Eurovan rear heat question.
DAVEURO
DAVEURO is offline
PostPosted: Sat Jun 24, 2006 12:24 pm    Post subject: Eurovan rear heat question. Reply with quote
My 93 Euro has rear heat. I found the rear heater core and fan unit under the van the other day. It is right about at the center seats and has a removable plug/panel on the interior. Is this just to clean it out or is there an accessory that also could goe here like on an upgraded model? Mine is a base model. It looks like a grill to let the heat out might be an idea. I have an appreciation for all VWs and froze my butt, not to mention my fingers and toes off on the way to work when it was below 15 degrees outside in my old bugs. I just want to utilize my heater since it has one.
T2T4
T2T4 is offline
PostPosted: Thu Jun 29, 2006 2:42 pm    Post subject: Rear heat Reply with quote
My 93' GL has a pull up vent under the second seat, and the rear heat works great. has a seperate fan switch on the dash...Yes, my 67' Bus, best heater was a good coat, gloves, and cap.
