So it begins
Page: Previous  1, 2, 3 ... 32, 33, 34
bruceo98
bruceo98 is offline
PostPosted: Sun Dec 07, 2025 12:13 pm    Post subject: Re: So it begins Reply with quote
I put the ecm where the wires didn’t have to be cut or lengthened to the motor.
I may not be the best, but when the top 10 get together, they all talk about me.
bruceo98
bruceo98 is offline
PostPosted: Mon Dec 08, 2025 5:30 pm    Post subject: Re: So it begins Reply with quote
I know it doesn’t look like much done but I cut and lengthened 21 wires . lol
DUNGBTL Premium Member
DUNGBTL is offline
PostPosted: Mon Dec 08, 2025 5:33 pm    Post subject: Re: So it begins Reply with quote
Very Happy
Little by little…progress!
J.
bruceo98
bruceo98 is offline
PostPosted: Tue Dec 09, 2025 5:16 pm    Post subject: Re: So it begins Reply with quote
21 wires to the column lengthened , 17 more to go. 38 wires just to the steering column. Only 100s more to go . Arggg. Did I ever say I hate wiring?
Root_Werks
Root_Werks is offline
PostPosted: Tue Dec 09, 2025 6:58 pm    Post subject: Re: So it begins Reply with quote
The wiring is really impressive! Keeping things clean takes time.
When I set my timing, why do I flush, then take a pee?
bruceo98
bruceo98 is offline
PostPosted: Tue Dec 09, 2025 7:07 pm    Post subject: Re: So it begins Reply with quote
Thanks . Right now this is just roughed in. Trying to get the wiring ran and the right length. Once I have that, I can start tidying it up and Wrap then . I want to get them where they go and check to make sure everything works before I finish them up .
bruceo98
bruceo98 is offline
PostPosted: Fri Dec 12, 2025 1:23 pm    Post subject: Re: So it begins Reply with quote
I'm thinking of changing the wheel/tire combo out. I want 17s BRMs . 195/40s on the front and 215/45 or 50s on the rear. guess more wasted money on the old wheels and tires.
Anyone need a set of chrome 911 replicas 4.5 front. 5.5 rear. tires go with them 215/65/15 rears 155/60 fronts. 205x5 lug pattern. also have a couple other size rear tires .never used.
bruceo98
bruceo98 is offline
PostPosted: Sat Dec 13, 2025 2:21 pm    Post subject: Re: So it begins Reply with quote
Ok , the steering column is wired and done . Yay. I put the covers on it and it fits good . Next is extending the wires for the ac high pressure switch fuel pump/tank and lights and horn that runs to the front. Starting to see some light . lol I’m going to have to make some sort of cover for the wires running down the column . Not sure what I can use , maybe some black pvc pipe cut in half .
bruceo98
bruceo98 is offline
PostPosted: Tue Dec 23, 2025 8:57 pm    Post subject: Re: So it begins Reply with quote
Well all the wires to the front, (headlights,horns,fuel tank and pumps, gauges, Ambient temperature sensor ,ac controls and steering column) are ran,just have to test them before I wrap em up . Now I have to do the clock, and light dimmer switch in the console I’m going to make.
Made 3 years this month since I started this project. Time flies when you’re having fun.
BMFBMF
BMFBMF is offline
PostPosted: Wed Dec 24, 2025 12:57 am    Post subject: Re: So it begins Reply with quote
She's going to turn some heads, and be quite exciting to ride !
That bare metal that I see around the dash, are you going to have to take things out to finish painting?
Enjoy your Christmas at home, wish I wasn't away at the in-laws. And could work on my beetle!!!
-----Slava Ukraini-----
1971 Stock South African Beetle 1300 : My mom's european "Thin Chick" spec. Completely stock with torsion bar front, swingaxle rear, smooth hubs, single MC, 40 mm shoes, 31PICT3 carb and 5 bolt drums all round, currently Running a 1976 SF:AS engine with the original SF:AD engine overhauled in a box, waiting to go back in one day.
bruceo98
bruceo98 is offline
PostPosted: Wed Dec 24, 2025 5:29 am    Post subject: Re: So it begins Reply with quote
Yes, everything will come out to paint it. Body isn’t bolted down so it will come off to paint also. That's primer you're seeing on the dash.
Thanks and have a Merry Christmas also. And to all the members of Samba .be safe and enjoy the holidays.
Page 34 of 34
