johnshenry Samba Member
Joined: September 21, 2001 Posts: 9416 Location: Northwood, NH USA
Posted: Mon Feb 06, 2006 9:10 pm Post subject: Zarwerks shop spy cam .... |
{EDIT: With the permission of the site administrator, I have chosen to use this thread to show various techniques and methods I use in my shop on an ongoing basis, such that others might be able to benefit and possibly use them as well. This is not intended to promote or showcase any of my Zarwerks products and no business will be discussed here. I can be reached via e-mail at [email protected]
- John H }
_________________ John Henry
'57 Deluxe
'56 Single Cab
buggen Samba Member
Posted: Mon Feb 06, 2006 10:23 pm Post subject: |
| Cool, would that be the 53 only manifold that I need for my vert? |
VDubMattStuart Samba Member
Joined: July 10, 2005 Posts: 273 Location: Lincoln, CA
Posted: Mon Feb 06, 2006 11:54 pm Post subject: |
Or would it be the one that I need for my hard top?  _________________ 53 oval hardtop |
Posted: Tue Feb 07, 2006 7:23 am Post subject: |
Could be. I'll be making 3-4 of them this pass.
Can anybody who has on original (Bob, Dave?) tell me what markings they have on the jacket. The original one I have (seen behind) is a 36hp one built for a 28mm carb. I know that the original "zwitter" ones were for 25hp, wondering what they had for logos, markings, etc. on the jacket.
Also, the original one I have has the "grooved" jacket, to the 25hp versions have those? I could pretty easily file that into my repros.... _________________ John Henry
'57 Deluxe
'56 Single Cab |
53 0val Samba Professor
Joined: July 03, 2003 Posts: 11396 Location: Irvine, CA
Posted: Tue Feb 07, 2006 7:33 am Post subject: |
I'll look for you tonight John........I don't remember any.  _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Tue Feb 07, 2006 7:36 am Post subject: |
Thanks Bob. You might need to use a mirror, the later ones (36hp) were embossed on the back of the jacket.
Or you could justpull the intake and send it to me for inspection  _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Tue Feb 07, 2006 8:59 am Post subject: |
| johnshenry wrote: |
Or you could justpull the intake and send it to me for inspection  |
I'll try the mirror.  _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
buggen Samba Member
Posted: Tue Feb 07, 2006 10:29 am Post subject: |
| johnshenry wrote: |
Also, the original one I have has the "grooved" jacket, to the 25hp versions have those? I could pretty easily file that into my repros.... |
My 53 is a 25 horse but it has an accelerator pump carb, is that correct? Or should it have the non-accelerator pump carbs like the split bugs? |
Posted: Tue Feb 07, 2006 10:59 am Post subject: |
I believe it to be with the pump. I have a 28pci carb on my car and a while back had it critiqued by Bob. He said it was correct or 'fine'. (fine means good with his high standards ) _________________ 53 oval hardtop |
Posted: Tue Feb 07, 2006 1:06 pm Post subject: |
| buggen wrote: |
| johnshenry wrote: |
The pump is correct. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Tue Feb 07, 2006 2:09 pm Post subject: |
| Quote: |
Interesting. Because this is a "transitional" intake. I believe it came after the 36hp style looking one, that had 25hp endcastings and 26mm carb flange (no flare on the carb riser tube just under the flange, ID of the flange is 26mm). So it (the "'53 Only" one) for a 25hp engine, but with a 28mm (accel pump carb, flared riser) .
The one that came after it was the "701E" 36hp intake.
While the heat riser that came on the 25hp/26mm intake and "701E" intakes was basically the same shape, the tubing is of a different diameter. The tubing on the 701E is thicker, and greater wall thickness.
The heat riser on the "original" one I have seen in the pic is thin, however the end castings are for 36hp, not 25. Go figure.
I'm going to make up a table that explains all the changes, and post it at the Zarwerks site. I'll have you guys review it, hopefully you are not too shy to point out anything that mightbe incorrect.......
