flyingCoyote Samba Member
Joined: January 14, 2006 Posts: 514 Location: Burp Hollow, OR
Posted: Sat Apr 01, 2006 9:48 pm Post subject: Stupidest previous owner "repair"? |
I think I might have a record - I once bought a '76 Westy, and found that one of the "fuses" was actually a .22 cartridge. I guess he REALLY wanted to be notified of any current surge..
_________________ 1985 Vanagon GL / homebrew camper (daily driver)
1974 Super Beetle (Wife's daily driver) |
51split Samba Member
Posted: Sat Apr 01, 2006 11:02 pm Post subject: Stupid POs |
OK
In 1975 I bought a 56 oval window the PO who had a new motor installed but couldn't get running right.
He was so mad he wanted to sell it for $100.
I went to see the car at night, and it looked OK.
He started it up but it ran but badly.
As I watched it run I could see it sparking against the engine tin.
Paid him the $100 and he signed it over.
He told me I would need to tow it home.
I moved the wiring around and reversed number 3 and 4 plug wires.
Reached in the window and started the car up.
Drove home and kept that car for several years. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16803 Location: State College, PA
Posted: Sun Apr 02, 2006 5:34 am Post subject: |
This was last fall.
So, every once in a while a see a small spot in the front of the car. hmm smells like gas. Anyway, while I am under here - I want to reset that big rubber bumper that is looks like it must be a tank mount. It's wedged between the top axle tube and the tank. Looks like its crooked.
Slip it out - gas pouring out of a hole that it was covering.
Guess he hammered the tank to clear the axle and the damper. Put a nasty crease at the bend on the corner of the tank, whcih cracked.
Added a new tank to shopping list LOL. _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
cbr900racer Samba Member
Joined: April 29, 2005 Posts: 1360 Location: middle tennessee
Posted: Sun Apr 02, 2006 11:54 am Post subject: |
hey, do a search for "dumbest PO award" and you will find a thread i started a while back. my PO had a rubber fuel line laying across the header and the axle nut on the passenger side was finger tight to just name a few  |
hambone Samba Member
Joined: July 09, 2004 Posts: 1623 Location: Portland, OR
Posted: Tue Apr 04, 2006 1:51 pm Post subject: |
'69 Beetle, front brake cylinders held together with bailing wire... |
Kafer Wolf Samba Member
Posted: Tue Apr 04, 2006 9:21 pm Post subject: |
cracked portion of front windshield rubber was slapped with epoxy and marker-penned black. everytime it rains, water pours into the interior  |
vwaddiction Samba Member
Joined: June 07, 2002 Posts: 136 Location: corner of Walk and Don't Walk
Posted: Wed Apr 05, 2006 11:47 am Post subject: |
Pulled up to pick up my new car to find the previous owner tinkering around in the back seat. He had disconnected shift linkage under the seat for me to prevent transmission damage during the tow home.
That was nice of him. _________________ Not just a car its a cult |
ScottK Samba Member
Joined: August 28, 2004 Posts: 1748 Location: Avilla America
Posted: Wed Apr 05, 2006 12:30 pm Post subject: |
My PO replaced the floorpans, but neglected to cut the old ones out. Just welded the new ones in on top of the old rusted out ones. |
John- Samba Member
Joined: January 27, 2004 Posts: 206 Location: Newberg, OR
Posted: Wed Apr 05, 2006 4:50 pm Post subject: |
ScottK wrote: |
thats pretty bad  _________________ 1962 VW beetle-The project
1985 Honda Aero50cc-The bike
1995 Hyundai Accent-The spare |
DaveM Mad Samba Scientist
Joined: June 11, 2002 Posts: 3010 Location: Dry side of Oregon
Posted: Wed Apr 05, 2006 5:03 pm Post subject: |
I've been working on some rader wheel restorations for a couple of years now (sorry Manuel for the loooonnnnnng delay). When we started in on the wheels, we found one had all but 1 spoke completely broken and the cracks had been filled in with body putty and then it was painted. _________________ Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices. |
67stang302 SBS Hit Squad
Posted: Thu Apr 06, 2006 12:22 pm Post subject: |
My 68 Square has half of the wiring replaced with speaker wire. My super had no throw out bearing installed (they couldn't figure out why the clutch didn't work). Got a 78 toyota corolla given to me they said the trans was bad so I pull the trans and find that who ever did the clutch forgot to put the disk back in. Drove my first bug home and the first time I hit the brakes the wiring caught on fire(they didn't understand that ground wires don't go to hot leads). I have had numerous PO experiences. _________________
EverettB wrote: |
Hondaz rulez my lifez |
SBSeven 1 YR and still going
59 Kombi laying beam
64 type 34 |
Travis H. Samba Member
Joined: December 09, 2004 Posts: 174 Location: colorado, springs
Posted: Thu Apr 06, 2006 7:26 pm Post subject: |
the PO of my camper took out the waste holding tank for the sink and replaced it with a big hole in the floor and a PVC pipe _________________ - 67 type 1
- 59 panel |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35919 Location: Conejo Valley, CA
Posted: Sat Apr 08, 2006 9:27 pm Post subject: |
A few months after buying a '65 bug to replace my stolen '67, I discovered a problem with the clutch cable (it seemed to have broken).
