a-train Samba Member
Joined: October 11, 2003 Posts: 702 Location: Issaquah via Parkland, WA
Posted: Fri Jun 09, 2006 6:41 pm Post subject: Difference between inner and outer spline adjustment |
I did a quick search, but couldn't find a concrete answer.
So I understand there are more inner splines than outer splines on the rear torsion bar (something like 44 outer and 48 inner???).
So adjusting the springplate on the outer splines makes a bigger difference than on the inside.
I thought I did one inner and one outer spline on each side when I lowered my bus, but my bus is sitting about 9/16 or so lower at the rear on my passenger side than on my driverside and to me it is noticeable and bugging the shit out of me.
So, without pulling both sides off and getting out the protractor etc... I want to raise the passenger side about 9/16 in. at the rear.
Does anyone know the difference in inches at the rear between an outer and an inner spline? I'm thinking of raising it an outer and lowering an inner......or should I go up two outers and down two inners?
Thanks, and I know I should probably do both sides at the same time and measure etc.... but in the interest of time, trying to get away with one side.
-A _________________ I like VWs
vwtony2 Samba Member
Joined: May 12, 2004 Posts: 1004 Location: south of 19 degrees north and east of 65 degrees west.....
Posted: Fri Jun 09, 2006 7:17 pm Post subject: |
unless you can be sure your bus is a straight as it was when it left the factory and your torsion rods have the same amount of spring in them as they did when they were new. Counting the "clicks" or splines is only a guide line. A protractor is a neat looking tool but what you need is a good eye and a bunch of trial and error. Just keep adjusting until you get it right. By the time you are done you should be able to remove and adjust spring plates in your sleep  _________________ Ambassador of Logistics Wide 5 Vintage Volkswagen Club International |
Posted: Fri Jun 09, 2006 10:28 pm Post subject: |
not exactly what I wanted to hear, but I figured that is how it would play out anyway.
I think I can get it in one or two shots.
Thx.
A _________________ I like VWs |
Posted: Sat Jun 10, 2006 3:03 am Post subject: |
Calculating this using a right triangle method and knowing the length of the spring plate (I approximated 17" from center of torsion to center of wheel) and knowing the angle difference in degrees based on dividing 360 by the number of splines I get
SIN (angle difference) * length of torsion bar = change in height at the wheel
This is changing one inner and one outer notch in opposite directions.
So,
SIN (.681818) * 17 = .2 inches at the wheel.
Rotating outer down one spline and inner up one spline will raise the rear .2 inches on the corresponding side.
I guess this is close enough _________________ I like VWs |
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1887 Location: Clearwater Fl.
Posted: Sat Jun 10, 2006 5:27 am Post subject: |
stock height or lowered buses ,either way you use an angle finder to make both sides even. |
aggro_jo Samba Sticker Pimp
Posted: Sat Jun 10, 2006 6:51 am Post subject: |
your mathmatical formula doesnt allow for sag when the suspension settles. but you are in the ballpark. in my experience, one inner and one opposite outer results in anywhere from 1/8" to 1/4" drop. |
Posted: Sat Jun 10, 2006 9:43 am Post subject: |
I figured it'd be off a little, but either way it sags at both positions so I neglected it (unless it sags more when it's lowered). I think i'm going to go nab a magnetic protractor later today. _________________ I like VWs |
bastardbus Samba Member
Joined: July 13, 2000 Posts: 1786 Location: Toledo, Ohio
Posted: Sat Jun 10, 2006 10:33 pm Post subject: |
Magnetic protactor is the only way to go.
Open a VW Bentley workshop manual, it is the way they do it.
Trying to "eye" it is a serious waste of time.
The protactor is like $3-$5 you can get the spring plates
dead on equal to each other every time.
I have used this method dozens of times.
works perfect. |
Andrew Samba Member
Joined: October 27, 2000 Posts: 5865 Location: Who in the what now?
Posted: Sun Jun 11, 2006 3:36 pm Post subject: |
aggro_jo wrote: |
This is what I've found, too. _________________ -Andrew |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1924 Location: Fontana
Posted: Sat Aug 14, 2010 6:08 pm Post subject: |
I'm replacing one stock height. When I mark the springplate do I mark the angle with a marker on the rail? - can someone post the bentley manual directions? _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
R.Rabbit Samba Member
Posted: Sat Aug 14, 2010 10:02 pm Post subject: |
http://vw.zenseeker.net/Wheels-TorsionBars.htm
probably more info that you really wanted  _________________ Opportunity may knock only once, but temptation eff' leans on the doorbell!
