Hebster52
Page: Previous  1, 2, 3 ... 11, 12, 13
Hebster52
Hebster52 is offline
PostPosted: Mon Sep 29, 2025 3:11 am    Post subject: Re: Hebster52 Reply with quote
The prototype I'm replicating was basically a -48 and it had kind of custom side trim and hood trim the fronthood trim was much longer than the factory split trim. So I decided to experiment some with 0,5mm aluminium sheet...
My DIY to the left and original to the right..
~Kris~
"The Hebster52" my Hebmuller replica build
The 912ST
The KidVRod project
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen, SOLD
Hebster52
PostPosted: Fri Nov 07, 2025 12:45 am    Post subject: Re: Hebster52 Reply with quote
Had a surgery in early October so not much happened here for a few weeks. Just some minor work on an idea to replicate the 1947-49 Philips Elomar radio front for covering a Bluetooth speaker behind it.
The past weekend I finally started welding the other front fender.
Also cut some filler pieces to backdate the front apron.
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Mon Nov 10, 2025 2:02 am    Post subject: Re: Hebster52 Reply with quote
Got the front apron backdated in the weekend.
Also started working on the replacement rear apron..
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Fri Nov 21, 2025 10:25 am    Post subject: Re: Hebster52 Reply with quote
Now the rear apron is done from the outside. Just need to fit and weld the inner bottom edge next...
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Mon Nov 24, 2025 10:33 pm    Post subject: Re: Hebster52 Reply with quote
Now the bottom is also welded.
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Sun Nov 30, 2025 5:56 am    Post subject: Re: Hebster52 Reply with quote
Yesterda I finally had the time to fully weld the other front fender!
The sparewheel well replacement panel was poorly shaped so I had to add some more lip to it so it would reach the front apron.....
Now all the parts to assemble the front are done!
~Kris~
The 912ST
The KidVRod project
VW_Jimbo Premium Member
VW_Jimbo is online now
PostPosted: Sat Dec 06, 2025 1:20 pm    Post subject: Re: Hebster52 Reply with quote
Nice job on the fender and spare tire floor reworks! I had the same job on my 54 a few years back. Once I welded that extension in, I had to reshape the piece, as the stamping was far from where I wanted it. I had a blast working it into its new shape!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
Hebster52
PostPosted: Sat Dec 06, 2025 2:13 pm    Post subject: Re: Hebster52 Reply with quote
Thanks.
Digged out the one metal pre-49 glove box I made 23 years ago to finally make the other one...
Unfortunately the first had gathered a bit of "patina" during the years in storage as seen here with the now newly made bottom section for the second box...
Both halves ready to be welded on the new box..
Yesterday I finished the second and cleaned up the first!
And confirmed the fitment in the dash.
Really happy with the final pair!
~Kris~
The 912ST
The KidVRod project
Teeroy Premium Member
Teeroy is offline
PostPosted: Sun Dec 14, 2025 2:39 pm    Post subject: Re: Hebster52 Reply with quote
Those came out great. Originally do they weld in place or attach with screws?
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
Jacks
Jacks is offline
PostPosted: Mon Dec 15, 2025 12:49 am    Post subject: Re: Hebster52 Reply with quote
I think your trim strips look marvelous
Jack Staggs
Actual name
finster
finster is offline
PostPosted: Mon Dec 15, 2025 4:50 am    Post subject: Re: Hebster52 Reply with quote
welded in, but for ease of access to the speedo etc many replacements are screwed in
Hebster52
PostPosted: Mon Dec 15, 2025 6:08 am    Post subject: Re: Hebster52 Reply with quote
Thanks!
Yes. They are originally welded.
~Kris~
The 912ST
The KidVRod project
Hebster52
PostPosted: Sat Dec 20, 2025 9:31 am    Post subject: Re: Hebster52 Reply with quote
Now the floor quarter panels are becoming floor halves. Still just tacked together for now but getting welded soon.
Also cut out the incorrect rear apron and started fitting the correct apron instead.
~Kris~
The 912ST
The KidVRod project
Page 13 of 13
