Hella Bro Samba Member
Posted: Fri Oct 24, 2003 4:38 am Post subject: Dove grey / Light Grey powder coat color |
I'd like to have my hubcaps powder coated Dove-grey for my Double-Cab
. Anyone have any info. Thanks |
Uniballer Samba Member
Joined: March 01, 2003 Posts: 340 Location: Newberg, OR
Posted: Fri Oct 24, 2003 7:59 am Post subject: |
| Wolfsburg West sells them already powder coated in that color |
Posted: Fri Oct 24, 2003 10:56 am Post subject: |
| Uniballer I wish wolfsburg west did carry them. They only carry the light grey. I need Dove grey for my Dove Blue Double-Cab. |
Posted: Fri Oct 24, 2003 11:55 am Post subject: |
| my bad |
RobzKombi Samba Member
Posted: Thu Apr 05, 2012 11:49 am Post subject: |
| Was a good match for the Dove Grey found? |
type241 Samba Member
Joined: June 02, 2006 Posts: 1023 Location: MOSES LAKE, WA
Posted: Thu Apr 05, 2012 12:04 pm Post subject: |
| Go to RAL chart(universal color chart) and pick a couple shades of grey. You can buy ANY RAL color through powder distributors. OR you can have a batch specially made for around $375 for 5 pounds which will do almost every dove grey part on the planet. |
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Thu Apr 05, 2012 12:14 pm Post subject: |
still looking for light grey equivilent as well. _________________ 1957 Beetle
1966 Bus |
Posted: Thu Apr 05, 2012 7:00 pm Post subject: |
| type241 wrote: |
By looking at the chart online,http://ralcolor.com/ it looks like Pigeon blue is as close as you can get, with Distant blue a close second. I'm sure the shades vary in person.
Don't really know what all the codes below really mean but I'll just take them to the shop I have my caps at and let them figure it out.
RAL = RAL 5014
RAL-RGB = 096-111-140
RAL-HEX = #606E8C
Color = Pigeon Blue |
Posted: Thu Apr 05, 2012 7:28 pm Post subject: Dove grey |
| It is that blue huh?? There are a lot of greys on that chart in the 7000's. I thought maybe 7040? |
Posted: Thu Apr 05, 2012 8:11 pm Post subject: |
I was looking at 7040 as well but most of the picture I've seen seem to favor the blue more than the grey, well at least to me they do. Then again it can be the way my monitor displays the shade. These are a few pictures I've found online so far to compare. What do you think?
This one seems more grey than blue.
Sidbus Samba Member
Posted: Fri Apr 06, 2012 4:11 am Post subject: |
| Sidbus wrote: |
| Wolfsburg West sells dove gray in a can. Maybe you can give that to the powder coater and tell him to match it? |
Already on that , I have two cans now and sprayed a part to take to the shop with me today. The plan is to take the painted part and a few of the RAL codes and see what they can come up with. I'll post up the results as soon as I can. |
Sidbus Samba Member
Posted: Fri Apr 06, 2012 5:26 am Post subject: |
| RobzKombi wrote: |
| Sidbus wrote: |
Good plan then! I used the WW paint on my hub caps and they look great on my freshly painted dove blue panel. Also bought an extra can of paint as I'm sure once I get on the road there will be a lot of touch up necessary  _________________ 57 Panel http://www.thesamba.com/vw/forum/viewtopic.php?t=453943
62 so34 http://www.thesamba.com/vw/forum/viewtopic.php?t=533160
76 Westy http://www.thesamba.com/vw/forum/viewtopic.php?t=520076 |
FlusteredBust Samba Member
Joined: April 11, 2007 Posts: 217 Location: St. Pete, FL
Posted: Fri Apr 06, 2012 6:13 am Post subject: |
The Pigeon blue looks closest. It's only a bit too blue in my mind. I don't the WW swatch is really that close to the hubcap.
HUBCAPS by falstaffsmind, on Flickr |
kafer60 Samba Member
Joined: January 17, 2005 Posts: 369 Location: Fredericksburg, Va
Posted: Fri Apr 06, 2012 7:11 am Post subject: Powder coating |
Take the hub cap to your local powder coater. They will have a color chip strip and will have all sorts of colors. I just had my gas tank done locally and he had a color that was all in german and found the perfect blue grey. _________________ Can't polish a turd!
"Midman- Seems to have worked well for Ted Bundy."
"seems like the right front tire is flat at the bottom, rest looks pretty good"
"The hardest part about business, is minding your own" |
Posted: Fri Apr 06, 2012 8:46 am Post subject: |
Caps are at the shop already ( http://decometalfinishing.com/ ), they were there to get plated but plans have changed. I'll be leaving to go there in a few minutes since I have some other parts that need coating.
FlusteredBust, good comparison picture but color is the strip R-side of the hub cap? where did you find that strip? |
Posted: Fri Apr 06, 2012 10:50 am Post subject: |
That right hand strip was taken by sampling the color of the OG hubcap with a photo editing program I have. When I do that, there is some variation depending on where I place the eye dropper selection tool pointer on the photo, so I can't say it's absolutely exact to original. But then again, there was probably slight variations every time they mixed a new batch of paint. The RGB (red, green, blue) Code ends up being (103, 120, 135) which I just discovered you can use to get a paint match here...
http://www.easyrgb.com
Unfortunately, and this doesn't seem to match automotive paint codes. The RAL chart actually has the RGB codes on it in the second column. Pigeon Blue is 096-111-140. You can duplicate it over at easyrgb.
I did read that some paint shops can take the rbg color and match it. |
Posted: Fri Apr 06, 2012 12:24 pm Post subject: |
So I took my color sample in and they say the can match it pretty darn close. The will shoot a couple of scrap parts to test first and see how close it comes to my sample.
I'll report back in a couple of weeks with results. |
Posted: Fri May 04, 2012 5:09 pm Post subject: |
Not even close, the plug was the attempted dove grey. Here's the radio delete painted with WW Dove Grey for comparison.
Dropped them back off at the body shop to get painted instead. Oh well. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 72013 Location: Phoenix 602
Posted: Mon Jul 08, 2013 5:58 pm Post subject: |
So I am sure, in this photo:
Is the cap on the left Light Grey and the cap on the right Dove Grey?
Both of these are original caps.
In person:
The cap on the left looks tan with a sort of greenish tint to it in person.
The cap on the right is a darker grey.
Neither have that "primer" look of the reproduction caps:
Example:
_________________ How to Post Photos
