Oil temp sender
Page: 1, 2, 3, 4, 5  Next
badpanel
badpanel is offline
PostPosted: Fri Apr 07, 2006 12:28 pm    Post subject: Oil temp sender Reply with quote
Hi guys, where is the best place for oil temp sender and where have you got your remote cooler and electric fan mounted on split bus?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Apr 07, 2006 12:33 pm    Post subject: Reply with quote
My temp sender is in the side of the oil sump.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
rrobdaw
rrobdaw is offline
PostPosted: Fri Apr 07, 2006 2:21 pm    Post subject: Reply with quote
mine is on a 3 way brass 'T' coming out of the original idiot light location, I can't even get a reading . So I'm going to have to move it. Robert
John M.
John M. is offline
PostPosted: Fri Apr 07, 2006 2:41 pm    Post subject: Reply with quote
I believe the most accurate spot for temperature readings is the oil pressure relief sender.
Current: 1972 Beetle - 96V EV
Previous:
1966 Beetle - Sea Blue - 1300SP
1966 Beetle - Sea Blue - 1600SP
1974 Beetle - African Red - 1914CC
badpanel
badpanel is offline
PostPosted: Sat Apr 08, 2006 12:24 am    Post subject: Reply with quote
Someone was telling me that the best place is in the remote filter mount if you have one, I may give that a try or in the sump!
Thanks guys.
AJTowers
AJTowers is offline
PostPosted: Sat Apr 08, 2006 9:42 am    Post subject: Reply with quote
Mines on the sump, also. I added this thread to the tech articles sticky, since this question seems to come up alot.
RPM's= Ruins-People's-Motors
redhot
redhot is offline
PostPosted: Mon Apr 16, 2007 11:57 am    Post subject: Reply with quote
Hi,
Two questions basically:
Going to use the GB 227A I think it is. Just a on/off switch similar to the dipstick version.
1) Place the sender in the sump (bottom plate) Good enough? Or should the gallery be tapped and entered at the type3 stock oil filler location (like Glenn)
2) Since it is going to be spliced into the oil-pressure light wire, is there some way to tweak the signal so that I know it is the temp-sender and not pressure sender? Was thinking of some sort of device that make the light flimmer steadily. Perhaps difficult since it grounds the circuit instead of being on the hot side?
Bashr52
Bashr52 is offline
PostPosted: Mon Apr 16, 2007 8:07 pm    Post subject: Reply with quote
I had an oil temp sender that screws into the stock pressure sensor hole. I ran just that in the hole for a while just to see what my temps were before I installed my T fitting for both senders. Drove it twice, then went to take it out to install the T and found it had nicely exploded inside the case and almost completely pluged my oil gallery. It took me a while with a flash light and a dental pick, but i got all the parts and pieces outta the hole. Glad I caught it when I did! I'm a bit weary of that style now and run the one that goes into the drain plug hole.
barndoormambo
barndoormambo is offline
PostPosted: Tue Apr 17, 2007 12:06 am    Post subject: Reply with quote
...mine is in the drain hole on an extended sump. Without an external cooler ( but with external filter) , what sort of 'normal ' temps should it be running?.. Confused
....just cause you don't see it, doesn't mean it isn't there!....
caslor
caslor is offline
PostPosted: Tue Apr 17, 2007 6:44 am    Post subject: Reply with quote
i have two engines.. the one with only one relieve plung and the other with 2 relief plungs..
a) it is good to place a oil temperature sender in the engine with one oil relief?
b) in the engine with 2 oil relief plungers where is the best plug to add this sender?
thanks
Mr. 010
Glenn is offline
PostPosted: Tue Apr 17, 2007 6:53 am    Post subject: Reply with quote
I've since moved my sender so no it's in the oil filter mount. That way I'm seeing the temp as it enters the engine.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
sb778
sb778 is offline
PostPosted: Tue Apr 17, 2007 7:21 am    Post subject: Reply with quote
I was also thinking of doing that.Does it restrict flow?not much room left inside the oil galley once sender is in.Great location for a accurate reading.
redhot
redhot is offline
PostPosted: Tue Apr 17, 2007 7:26 am    Post subject: Reply with quote
Cant see why the temperature rise should be so large from the pickup tube to the filter?
Any opinion on the electrical part?
Mr. 010
Glenn is offline
PostPosted: Tue Apr 17, 2007 7:28 am    Post subject: Reply with quote
There is no restriction.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
sb778
sb778 is offline
PostPosted: Tue Apr 17, 2007 7:38 am    Post subject: Reply with quote
Glenn,did you notice a significent temperature change from sump to filter location?
Mr. 010
Glenn is offline
PostPosted: Tue Apr 17, 2007 7:41 am    Post subject: Reply with quote
Can't say since I have a totally different engine. It's still new and needs to be dialed in, so 'll have to wait and see.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
gerg
a.k.a. 6volt65
gerg is offline
PostPosted: Tue Apr 17, 2007 7:47 am    Post subject: Reply with quote
I have 2 senders on my case - one in the type 3 oil block off plate and one in the relief position. The sump temps (type 3 plate) are usually 20 degrees hotter than the relief position.
The relief position is a mixture of cooled oil coming from the external cooler/filter return (bleeding past the piston) and oil in the case sloshing up into the bottom of that relief well.
So 200 at the relief position is usually 240ish at the sump location.
I do think, however, the sender in the type 3 plate is reading high since it is sinking heat out of the case itself. The sender tip is the same casting as the threads - so oil temp and case temps can influence it.
I'll be driving the SC to TX tomorrow and watching the temps - comparing the 2.
Gerg
. . . I got 99 problems and my bus ain't one . . .
'65 Sunroof Beetle
'65 Vert
'60 Singlecab
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger Gallery Classifieds Feedback
veedubcrazy
veedubcrazy is offline
PostPosted: Tue Apr 17, 2007 8:21 am    Post subject: Reply with quote
Going to Fredericksburg?
1967 Deluxe Sedan
1971 Squareback - "The Silver Surfer"
bugnut68
bugnut68 is offline
PostPosted: Tue Apr 17, 2007 9:16 am    Post subject: Reply with quote
I installed my temp sender on the block off plate at the rear of the engine, where the Type 3 oil filler would go, if the engine were utilized as such.
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
gerg
a.k.a. 6volt65
gerg is offline
PostPosted: Tue Apr 17, 2007 1:32 pm    Post subject: Reply with quote
Sure am.
Oil cooler fan shroud complete - cosmetics now Wink
Gerg
'65 Sunroof Beetle
'65 Vert
'60 Singlecab
Page 1 of 5
