wolfsburgvw Samba Member
Posted: Sun Mar 05, 2006 9:01 am Post subject: Split horn |
i have the chance to buy a horn for a split but its 12 volt,how do i go about changin g it to 56 volt,anyone. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71483 Location: Phoenix 602
Posted: Sun Mar 05, 2006 9:59 am Post subject: |
it looks just like a split horn. |
Wiggy Samba Member
Joined: April 17, 2003 Posts: 6606 Location: Downingtown, PA
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Mon Mar 06, 2006 10:17 am Post subject: |
no it is the swirly type like splits have.nothing like that chrome one. |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9405 Location: Northwood, NH USA
Posted: Mon Mar 06, 2006 11:36 am Post subject: |
Actaully a "split" could have had any of three horns, the "mercedes sign", the swirl or the vertical slot one with the oval (not round) Bosch badge.
I believe that sometime in 1950 they went to the vertical slot type hron. Many '50and earlier pics, brochures, videos, etc, show the Mercedes type horn, some show the swirl horn.
As for voltage, the diaphragm has nothing to do with the voltage "load". The coil is wound for a particular voltage. With intermittent, normal use however, a 6 volt horn will survive 12 volts just fine, but it will have a higher pitch.
A horn is kind of a self-regulating device, higher voltage will result in a high magnetic filed being generated but the duty cycle (the amount of time the coil is energized vs. no energized) but not proportionally higher current (which could lead to overheating/burnout. Energize a coil on a 6 volt horn with out the diaphragm and contacts in place and it will pull about 22 amps. Properly tuned, assembled with diaphragm and contacts, and it will show about 4 amps on a DC ammeter (when in fact it is going to 22 amps, then to zero, then to 22, etc.) Run that same horn on 12 volts, and the DC ammeter will read about 5-6 amps.
I only know all that because I restore these horns and test them all the time.... and I'm a geeky engineer..... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Mon Mar 06, 2006 12:02 pm Post subject: |
ok thanks,so what haqve i got to do if i want to make the 12 volt horn 6 volt.steve. |
Posted: Mon Mar 06, 2006 1:07 pm Post subject: |
wolfsburgvw wrote: |
Hook 6 volts to it. It will make noise. _________________ John Henry
'57 Deluxe
'56 Single Cab |
VDubMattStuart Samba Member
Joined: July 10, 2005 Posts: 273 Location: Lincoln, CA
Posted: Mon Mar 06, 2006 4:35 pm Post subject: |
Who knows what kind of Horn I should have on my 53? The one on my car now looks like it was either replaced or rebuilt.
It also has a very flat sound compared to other 6V bugs I've had. Any idea what might be wrong? _________________ 53 oval hardtop |
Posted: Mon Mar 06, 2006 6:07 pm Post subject: |
'53 should have the vertical slot horn with the oval badge. I restore these, although new or repro tags are not available for them. If you have a good tag keep it!.. With a contact clean and a tune, they really wail.... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Mon Mar 06, 2006 6:17 pm Post subject: |
Thsi one would be correct for a '53.
'57 Deluxe
'56 Single Cab |
Yustrn JHC Controla
Joined: August 01, 2000 Posts: 5486 Location: Ovaland, CA
Posted: Mon Mar 06, 2006 6:33 pm Post subject: |
Nice Tat you got there John _________________ I own a copy of "The Car of the Century" by Garwood. This means I am authorized to act like a twat in thesamba forums. |
Yustrn JHC Controla
Posted: Mon Mar 06, 2006 6:34 pm Post subject: |
This horn could be yours for about 200 _________________ I own a copy of "The Car of the Century" by Garwood. This means I am authorized to act like a twat in thesamba forums. |
Posted: Mon Mar 06, 2006 7:04 pm Post subject: |
Not my hand, not my tat Eric. {I dug that pic out of the gallery}
While we are sharing horn pics:
Clockwise from upper left: The "Mercedes" horn, the vertical slot horn with no badge (I think these were used on some stds, and the type2 "working buses"), the (rare) horn cover, the vertical slot horn with the badge (missing on that one, I'm looking for a nice one, anyone??), and the "swirl" horn. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Tue Mar 07, 2006 2:09 am Post subject: |
johnshenry wrote: |
'53 should have the vertical slot horn with the oval badge. I restore these, although new or repro tags are not available for them. If you have a good tag keep it!.. With a contact clean and a tune, they really wail.... |
Well, it looks like I don't have the correct horn. It definately is a later horn. Has the raised center (like a nipple) with the pattern of small holes. It does have screw terminals though. Pretty common if I remember correctly.
So if I find the correct horn for my '53, what can I expect to pay for one? _________________ 53 oval hardtop |
Posted: Tue Mar 07, 2006 7:10 am Post subject: |
The deal with the vertical slot ones Matt is always the badge, they didn't weather well. I might have an extra one, but no good badges. I see them from time to timeon eBay, they seem to go for $30-$65 or so, but even then, seldom with a good badge. They are nowhere near as rare as the Mercedes or swirl ones... _________________ John Henry
'57 Deluxe
'56 Single Cab |
