
Having had multiple oil cooler o-rings fail over the years and one of the small rubber coolant lines going to the cooler blow, when I put a 2.1L engine in my 83 1/2 I opted to remove the cooler and run without it. Note than the 1.9L did not have a cooler and did not have bottom end/lubrication problems. I run synthetic oil anyway so I figure oil wise I am still ahead of someone running a cooler and dino oil, while zero worry of losing more crankcase oil or coolant because of a dinky little cooler whose purpose is pretty questionable.
Wildthings
PostPosted: Wed Nov 26, 2025 1:02 pm    Post subject: Re: Oil Cooler/Heat Exchanger Seal Reply with quote
Sending more oil through the pressure relief just means the remaining oil going to the bearings ends of hotter. Thinner oil also helps the lifters pump up faster and often not leak down at all. 5w40 is a good go-to oil for these rigs if the bearings clearances are tight and has been my first choice for 25 years at this point in time.
With 5w40 in the crankcase my 83 1/2 sits for six months a year and the lifters are usually quiet when it is first fired up again.
Igeo
Igeo is offline
PostPosted: Wed Nov 26, 2025 1:55 pm    Post subject: Re: Oil Cooler/Heat Exchanger Seal Reply with quote
I have used 15w-40 diesel oil and 15w-50 Mobil 1. The engine has something like 210k miles and burns a quart of the Mobil 1 every 2,000 to 2,500 miles. Coolant stays at the same level always. No oil leaks whatsoever. Oil pressure on a hot day in the desert at 3,500 rpm can be in the mid to upper 30's psi. That's on the low side I realize, but it will give me 20 mpg and runs really well, so I want to take good care of it. I'll try the 10w-60 and see what affect, if any, it has on the oil pressure. I have the OEM VW o-ring on the way. Need to stare at the delivery pipe and how I'm gonna approach that to give me access to behind the heat exchanger. Coolant hoses are recent, so I think I'll try to back the pipe out. Maybe cut a slot in the end or jam an easy out in there?
SCM
SCM is offline
PostPosted: Wed Nov 26, 2025 2:09 pm    Post subject: Re: Oil Cooler/Heat Exchanger Seal Reply with quote
I forget the size you need but I believe you can buy two nuts to thread onto the exposed end of the pipe (in place of the filter,) tighten 'em against each other, then use an open-end wrench on the nut nearest the cooler to twist the pipe off. That way you have less chance of damaging the pipe compared to cutting it, etc.
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
zerotofifty
PostPosted: Wed Nov 26, 2025 3:43 pm    Post subject: Re: Oil Cooler/Heat Exchanger Seal Reply with quote
On my aircooled type IV I found that my oil was both cooler and gave more pressure when I used 15w 40 rather than thicker 20w 50.
The reason is that the thicker weight oil bypassed the oil cooler, the thinner oil did not bypass the cooler. I proved this with a thermocouple mounted on the oil cooler fins. the cooler stayed cold with the tick oil, but got hot with the thin oil, indicating the thicker oil did bypass the cooler! my sump,oil temp was much lower with the thinner oil, and pressure was higher than with the thick oil.
Of course a change in the cooler bypass relief spring should be able to allow high weight oil to not bypass the cooler.
Words to live by.
Igeo
Igeo is offline
PostPosted: Wed Nov 26, 2025 5:26 pm    Post subject: Re: Oil Cooler/Heat Exchanger Seal Reply with quote
Looks like someone has been in here before me. Are those tool marks on the inside of the pipe? I borrowed a pipe extractor from my neighbor and the 3/8 one fits rather sloppy, but it got the job done. As predicted by my wife, the seal looks pretty fresh. I'll replace it anyway.
DanHoug
DanHoug is offline
PostPosted: Wed Nov 26, 2025 5:43 pm    Post subject: Re: Oil Cooler/Heat Exchanger Seal Reply with quote
yahp, fairly fresh o-ring. but you didn't KNOW it was fresh! it's all about knowing the state of your van and pre-emptive maintenance. i lost a rear wheel bearing 1600 miles from home. when i got home, i pre-emptively replaced the side that didn't fail. it looked like it could've gone another 100k miles. you.just.don't.know, until you know.
my sister and brother-in-law.... they NEVER know, failures happen and it is karma/a sign/god's will. meh, just bad maintenance.
-dan
Igeo
Igeo is offline
PostPosted: Wed Nov 26, 2025 6:04 pm    Post subject: Re: Oil Cooler/Heat Exchanger Seal Reply with quote
True enough! It does play in to the old favorite line: "If it ain't broke, just give me a minute!"
Wildthings
PostPosted: Wed Nov 26, 2025 8:52 pm    Post subject: Re: Oil Cooler/Heat Exchanger Seal Reply with quote
I would replace the spring for the oil relief valve versus going with a heavier oil, at least for starters. As mentioned oil getting dumped back into the pan because it is being relieved by the pressure relief valve does you no good.
Wildthings
PostPosted: Wed Nov 26, 2025 9:03 pm    Post subject: Re: Oil Cooler/Heat Exchanger Seal Reply with quote
It is a 3/4 NF (3/4 x 16) thread, the same thread as a super common FL=1a filter and many others take. It is also possible to get a pair of channelock style pliers up between the cooler and the block and use them to turn the nipple.
Igeo
Igeo is offline
PostPosted: Wed Nov 26, 2025 10:04 pm    Post subject: Re: Oil Cooler/Heat Exchanger Seal Reply with quote
[quote="Wildthings"]
I shimmed that spring a couple of years ago. I did it pretty much knowing it wouldn't affect hot oil pressure. It didn't.
