fredybear Samba Member
Posted: Mon Mar 03, 2025 2:05 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
Everything gets sooooo much more fun when your close. Why
Picking and Piddling Till Paint. Ready
Before
After, well almost
The channel
I wasent, I was, I wasent, I was, well its all gotta be fresh
Next Up  _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Wed Mar 05, 2025 10:01 am Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
OOOOOO La La, Dat Booty Be Tight. Make me wanna rub up against it, git me alittle sum
Another coat of poly for superior flatness.
Still gotta work on the flare and bus nipple for perfection.
Hours of sanding, than back to the other side  _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
dumptuck Samba Member
Posted: Wed Mar 05, 2025 10:07 am Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
What colour are you gonna go? Back to yellow or something new? Or do we have to wait and see _________________ Erik |
StanDahl Samba Member
Joined: August 25, 2024 Posts: 107 Location: Orange Co. SoCal
Posted: Thu Mar 06, 2025 3:37 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
I just went through all nine pages and at first thought you were just trying to make it useable. Some of those pieces were so crumpled that I figured you'd be cutting out chunks and welding in donor parts, but as the process went on I realized you're going for body work perfection! This is inspiring! _________________ John...in a 1969 Bus, morphing into a tintop weekender |
Posted: Mon Mar 10, 2025 9:13 am Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
| StanDahl wrote: |
| I just went through all nine pages and at first thought you were just trying to make it useable. Some of those pieces were so crumpled that I figured you'd be cutting out chunks and welding in donor parts, but as the process went on I realized you're going for body work perfection! This is inspiring! |
Thanks, Im still perfecting, still, still and still again, it can be done. I like original, so coulda got 2 new doors and made my life easier, but, what fun it that.
Before again
Gotta perfect that flare,
After again
Door
Roof abuse, sanding, sanding and more sanding, wasn't just that little sanding block, cause that would be insane
| Quote: |
dumptuck
PostPosted: Wed Mar 05, 2025 9:07 am Post subject: Re: 1971 VW Bus Resto. The BoHo Bus
What colour are you gonna go? Back to yellow or something new? Very Happy Or do we have to wait and see |
Original, its original yellow/orange underneath and engine compartment, so cant change color unless everything was blasted clean.  _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Fri Mar 21, 2025 1:21 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
How bout a Sneek Peek,
Um or maybe Ill quit and take up Birding.
Rare Bird Alert, OMG help
Some filler to perfect it
almost,
Poly Prime
Next up, wait and see or,um,and, ooooo-um  _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Wed Apr 02, 2025 1:19 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
J U I C Y Look at Dat Flesh, i mean metal...
Urethaning First the Poly
Need some more perfecting. Look at those Lines...... OOOOyEaH
Help Help , Painful
The last corner, ooooyea  _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Mon Apr 07, 2025 9:26 am Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
My flares must be perfect so lets destroy everything
I think is was a half inch in so, pressurize and crack ouch
I will reperfect this
Next Up ???  _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Tue Apr 22, 2025 8:19 am Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
Look at dat flare, Sweetness Perfecting the alignment of everything
Before
What a pain to put that hatch on by yourself
After
Perfecting the hatch
Blew up the puter, now back on win7 on old puter.
Install win 98 to format, add winXP, than win7 32 bit, woops, the editor dont run on 32 redo and put in win 7 64 bit. Hours to do this. I made it back. and guess what. The Samba worked fine on IE 8 Nothing else would work, who new. Now im on Firefox till that expires  _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Mon Apr 28, 2025 9:11 am Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
Pickin & Piddlin
Before
After
The Flare, DoUCareaboutmyFlare
Lookin good
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Fri May 09, 2025 8:08 am Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
One last look before paint
20 ozs of roll on primer for the roof.
How bout roll on some $400 qt paint, spray it, mix it up.
Quit and do something else  _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Thu Jun 19, 2025 8:19 am Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
See if I can cool it enough to paint in here
Lets flatten some original door panels. Beautiful originals
How many months to get em perfectly flat
Got me a flow goin  _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Thu Dec 25, 2025 4:17 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
All I want for Christmas is a painted Bus, a painted Bus. Sing with me
Sanded for hours, fresh prime than paint
Ready
2 -4 -1 special. I will do both at the same time. Ready
OBoy  _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Wed Dec 31, 2025 9:23 am Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
How to paint a roof
Took a few to figure out.
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Buggeee  Samba Member
Joined: December 22, 2016 Posts: 5057 Location: Stuck in Ohio
Posted: Wed Jan 07, 2026 1:18 pm Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
| Buggeee wrote: |
| Be careful up there Freddy! The Bus is looking great!!! |
Thanks, Ready for some joy
The 2 tun tank gets some paint.
He did not, he did, he rolled on Glasurit Single Stage, No Way, WAY
Primer, finally made it perfect
Than, O-NOOOOOO Whats that called
Look Close, OOOOO-NOOOOOOOooooo
First half and second, what a difference, I learn
8ozs paint, 3/4 slow, 1/4 fast 20% reducer.
First half was goin smooth, the tried to use the rest up and put it on heavier. OOOOOoooooNNNNoooooooo, Woops
Tryin stuff out is fun, waste money, thats like $100 right there. YUK
All slow, 5% reducer and real thin layer and it should flow out quite nice,
Should I try again after sanding my mess?????? or spray, would of been done if I had a brain, BUT
Camera spots  _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Tue Jan 13, 2026 9:43 am Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
I shall try again cause im Tupid ubet
BUT, i will have a really expensive base coat.
Sanding 3 hours to clean the mess
another coat, no reducer, 2ozs paint, roll real thin, 65 degree bus
see through
sand again, wet sant 400 grit, aaahhhh dust free sanding
again, 75 degree bus roof, no difference
Its gray, my pastel dont match, boo, not happy
i forgot what pics are what, BUT, i will have a beautiful, expensive base coat.
5% reducer and it will be 80degrees tomorrow, try again
Enough coats and I could probably color sand and buff it to perfection.
Help  _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
Posted: Wed Jan 14, 2026 10:02 am Post subject: Re: 1971 VW Bus Resto. The BoHo Bus |
| Buggeee wrote: |
I tried to bury a mess by going HEAVY with epoxy primer once, and once was enough! Lesson learned. What a mess I had.
Keep on it Freddy Bear  |
I failed
But, now on to color issues
Round 2 on the big side. 85 degree roof
3ozs 5% reducer, 85 degree roof, not bad
90D issues, im not happy, roof looks yellow, gray, anything but white
gonna color match the rear hatch and see what come close. Help, im goin wacko
2 weeks, 3 weeks, to paint a roof, help me, someone, anyone  _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
