smitty Samba Member
Joined: January 04, 2004 Posts: 141 Location: Nashville Tn.
Posted: Fri Mar 24, 2006 9:10 pm Post subject: gland nut help |
It would be fantastic if someone could post a pic of a gland nut for a full automatic T-3 trans OR tell me where to find an automatic gland nut OR if anyone can verify if the one I have is correct. Thanks for any help.
Mr. Bubblehead El Chupa Nibre
Joined: October 25, 2002 Posts: 2756 Location: 612 Wharf Avenue
Posted: Fri Mar 24, 2006 9:14 pm Post subject: |
I don't think you have the right one, I'm pretty sure the automatic ones were solid...maybe that one is for a Type 1 autostick? _________________ OGST
Samba Member #4862 |
smitty Samba Member
Posted: Sat Mar 25, 2006 6:13 am Post subject: |
Thanks Mr. Bubblehead, but.....
I am certain they are not solid. The torque converter has a nipple that fits into the gland nut for added support. Consequently, it fits the one I have perfectly.
C'mon people, dig through those manuals! Somebody has to know for sure what the difference is.
I believe I have stumped the 'all-knowing' Sambanites  |
smitty Samba Member
Posted: Sat Mar 25, 2006 9:29 pm Post subject: |
Well it would appear I didn't stump everyone....Russ Wolfe, you Da' Man
thanks to everyone that played! |
brntrtt5 Samba Member
Posted: Sat Mar 25, 2006 9:32 pm Post subject: |
just make sure the one u use does not have a pilot bearing in it. Speaking from experience the flexplate will not bolt flush to the converter.
the one you have looks to be one for a manual tranny without the pilot bearing |
notchback Insensitive Jerk
Joined: December 16, 2003 Posts: 7024 Location: Behind the Zion Curtain
Posted: Sat Mar 25, 2006 9:55 pm Post subject: |
From a '71 engine that I tore down:
| zeen wrote: |
| Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point. |
FU#3 |
smitty Samba Member
Posted: Sat Mar 25, 2006 11:33 pm Post subject: |
Ok, now the one that Notch posted looks like a MT trans minus the bearing, based on the thickness of the flats when compared to the pics I originally posted of the MT and the 'mystery' ones. This puts me right back to square one, no pun intended. I'm beginning to think it might be easier to find a MT chassis and do a body swap than it is to find the correct gland nut  |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun Mar 26, 2006 10:19 am Post subject: |
Yeah, I got some dimensions from Jim Adney for the automatic galnd nut. the thickness of the hex for a T-3 Automatic is .332" The manual trans one is .408". It is slightly thinner than a manual trans but thicker than the automatic stickshift T-1 one.
If Neal could measure the known one he has, to confirm it, this would be appreciated.
I am trying to get the correct dimension so I can make some from manual trans ones.
Using the wrong one can ruin the drive plalte. because it will always be in a bind, or the center nub will not be supported properly. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
smitty Samba Member
Posted: Sun Mar 26, 2006 11:13 am Post subject: |
And if he can take in ID measurement of the opening with the flats as well, it would be most appreciated.
thanks for all the help and keep it coming, if we get enough people scratching their heads the answer is sure to turn up! |
Posted: Sun Mar 26, 2006 4:31 pm Post subject: |
| smitty wrote: |
You want me to work? It only took 5 days to take a picture, so it'll probably take even longer for me to measure it.
I'll try to get to it tomorrow and post the measurements. _________________
| zeen wrote: |
FU#3 |
smitty Samba Member
Posted: Sun Mar 26, 2006 8:59 pm Post subject: |
| Russ Wolfe wrote: |
| the center nub will not be supported properly. |
2 new questions:
is the nipple on the torque converter there for support or is to allow for the output shaft? Looking inside the converter I can see a small cog in the nipple.
Notchback, will you sell me the one you have?
Sorry I'm beating this issue to death but I really want my car on the road for Bug-a-Paluza April 22-23. |
