Source for original tar boards
Page: Previous  1, 2, 3  Next
Kelly
Kelly is offline
PostPosted: Thu Dec 29, 2005 11:08 pm    Post subject: Re: Source for original tar boards Reply with quote
Is there a source for the original-style rear deck tar boards?
I'd ready to redo that area and would prefer to use something that looks original. Otherwise I'll go with some dynamat equivalent.
The tar stuff appears to be 3/16" inch thick.
Example (not my Bus):
I recently parted out a '69 that had perfect tar boards under the rear mat. They still feel new. I used a scraper to take them off without a hitch. If there's any bays at the junkyard take a look there. I saved all of them to use on my bus.
It's not how wide your hatch is, it's what you do with it.
Eriba Puck Sticky
crofty
Judas of the North
crofty is offline
PostPosted: Thu Dec 29, 2005 11:55 pm    Post subject: Reply with quote
They are for Standards and Deluxes.
They also used additional strips behind the seat divider interior panels and drink tray.
My 62 Flipseat has 'em too and I'd guess that SO23's might as well.
HamburgerBrad wrote:
Mr. Bubblehead
El Chupa Nibre
Mr. Bubblehead is offline
PostPosted: Fri Dec 30, 2005 4:54 am    Post subject: Reply with quote
Yustrn wrote:
my65vert wrote:
All I know is the whole inside of the fukr is coated with some tar shit that is taking me forever to get out. It's like they put the tar stuff down then laid insulation on it before it dried and it's a hell of a mess to get off.
Go down to Kragen Autoparts, near the bondo will be Marhyde brand paint remove or aircraft stripper buy it , put it on there, let it soak, put on some more and then scrape your stuff right off, this stuff is the cat's meow when it comes to removers, but make sure you buy the MARHYDE brand and nothing else, the rest is junk
Acetone will melt that shit, too. Makes a big damn mess.
OGST
Samba Member #4862
doveblue3
doveblue3 is offline
PostPosted: Fri Dec 30, 2005 7:26 am    Post subject: Reply with quote
I called the MBZ dealer here, they were $27 each and they didn't have any in stock so I couldn't get dimensions.
My local Home Depot only sells the new closed cell foam expansion joints now but I found some online pics of the old ashphalt based strips and it looks promising. Thanks doveblue3.
The Home Depot stuff actually looked pretty good at $12 for a 50' x 4" roll.
thats strange that they didnt have the asphaltic stuff. i just bought some last month when i poured my driveway. i did buy it at lowes though, not home despot.
Karl
Karl is offline
PostPosted: Fri Dec 30, 2005 11:49 am    Post subject: Reply with quote
The dealer that wants $27 is raping you. True list is $14.50!
They measure about 18" x 5".
I can supply as many as you want for $10.50 each + postage.
PostPosted: Fri Dec 30, 2005 3:06 pm    Post subject: Reply with quote
Thanks for checking. Phoenix sucks, both MB dealers were $27.
What's the thickness?
The strips are primarily 2.5" wide. You need 16 4' x 2.5" strips, which comes out to 24 sheets. Damn...
Lowe's has the asphalt expansion joints. They are asphalt-covered pressboard(?) as opposed to asphalt-impregnated so they break if bent. Cheap though, only $1.26 each.
Karl
Karl is offline
PostPosted: Mon Jan 02, 2006 4:15 pm    Post subject: Reply with quote
PM me your address...... I have something for you.
Walk Thru KO
Walk Thru KO is offline
PostPosted: Tue Jan 03, 2006 12:13 pm    Post subject: Reply with quote
Does this MB part # work? What is the thickness? Anything out there any cheaper?
iamdonquixote
iamdonquixote is offline
PostPosted: Tue Jan 03, 2006 1:44 pm    Post subject: Reply with quote
for what its worth, I plan on masking off the raised ribs and spraying rubber undercoating on. From a distance it will look like felt and provide a similiar sound deadening...