SBS #5
'54 RHD Swedish 3-fold
'60 L345 Doppelkabine |
joe56vw Samba Member
Joined: June 24, 2004 Posts: 3202 Location: Olympia wa
Posted: Sun Aug 15, 2010 12:57 am Post subject: Re: Difference between inner and outer spline adjustment |
a-train wrote: |
-A |
this is not true the only different between the ends of the bar is the splines are not even with the other side
so you can make little adjustments ei.. one outer click down is 3" and one outer down with one inner up is 1 1/2" _________________ '60 15 window walkthrough
why is there no sarcasism button on here? |
hsosa1 Samba Member
Posted: Sun Aug 15, 2010 10:23 am Post subject: |
Thanks for the info it did help . anyone have the bentley. where do I put the protractor on the end of the torsion where the splines are and where do set my mark? I saw the pic but how do u reference a starting point ? Do I just mark my old springplate position and then do the same with the replacement ? I need that damm bentley  _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
krusher Samba Member
Joined: September 24, 2002 Posts: 7662 Location: europe
Posted: Sun Aug 15, 2010 12:34 pm Post subject: Re: Difference between inner and outer spline adjustment |
joe56vw wrote: |
a-train wrote: |
-A |
so you can make little adjustments ei.. one outer click down is 3" and one outer down with one inner up is 1 1/2" |
That is completely wrong  _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
hsosa1 Samba Member
Posted: Fri Aug 20, 2010 1:23 pm Post subject: Spring plate stock |
Ok so my bus is stock height. I just need to replace one springplate and the bushings. The transmission is removed. The bus is somewhat level. Here is a picture of the old springplate with the markings . I have not removed the old springplate but have marked with an awl the angle on the frame. see pic. When I replace this How do I install it? I know get bentley manuel which I dont have . I want to set it stock. Does it look stock from this picture? Should I just copy the marks from the old plate to the new plate? Can someone post the bentley page. I know it s not that tough but Im bad at geomeotry and want to get it right . Help ! If someone can just post how to install a stock springplate setting. IE place protractor on then step two etc. Do u grease the bushings ?
. By the way the right side is the same and the marks are off by one teeth on both sides.
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12548 Location: Over 2002 posts deleted!
Posted: Fri Aug 20, 2010 1:38 pm Post subject: |
Even with the "correct" instructions, how does anyone know just how many inner splines they have adjusted when you can't see in there????  _________________ Some people are so busy being clever they don't have time enough to be wise. |
hsosa1 Samba Member
Posted: Fri Aug 20, 2010 1:43 pm Post subject: |
Im barely understanding the outside splines. I guess that s why need a protractor which I have no idea how to use... Anyone ? Ive scoured the samba for instruction on how to install for stock plates ...no luck just loweing them. bentley online somwhere I can just post the page here ... _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
pyrOman Fire Master
Posted: Fri Aug 20, 2010 1:51 pm Post subject: |
It isn't rocket science though. I've done it hunnerts of times even without an angle finder (a.k.a. protractor). Here, I'm setting up mine for IRS.
Whatever angle you set on one side, just match it on the other.  _________________ Some people are so busy being clever they don't have time enough to be wise. |
sventinker Samba Member
Joined: June 10, 2009 Posts: 1481 Location: the sandbox
Posted: Fri Aug 20, 2010 1:54 pm Post subject: |
hsosa1 wrote: |
Im barely understanding the outside splines. I guess that s why need a protractor which I have no idea how to use... Anyone ? Ive scoured the samba for instruction on how to install for stock plates ...no luck just loweing them. bentley online somwhere I can just post the page here ... |
I read the page and I bought a protractor with a magnet from HF I couldn't understand the instructions but if you like I'll try and translate it to you tonight. _________________ April 3rd 62 standard mgr/pw
374 North American equipment
Includes 6 popouts
025 Safety belts
195 Adjustable bench seat/backrest (until 1963)
dawerks wrote: |
Perfection only comes with delusion. |
http://www.oacdp.org/ |
