coW Samba Member
Joined: September 21, 2004 Posts: 2096 Location: New England
Posted: Fri Feb 17, 2006 6:20 am Post subject: |
I've been following Lee's experiment as well and referred others to it. It is a very useful test.
Thanks for that link - That's quite interesting as well. |
Lee. Samba Animal Controller
Joined: December 22, 2003 Posts: 3079 Location: Denver, CO
Posted: Sun Feb 19, 2006 10:04 pm Post subject: |
| chubbydude wrote: |
Thanks Lee for doing this excellent comparison.
I was wondering what the score was, or when you are planning on doing an update!
I have seen a similar unbiased comparison on the net, and POR won in terms of stopping rust creep.
http://www.drjing.com/Mini/BLOG/SideBySide.htm |
I'll get some pics up tomorrow. I threw a bunch of de-icer all over them a few weeks ago. _________________ www.DenverWildlifeControl.com |
Jowlz The Anti-Purist
Joined: May 02, 2005 Posts: 2464 Location: Tunkhannock, PA
Posted: Sun Feb 19, 2006 10:20 pm Post subject: |
I have been following for a while as I have always used por-15. Excellent work Lee. This thread should be a sticky. _________________ The honey-do list put my project on hold....... |
Posted: Tue Feb 21, 2006 3:32 pm Post subject: |
Thanks guys.
No change except the small ones are bubbling a little bit.
plotch Samba Member
Joined: December 22, 2004 Posts: 553 Location: jeffersonville, vermont
Posted: Fri Mar 03, 2006 10:47 am Post subject: |
| The consumer reports for the vw and auto world. Hopefully the test will be ongoing and ongoing. I have used Hammerite on steel wheels, both sides and had bleed through in six months. Rustoleum lasts longer than that used in the same manner. Also have used the por-15 products. Have had some bleed through which might be because only did one side of the rocker panels. Am tempted to pour product into the enclosed areas for added protection, but am afraid of wasting the precious stuff. Thanks for doing the test. |
walrus Samba Member
Joined: June 02, 2005 Posts: 507 Location: ashland ky
Posted: Thu Mar 30, 2006 3:43 am Post subject: |
One nice test. It is hard to decide on what to use if no one has tried out all the products side by side. _________________ 1987 Syncro west. conversion
1991 Jetta gli |
Posted: Fri Mar 31, 2006 3:24 pm Post subject: |
No changes so far. I was thinking of pouring brake fluid on them and hitting them with a sledgehammer to see how they hold up. _________________ www.DenverWildlifeControl.com |
miguelsanchez566 Samba Member
Joined: February 23, 2006 Posts: 29 Location: fernandina beach, fl
Posted: Wed Apr 05, 2006 12:47 pm Post subject: |
| Lee. wrote: |
| No changes so far. I was thinking of pouring brake fluid on them and hitting them with a sledgehammer to see how they hold up. |
haha now that sounds like fun...let us know! |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Wed Apr 05, 2006 4:35 pm Post subject: |
Lee--
I can't remember if I mentioned this, before, but spray some sheet metal with Plasti-kote 500 degree engine paint. I have had good luck using it on all kinds of stuff. |
VWBobby Samba Member
Joined: April 21, 2004 Posts: 1537 Location: Central Oregon Coast
Posted: Thu Apr 06, 2006 9:30 am Post subject: |
I also wouldn't mind to see a test of the Plastikote 500 degree paint!
I use this stuff on my valve covers, brake calipers, or anywhere that I want a very protective coating that won't chip/scratch as easily as regular paint. I read somewhere that it has ceramic material in it...that could be the reason it works so well when scratched. |
Posted: Thu Apr 06, 2006 1:49 pm Post subject: |
| VWBobby wrote: |
| Campy wrote: |
Lee--
Will it work right over rust? _________________ www.DenverWildlifeControl.com |
surfonica Samba Member
Posted: Thu Apr 06, 2006 2:20 pm Post subject: Are any of these sandable? |
Excellent test!