marklaken
marklaken is offline
PostPosted: Tue Jan 03, 2006 3:18 pm    Post subject: Reply with quote
my floor was covered in tar - the aircraft stripper was slow, sloppy and very stinky at removing it - had much better luck with a heat gun and a 2"scrapper - i ended up marring the floor pretty good so i then did a quick aircraft strip of the paint and applied masterseries CT:
during:
after:
Wish List:
1967 Wesfalia SO-42 Parts Needed: Kitchenette, Cot Poles
'65 rear left beetle fender
15" Bus Wheels in fair condition
Mark Laken
Fort Collins, CO
localboy
Samba Longboarder
localboy is offline
PostPosted: Tue Jan 03, 2006 6:00 pm    Post subject: Reply with quote
Sorry for the hi-jack. BUT...Mark How did you like the Masterseries stuff? Getting my Notch back from paint soon and need to coat inside the doors, roof etc prior to interior install. Tried both Rust Bullet and POR 15 before. Neutral POR covered better in one coat but can't be painted...
One man's "patina" is another man's cancer...
Black '65 Resto-Custom S Notch 2110 cc powered
original paint Pearl White '66 Westy SO-42
Allstate single-wheel trailer project
j.pickens
j.pickens is offline
PostPosted: Tue Jan 03, 2006 9:30 pm    Post subject: Reply with quote
I thought the padding looked more like tar-impregnated felt to me.
You can get raw wool felt from McMaster-Carr.
Here's a link:
McMaster-Carr Link
I would guess you'd need the 1/4" or 3/8" thickness. You want the stuff to fill in the valleys so that a carpet or cargo floor card will lay flat, but press down slightly on the padding to absorb noise.
The 3/8" thickness in a 12" by 60" sheet, part #8756K14, is $45.
Let us know what you decide to use.
I also see they sell a felt sample kit with all their felts for $4.50 so you can check out which grade would match best.
BeaterBarndoor wrote:
Red Fau Veh wrote:
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Tue Jan 03, 2006 10:30 pm    Post subject: Reply with quote
If you really aren't concerned by looks TMI sisal padding would work perfect, paint it black and who would know. a 3 foot by 6 foot piece is around 13 dollars (all approx). I can show you it a BBB. My 63 flip seat had the srips in the back. I carefully removed a nice set from a donor bus out back Wink
"no more hacking my sig line"
npbusguy
npbusguy is offline
PostPosted: Wed Mar 11, 2009 9:17 pm    Post subject: Reply with quote
Any updates on the MB tar strips mentioned in this thread? How did they look and fit?
How about other original looking materials that people have used recently?
Thanks,
Neil
npbusguy
npbusguy is offline
PostPosted: Fri Aug 21, 2009 11:35 am    Post subject: Reply with quote
Bump...
Any photos of the Mercedes deadening material?
I am at the point that I need to lay down some tar impregnated felt strips.
PostPosted: Fri Aug 21, 2009 4:57 pm    Post subject: Reply with quote
They don't look the same as originals
npbusguy
npbusguy is offline
PostPosted: Fri Aug 21, 2009 6:58 pm    Post subject: Reply with quote
Thanks Everett, that s helpful.
I think I need to find a bus in the midwest and try to salvage some orginal tar strips
DanM
DanM is offline
PostPosted: Fri Feb 26, 2010 7:29 am    Post subject: Reply with quote
I'm on the hunt for original tar strips but considered the Mercedes stuff, since it looks decent in Everett's pics. Unfortunately, I just called my local Mercedes dealer and they quoted me $40 for one sheet!
drive it. break it. fix it. repeat.
SkooobaSteve
SkooobaSteve is offline
PostPosted: Fri Feb 26, 2010 8:03 am    Post subject: Reply with quote
Inflation at its finest..
Jonathan
Romans 6:13
WTB 67 beetle rear seat belts.
59 Euro ragtop build with my dad
http://www.thesamba.com/vw/forum/viewtopic.php?t=493553&postdays=0&postorder=asc&start=0
65 dlx Slow build
http://www.thesamba.com/vw/forum/viewtopic.php?t=391061
SkooobaSteve
PostPosted: Fri Feb 26, 2010 8:05 am    Post subject: Reply with quote
On a side not call a diff dealer list is only 32.50 at the dealer so they are doing little bit of a mark up on ya. If your a shop you can get it for 27 bucks. Still its going up just like everything else.
Jonathan
Romans 6:13
65 dlx Slow build
Page 2 of 3
