whats a bowden tube???
flat4freak1978
flat4freak1978 is offline
PostPosted: Mon Oct 06, 2003 9:11 am    Post subject: whats a bowden tube??? Reply with quote
and what does it do?
1978 bus. 2.0 f.i. manual trans. "the great gonzo"
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Mon Oct 06, 2003 9:15 am    Post subject: Reply with quote
It is the flexible tube which the clutch cable runs through, as it exits the conduit from the front/ chasis and connects to the transaxle.
it keeps tension on the cable. if not adjusted with the right amount of " bend" to it the clutch/ trans will " judder" on take off in first or reverse
there are several threads in relation to it going on in a couple of the forums
flat4freak1978
PostPosted: Mon Oct 06, 2003 9:21 am    Post subject: Reply with quote
can they go bad?? would they cause the clutch to slip? thanks for any help in advance.
ratwell
ratwell is offline
PostPosted: Mon Oct 06, 2003 9:49 am    Post subject: Reply with quote
Same principal as the bicycle brake cable which is named after Bowden the inventor.
'78 Westfalia CDN
'76 Doublecab Sweden
Read the Baywindow FAQ
keifernet
PostPosted: Mon Oct 06, 2003 10:08 am    Post subject: Reply with quote
slipping clutch is most likely caused by
oil on the disc/ flywheel due to bad main seal
weak pressure plate
over adjusted clutch causing pressure plate not to disengage disc fully
an oddity that will give similar symptoms is a " spun" rear brake drum...
when big nut holding the drum on is loose over a period of time the splines in the drum get worn out by the hard steel of the stub axle....
but as I said that is not that common.
ratwell
ratwell is offline
PostPosted: Mon Oct 06, 2003 6:13 pm    Post subject: Reply with quote
Whatever you do, don't pay more than $1.25 for a pack of 5. Wink
'78 Westfalia CDN
flat4freak1978
PostPosted: Wed Oct 08, 2003 4:21 pm    Post subject: Reply with quote
lol
Laughing
