Joined: May 01, 2003 Posts: 178 Location: camas washington
Posted: Fri Jun 16, 2006 4:06 am Post subject: Front floor insulation under carpet, Replace with?? |
Just cleaned up the floorpans on my girlfriends squareback and peeled out the tar/ foam boards that are under the drivers and pass feet. What have you guys been using under your carpet up front? First night with the squareback!
thanks
shawn _________________ 72 ASI Bus "Mill"
66 Singlecab
68 Squareback
62 Ragtop Bug
77 Westfalia |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35952 Location: Conejo Valley, CA
Posted: Fri Jun 16, 2006 8:41 am Post subject: |
Those pads were designed well. The sandwich design meant that vibrations were not transmitted through them, making them more effective at sound deadening. Also they were cheap. Try to replicate the layers with foam and some other heavier material. The damn stickyness is a pain but it made them more effective at muffling sounds of all frequencies. Mine are original, and I haven't had to find replacements, but I'd look hard for something layered like the factory ones. |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Fri Jun 16, 2006 8:59 am Post subject: |
isn't there a replacement tar-board kit for Type 1's? if so, couldn't you use this (modified, of course) as a replacement? _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
ddare Samba Member
Joined: January 10, 2005 Posts: 583 Location: Cypress, CA
Posted: Fri Jun 16, 2006 11:49 am Post subject: |
i am using this stuff called polymeric mastic. Rather, will be using, once I finish paint and put the body back on the pan. You can get it from http://www.mcmaster.com/
It's kind of like tar board but I think more plastic than asphalt, apparently has pretty good sound deadening properties. that with a layer of jute carpet padding should do. jute padding is absorbent, so i wouldn't recommend it if you have any leaks in your windshield seal, pan, doors etc but its super cheap.
There was another guy that did his squareback in 2layers of polymeric mastic, said it worked out well, i think he has pictures posted. |
Crippler Samba Member
Joined: November 01, 2005 Posts: 614 Location: Victoria, TX
Posted: Fri Jun 16, 2006 11:52 am Post subject: |
i ordered four sheets of polymeric mastic from McMaster Carr. it covered everything, sound dampened, and i have some left over.
 _________________ 1973 VW bus |
urchin Samba Member
Posted: Fri Jun 16, 2006 5:42 pm Post subject: |
If you live in a wet area like me water is always a problem. I use ice and water sheild that they use for roofing or I use a product called blue skin makes the entire floor water proof. The carpet wants to slide around some but at least the pan stays dry even with a inch of water in it. I have done it to at least 10 different cars/vw caddys and my sq back. The caddys are always filled with water to the point of needing drain holes but the metal stays dry. |
rloaircool Samba Member
Joined: January 21, 2004 Posts: 304 Location: Idaho Falls, Idaho
Posted: Sun Jun 18, 2006 2:52 am Post subject: |
urchin wrote: |
Do you have any more information or a source on that blue skin product? I tried a google source but just came up with a bunch of skin cream. Thanks. |
urchin Samba Member
Posted: Sun Jun 18, 2006 3:35 am Post subject: |
Go to a building supply co. Home depot maybe. Its for waterproofing foundations Ice and water sheild which is a underlay for roof shingles is similar although not quite as sticky. I also put down absorbant spill pads soaked in trans fluid in the lower part of the pans ( foot areas) Then the blue skin only sticks to the perimiter. It is very very sticky so a cool day is better to try and manouver the stuff. Try a little piece of it first to see how it feels. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16803 Location: State College, PA
Posted: Sun Jun 18, 2006 7:17 pm Post subject: |
Would you say the the polymetric mastic is equivilant to dynamat? Getting ready to get into this part on my 69. _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
x43x Samba Member
Joined: October 10, 2002 Posts: 126 Location: Renton, Moshington
Posted: Tue Jun 20, 2006 12:05 am Post subject: |
It functions the same as Dynamat for much less money, but doesn't have the fancy looks. The stuff I got is asphalt based, so it's pretty heavy, but thin. Dynamat also has some heating properties for keeping the cab cool, but I'm not sure if the polymeric does the same thing. It dampens engine and road noise really well in my car. Here's a link to an old thread of my install.
http://www.thesamba.com/vw/forum/viewtopic.php?t=144038&highlight=polymeric+mastic |
Posted: Tue Jun 20, 2006 4:08 am Post subject: |
So - it almost looks like tarboard, but nicer - easy to work with? By the way, your interior looks GREAT! _________________ D-Dubya Manx clone 1914. Ex wifes car.
x43x Samba Member
Posted: Tue Jun 20, 2006 8:45 am Post subject: |
Its really easy to work with. It comes in large sheets with a super sticky side that has paper to peel off when you're ready to apply. I used a carpenter knife and a razor blade to cut my pieces out. |
Posted: Tue Jun 20, 2006 9:52 am Post subject: |
[email protected] wrote: |
Did you have to use extra glue, or does the adhesive work good enough. I ordered a bunch a while ago from mcmaster-carr, am just about ready to put it in. |
x43x Samba Member
Posted: Tue Jun 20, 2006 5:46 pm Post subject: |
I didn't use extra glue. The stuff is pretty damn sticky and should work well if the surface is nice and clean. When cutting out your pieces, don't take the backing off until you get it exactly the way you want it, or else its a bitch to peel back off and readjust. |
