Greasing front bearings
BMFBMF
BMFBMF is offline
PostPosted: Sat Jan 03, 2026 10:53 pm    Post subject: Greasing front bearings Reply with quote
Hi Folks, there is a large "donut" shaped depression in the drum in between the two bearing races.
When I too the drum of it was full of grease , up to the level of the bearing rollers roughly. I guess in the mists of time I must have thought of that as a sort of "grease reservoir" for the bearings.
What do you guys do. Just grease the bearings?
I've seen photos of the whole cavity full of grease on the other hand.
cheers
BMF
-----Slava Ukraini-----
1971 Stock South African Beetle 1300 : My mom's european "Thin Chick" spec. Completely stock with torsion bar front, swingaxle rear, smooth hubs, single MC, 40 mm shoes, 31PICT3 carb and 5 bolt drums all round, currently Running a 1976 SF:AS engine with the original SF:AD engine overhauled in a box, waiting to go back in one day.
passionre
passionre is offline
PostPosted: Sun Jan 04, 2026 3:55 am    Post subject: Re: Greasing front bearings Reply with quote
The grease cavity should be approx. 75 percent full of new grease. It is at least as important to clean/replace and repack the bearings themselves properly.
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Sun Jan 04, 2026 4:57 am    Post subject: Re: Greasing front bearings Reply with quote
I have always greased the bearing, installed the drum, filled the cavity with grease, pressed the bearing in place which squeezes some grease out, tightened nut or pinch bolt, and done.
runamoc Premium Member
runamoc is offline
PostPosted: Sun Jan 04, 2026 9:03 am    Post subject: Re: Greasing front bearings Reply with quote
For the grease to 'move' from this reservoir to the bearing the bearings would have to get as hot as the melting temp. of the grease.....I don't think so. Cool
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
