volkaholic1 Samba Member
Posted: Sat Dec 27, 2025 11:13 am Post subject: questions about #2 & #4 lower rear air deflectors |
just trying to find out what years the uncommon versions are from
in the pic, the center is what i call the "typical" #4 and #2 lower rear air deflectors.
the #4 in the upper left has a hole in it, i know that is for running the small paper hose up to the air cleaner, but what years did it come on?
the #2 in the lower right is a mirror image of the #4, what years did that come on?
i can buy the typical parts from VW mexico, but does anyone make the others new? _________________ Volkaholic |
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1245 Location: San Angelo, Texas
Posted: Sat Dec 27, 2025 2:06 pm Post subject: Re: questions about #2 & #4 lower rear air deflectors |
I'm going to say the number 4, left is off of a '67.....'67's had a twin snorkle on the air cleaner.......I you want one with a hole in it, just put a hole in it. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
Posted: Sat Dec 27, 2025 3:56 pm Post subject: Re: questions about #2 & #4 lower rear air deflectors |
so that is a 1 year only part, good to know _________________ Volkaholic |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 1055 Location: Eastern north carolina
Posted: Sun Dec 28, 2025 6:27 am Post subject: Re: questions about #2 & #4 lower rear air deflectors |
| I think the 68 air cleaner also used that one on the left side.i will look at a 68 air cleaner today and correct my post if I am wrong. |
diablosandwich Samba Member
Joined: January 15, 2012 Posts: 530 Location: Illinois
Posted: Sun Dec 28, 2025 7:21 am Post subject: Re: questions about #2 & #4 lower rear air deflectors |
The #4 with hole for left side was on 40hp and 1300 too. I am not sure if it was only on fresh air 40hp or not though.
Casey _________________ 2 1966 Java Greens and a 65 Sea Blue that is green |
john7 Samba Member
Joined: August 06, 2003 Posts: 1567 Location: Garden grove ca
Posted: Sat Jan 03, 2026 9:20 am Post subject: Re: questions about #2 & #4 lower rear air deflectors |
Top left is 65-67
The one you don’t have is the right side 67 only version with the hole _________________ Jesus Saves
Slot Mag King!
I accept Paypal, CASH, GOLD, SILVER, COINS, GUNS & money orders. |
Posted: Sat Jan 03, 2026 9:41 am Post subject: Re: questions about #2 & #4 lower rear air deflectors |
i am starting to wonder if the lower right is VW Mexico or VW Brazil _________________ Volkaholic |
Teeroy  Samba Member
Joined: April 20, 2003 Posts: 3912 Location: Eastern WA
Posted: Sat Jan 03, 2026 12:17 pm Post subject: Re: questions about #2 & #4 lower rear air deflectors |
I think upper left and lower right are off 1500 bus. 67 beetle also would use upper left, 40hp looks similar but would be shorter end to end. I put lower right style on my dual carb engines without preheat to even the airflow _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