Forgive my ignorance as a newbie, but I've got 2 questions:
1. Are any of these products sandable? In other words, if I prep/paint these on my front window frames or my rain gutter to kill rust, can I sand the product down when dry to make it smooth, then primer over it before painting?
2. What happens If I use these products on areas with cancerous rust? Do these products really "eat" the rust down to the bare metal, or just chemicaly encapsulate the rust from air - killing it's progress? I'm worried about small pinholes becoming big holes!
Thanks,
- Rick |
veedubguru Samba Member
Joined: June 26, 2006 Posts: 8 Location: Asheville, NC
Posted: Thu Jun 29, 2006 7:04 am Post subject: |
I noticed you said only 2 hours for the POR 15 to dry- it takes 4-5 hours inbetween coats, 2 coats does it. I've both brushed and sprayed it, with great results from both. I let a frame I did sit out all winter after POR 15ing it last fall, no problems, looks great! Brushing allows me to do a little more than 2 frames, spraying conserves and I can do about 5 frames from 1 gallon, and no brush strokes. I didn't thin it for spraying either, just got a $40 thick stuff spray gun. Gotta clean it real good, or the gun is history! I've done numerous frames now in POR 15, but I also sand blast first. Having restored bentley, rolls royce and very exotic cars for over 20 years now, I can definitely say that whatever product you use, if you don't get the rust all the way out, it will come back! For Sure! So don't cut any corners thinking a wonder product is going to save your but!
Tom |
Posted: Thu Jul 13, 2006 6:00 pm Post subject: |
No changes in the big panels. All of the smaller samples are starting to bubble pretty bad. If they had been topcoated with paint. It would look like crap.
I have them set up to get hit for 20 minutes a day with the sprinklers for the rest of the summer. _________________ www.DenverWildlifeControl.com |
redbug68 Samba Member
Joined: May 17, 2006 Posts: 55 Location: Harlingen, TX
Posted: Tue Jul 25, 2006 11:03 am Post subject: |
OK! I cant wait any longer....
if you had to choose now which one would you say is in the lead.
I need to do something for the pans I just installed beofre rust attacks!! |
Posted: Tue Jul 25, 2006 12:54 pm Post subject: |
| redbug68 wrote: |
I just went out and looked. Por & RB are doing a little better than the others. I would say go with RB because it's a little cheaper.
Make sure to get the metal as clean and as rust-free as you can. _________________ www.DenverWildlifeControl.com |
Campy Samba Member
Posted: Tue Jul 25, 2006 11:29 pm Post subject: |
| With products like Por-15, or any paint, as far as that goes, make sure that the metal is, also, scuffed up. Por-15 will peel off like tape if the sheet metal is dirty and/or smooth. |
Spentzos Samba Member
Joined: December 01, 2005 Posts: 87 Location: Newport, RI
Posted: Wed Aug 09, 2006 6:18 pm Post subject: |
Hello, Very good test. I've used Wurth RustGuard (under my bus and in the wheel openings) in the past with good results. It's held up very well for about 2 years now. I imagine it's simular to the POR-15. Might want to try it. One thing though, it has no UV protection. Is you sample piece in the sun? Something to consider. The Wurth product is supposed to be top coated (when tacky) if it's to be exposed to UV rays. _________________ Dino Spentzos
72 Westfalia
Newport, RI USA |
Posted: Wed Aug 16, 2006 12:34 pm Post subject: |
| Spentzos wrote: |
| Is you sample piece in the sun? |
Yes, they have been in the sun the whole time.
Today, I dropped a 10# rock on each sample. Dented the metal, but, no other damage. I also poured a quart of brake fluid on the samples. We'll see what happens. _________________ www.DenverWildlifeControl.com |
8686 Samba Member
Posted: Sun Aug 20, 2006 5:43 pm Post subject: rust |
Lee
Have you or know looked at this product and do you think it has any merit. Im thinkinking of using it.
www.safestrustremover.com
cheers |