PO, a lazy but creative bastard didn't know to hook the FRONT of the clutch cable first, THEN put on the wingnut on the tranny lever. To add length to the seemingly too-short cable at the pedal cluster he added a large thick paper clip looped around both. I discovered this when it eventually cut the "finger" that hooks the cable eye at the cluster.
As I looked at this broken setup, I remembered him saying he had rebuilt the motor himself a year ago. Amazingly, it lasted nearly 100K miles. |
vwjosh6070 Driveway Camper
Joined: August 24, 2003 Posts: 2802 Location: not camping...
Posted: Sun Apr 09, 2006 1:55 pm Post subject: |
the PO of my 60 installed a house light switch in for the headlights, and removed the relays and strait wired everything. now i only have turn signals 50% of the time, but my headlights work! _________________ josh, AKA "the infamous josh"
1973 Transporter "Floyd"
****Wheres my old bus?! 1967 Montgomery Ward Camper****
KI4MXO |
Kommercial Samba Moderator
Joined: December 28, 2000 Posts: 1189 Location: San Tan Valley, Arizona
sunroofghia Samba Member
Joined: June 26, 2003 Posts: 71 Location: Phoenix,Arizona
Posted: Tue Apr 11, 2006 9:37 pm Post subject: |
Not really dumb but overkill, my PO put rattle can undercoating all over the entire interior of the car....because someone said "Old VW's rust out fast". I bought it from him in Fu@%'n Phoenix!  _________________ 72 ghia coupe w/Electric Golde slider
65 fiat 600D |
jroymcd Samba Member
Joined: April 18, 2005 Posts: 1053 Location: Bay Area
Posted: Wed Apr 12, 2006 3:47 pm Post subject: |
ScottK wrote: |
same thing but the did not even weld them in. the used expoxy
covered rust with bondo to do repairs.
ran wires along the running boards.
fuel filter backwards
etc.
spent the last 6 months fixing everything. the PO was someone who owns a vw shop.  _________________ www.cultwagen.com |
insanitize Samba Member
Joined: December 01, 2003 Posts: 141 Location: Queens, NY
Posted: Thu Apr 13, 2006 6:06 am Post subject: |
I once bought a 62 Oldsmobile vert from a man who repaired small aircraft. He replaced the canvas with the fabric that they used to make the skin on planes and then used the hardener to make it stiff. What a pain it was to remove but I was young and wanted a vert. My friends and I removed the pseudo hardtop and replaced it with green boat canvas, (the car was red) no sewing just glue and staples the worst looking job you can imagine. I drove the car for two summers like that then wrecked it. I miss that car. |
OVLWNDO Samba Member
Joined: June 09, 2005 Posts: 225 Location: San Mateo, CA
Posted: Thu Apr 13, 2006 10:42 am Post subject: |
Old piece of shag carpet used in place of the steering coupling disc. |
Karnage Samba Member
Joined: November 21, 2004 Posts: 24 Location: Washington state
Posted: Fri Apr 14, 2006 10:57 am Post subject: |
The ignition on my 64 had gone out and instead of just replacing it the PO added a tiny toggle switch and a starter button. I kinda dug the starter button though.
the '74 standard(which i turned into a horrid chop) i had when i was a teenager had the windshield caulked inside and out with white caulking since the windshield leaked. I bought a used gasket for five dollars and replaced it the next weekend, as well as pulling out the house carpeting and emptied the rear ashtrays of the roaches... _________________ "the truth is ugly, so we throw our prophets in prison"~C.M |
