VW_MAN_73 Samba Member
Joined: November 18, 2005 Posts: 1003 Location: Sunny Florida
Posted: Sat Apr 29, 2006 8:43 pm Post subject: trying to start |
I just put a new fuel pump in the bus. It is getting spark and fuel and plugs are connected right. It turns over and sounds it starting to run but then doesn't. What is going on. I keep trying it and then letting it sit not to flood it. Any ideas? _________________ ’73 Beetle - My first car, owned 26+ yrs
’71 VW Westfalia - Road-tripping across the US
Rescued & restoring a ’61 Dove Blue SO23 Bus
Follow our journey! |
UZI Platinum FUBU
Joined: February 08, 2002 Posts: 13335 Location: phila-DELFT-ia
Posted: Sun Apr 30, 2006 3:57 am Post subject: |
i'm guessing you took the distributor out to swap the fuel pump. did you put it back right? _________________ Extravagant Lifestyle
Quote: |
mannys66: South Philly Van Club, only the most influential and freshest van club in the vw scene |
Quote: |
Cuñado: Chrome will get you home!!!!!!!!!! |
Posted: Sun Apr 30, 2006 8:00 am Post subject: |
No, I didn't have to take the distributor out. The bus is trying to start but won't catch. _________________ ’73 Beetle - My first car, owned 26+ yrs
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12546 Location: Over 2002 posts deleted!
Posted: Sun Apr 30, 2006 9:27 am Post subject: |
First go back to step # 1, get a beer!
Then revise the basics, firing order, timing, fuel hoses in correct pump port, etc. It's prolly something very simple, so simple it might have been overlooked.
Then get another beer!  _________________ Some people are so busy being clever they don't have time enough to be wise. |
mintonman Samba Member
Joined: October 20, 2003 Posts: 4246 Location: between Trenton NJ. & Philly Pa.
Posted: Sun Apr 30, 2006 9:31 am Post subject: |
Sorry about my edit, I didn't read the first part of this, I'm assuming it ran fine befor the fuel pump replacement?? _________________ Hoockd on fonicks werkt for mee?
under the influance "DUH" |
Posted: Sun Apr 30, 2006 9:34 am Post subject: |
Try putting a hand over the carb while someone turns the key, maybe the choke is at fault  _________________ Hoockd on fonicks werkt for mee?
Posted: Sun Apr 30, 2006 9:40 am Post subject: |
Actually this was a motor I had gotten when I had bought the bus. It was a long block really. I put everything on it. It is a singleport motor 1500cc. I have a 34pct carb on its correct intake but had to use the singleport manifolds to work this system. However I bought these intakes used off the site and the manifolds diameter is smaller than the intakes. Usually the manifolds are bigger than the intake. Iam wondering if there is not a good flow of gas due to this setup. if you are wondering about the manifolds, they are the ones to convert to the use of a bigger carb. _________________ ’73 Beetle - My first car, owned 26+ yrs
Posted: Sun Apr 30, 2006 9:41 am Post subject: |
by the way..... I finished the keg and still isn't working!  _________________ ’73 Beetle - My first car, owned 26+ yrs
Posted: Sun Apr 30, 2006 9:48 am Post subject: |
I wonder if the gas could be getting hungup inside there going big to small  _________________ Hoockd on fonicks werkt for mee?
Posted: Sun Apr 30, 2006 9:50 am Post subject: |
You may want to try pulling the manifolds off & filing the lower part inside so there isn't a big lip in there for the fuel to get hungup on. Don't know if it will work, but mat be worth a try. _________________ Hoockd on fonicks werkt for mee?
pyrOman Fire Master
Posted: Sun Apr 30, 2006 10:30 am Post subject: |
The carb flange on the manifolds are known to "warp" a bit. Check yours to be flat or it may be inducing a vacuum leak. Same goes for the flange on the carb itself!  _________________ Some people are so busy being clever they don't have time enough to be wise. |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15251 Location: Casa de Oro, California
Posted: Sun Apr 30, 2006 2:17 pm Post subject: |
Fill an squirt oil can with fuel and carefully squirt some down the carb while trying. If it works then examine the fuel line, fuel pipe, needle areas. |
Posted: Sun Apr 30, 2006 6:46 pm Post subject: |
Hey guys. I forgot to mention. It is a type 3 motor and it shows in my book that they have a different firing setup on the distributor.
t1+2 t3
3 2 1 4
4 1 2 3
I turned the distributor to where the #1 notch matched the spot for the #1 firing order for type three. and connected all wires to t3 setup. All I heard was some pops. What do I do now? I am going to light this bus on fire and crash it into the woods!  _________________ ’73 Beetle - My first car, owned 26+ yrs
BarryL  Samba Member
Posted: Sun Apr 30, 2006 7:19 pm Post subject: |
I don't think that type 3 thing thing comes into play here but I could be wrong. Put the #1 wire in the cap at about 5 o'clock looking down at the cap. Put the #4 wire at 8 o'clock. Put the #3 wire at 11 o'clock and the last #2 wire at 2 o'clock and see what happens. Try keeping that same order but move each one one spot clockwise if that doesn't work. Try all 4 positions. Is # 1 timed right?
You have your rotor in place, of course, don't you? |
Posted: Sun Apr 30, 2006 7:29 pm Post subject: |
I had it setup like you said and it won't run. Sounds like it is trying to but doesn't. Also, it is a beetle distributor 009 that I put on this type 3 motor. Is there a certain way I have to put the distributor on, did I install it wrong? There is fuel and spark. _________________ ’73 Beetle - My first car, owned 26+ yrs
BarryL  Samba Member
Posted: Sun Apr 30, 2006 7:35 pm Post subject: |
The distributor will only drop in one way. Try the thing I said about moving the wires one notch. Also try this: take out #1 spark plug and turn the engine by hand. Stick your finger in the hole and determine when it is compressing to top dead center. Look at the rotor and that is your #1 wire. |
Posted: Sun Apr 30, 2006 8:20 pm Post subject: |
o.k. Barry. I will try that but when it compresses(piston is pushed out) the rotor will be at 2 different spots each time. For instance when at tdc and turning to tdc again the rotor is at different spots. _________________ ’73 Beetle - My first car, owned 26+ yrs
micro_type2 Samba Member
Joined: April 25, 2004 Posts: 31 Location: The Apple State
Posted: Sun Apr 30, 2006 8:30 pm Post subject: Re: trying to start |
Take it to a mechanic and get a free estimate on what's wrong with it. Then take it home and fix it. Call me cheap. |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Mon May 01, 2006 5:40 am Post subject: |
on some of the aftermarket fuel pumps,the inlet and outlet are reversed. is pump pumping? if you pour a small amount of gas down carb throat,will it fire? you need to set #1 on tdc then looking at top of distributer firing order is -clockwise 1-4-3-2.. roter points at small notch on rim of distributer and #1 on cap lines up there. too bad you put worst vw factory carburater on a fine single port engine. have your valves been adjusted lately? _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
UZI Platinum FUBU
Posted: Mon May 01, 2006 5:51 am Post subject: Re: trying to start |
micro_type2 wrote: |
sounds like $120 of wasted towing charges _________________ Extravagant Lifestyle