'57 Deluxe
'56 Single Cab |
Posted: Tue Feb 07, 2006 5:57 pm Post subject: |
| johnshenry wrote: |
There doesn't seem to be anything there.....I used the mirror and felt along with my fingers where I could and NOTHING. No part number or VW stamp embossed; at least, none I could note. The "groove" between the two pipes is more pronouced through the jacket.....unlike the 36 that doesn't have much definition at all. I have a 36 and it is not the same. Even on the front, the jacket defines the two pipes and does not obscure them at all; almost like a wet towel would show the shape of the two different pipes. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Tue Feb 07, 2006 6:00 pm Post subject: Re: Zarwerks shop spy cam .... |
Looking at your picture again......the one in the back shows the distinction between the two pipes through the jacket. Is that a real one? Because it really looks correct.  _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Tue Feb 07, 2006 6:03 pm Post subject: |
| johnshenry wrote: |
Can anybody who has on original (Bob, Dave?) tell\0\05{\0\0\0\0\0\0\0\0hey have on the jacket. The original one I have (seen behind) is a 36hp one built for a 28mm carb. I know that the original "zwitter" ones were for 25hp, wondering what they had for logos, markings, etc. on the jacket.
Now I see what you mean.......mine looks just that.....at least from the front. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Tue Feb 07, 2006 6:12 pm Post subject: |
Thanks Bob.
I actually have a 36hp one ("701E") with that pronounced groove, and I started to use it to make the '53 one, then go figure, I find a crack in the jacket on the back! Doesn't that suck!
I could actually file the groove in and after a bead blast, it would look pretty good.
So, Bob, you said you have the groove, no numbers or logos that you can feel.
And your engine is 25hp right?
And do you have a 28mm carb flange with the flare under it?
Thanks, I'm trying to get as much info as I can.
Dave Haviland, if you are reading, you have one of these too, what does yours have???
Thanks... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Wed Feb 08, 2006 3:26 pm Post subject: |
| johnshenry wrote: |
Thanks Bob.
Thanks... |
That's the way I see it John. Pronounced grove, no markings, 25hp, 28mm carb flange with slight flare. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Wed Feb 08, 2006 8:28 pm Post subject: |
Couple more pics (from my crappy "shop" camera).
Finished the butt welds on the first one, LOTS of flat filing. Made a second and cut parts for a third. Still need to finish the welds, mill the endcastings for 25hp, media blast, paint and bake.
The heatrisers have to be blocked BTW, as the heatriser is dimple-rolled along its top edge to sit "squished" against the bottom of the intake runner, the "extension" heatriser section cannot be butt welded where it touches the intake runner. While it is unlikely that exhaust gases would escape out of that tiny crack (which you can't see), I cannot take risk. Even if the amount of gas that escaped was small and harmless, it would probably discolor the intake runner.
Since most people only drive these early cars on warm, nice days, it shouldn't matter. Most people will have driven these cars for years with completely blocked heat risers and never even knew it..... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Wed Feb 08, 2006 10:21 pm Post subject: |
Looking good. Thank god for guys like you John. You're a talented man. _________________ 53 oval hardtop |
RickC Samba Member
Joined: August 04, 2001 Posts: 125 Location: Monterey County, CA
Posted: Wed Feb 08, 2006 10:29 pm Post subject: |
Hi John. You are really doing a great job on these manifolds. I found another one .... 26mm head and 28mm carb, and I think there are some numbers on the rear of the jacket. I'll try to check it out tomorrow or Friday. Thanks for your efforts at Zarwerks. _________________ Rick Clark in Monterey County, CA USA
... where the surf is happening and the lightweights are standing on the beach, checkin' it out... |
Posted: Thu Feb 09, 2006 7:49 am Post subject: |
I figured you might jump in here Rick.
Thanks for you paitience, the first one of these is yours.....
Should be done in a couple weeks.... _________________ John Henry
'57 Deluxe
'56 Single Cab |
