balance tube
smitty
smitty is offline
PostPosted: Tue Jul 18, 2006 6:04 pm    Post subject: balance tube Reply with quote
Hey all, just looking for some info on carburetor balance tubes. I have a set of Solex PDSIT 32s but I'm missing the balance tube. The manifolds are dual port and the spigots for the tube are 8mm but the bracket (which also supports the aircleaner) the tube runs through is much larger, say 14mm. Now for the Q&A... Is there supposed to be a grommet in the bracket? Whats the ID and the OD of the tube supposed to be (approx.)? What happens if the tube is larger/smaller/eliminated?
thanks for playing!
Russ Wolfe
Russ Wolfe is offline
PostPosted: Tue Jul 18, 2006 6:59 pm    Post subject: Reply with quote
Should be a piece of rubber around the tube where it goes through the center bracket.
I made my balance pipe when I did my conversion to dual port from some 5/16" gas line from the local parts store.
http://classicvw.org/gallery/main.php?g2_view=core.ShowItem&g2_itemId=1767
You can kinda see it in that picture.
Gary: OK. Ima poop.
smitty
smitty is offline
PostPosted: Tue Jul 18, 2006 9:44 pm    Post subject: Reply with quote
Works for me. Thanks Russ
PostPosted: Tue Jul 18, 2006 10:05 pm    Post subject: Reply with quote
The 64-66 balance tube for the single port engines is larger:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=291340
They retained the same center bracket for '67, which used a smaller balance tube, so a bushing was used to make up the space.
If anyone needs a 64-66 big balance tube, I have some for sale.
jimmynotch
jimmynotch is offline
PostPosted: Tue Jul 18, 2006 10:31 pm    Post subject: Reply with quote
What happens if one usd a smaller diameter tube for SP? Is there a change in performance?
Jim in Sacto -
my wonderful loving supportive wife wrote:
You guys are dorks.
1965 1500-S Notchback --"Maggy"
1971 Type 2 Double Cab --"George"
TOOB member #2
PostPosted: Tue Jul 18, 2006 10:35 pm    Post subject: Reply with quote
Assuming you could get the tubing to make it work, I think it would just be harder to balance the carburetors correctly? I don't know what would happen when driving.
mr. warehouse
mr. warehouse is offline
PostPosted: Tue Jan 02, 2007 12:32 pm    Post subject: Reply with quote
Digging up an old thread.......
I was adjusting the carbs on my Square yesterday and noticed no balance tube (I'll fix that) but 2 spigots coming oiut of each manifold for a total of 4 spigots.
2 balance tubes or what??
Aside from the typical #3 acting funny at idle everyhing else is smooth.
BerT3
BerT3 is offline
PostPosted: Tue Jan 02, 2007 1:47 pm    Post subject: Reply with quote
http://bert3s.com/osCommerce/catalog/images/connectors.jpg
This in combination with a different vacuum balancer tube
BerT3
mr. warehouse
PostPosted: Tue Jan 02, 2007 5:19 pm    Post subject: Reply with quote
Perfect, that's what I needed to know.
I'll make some here unless anyone has some for sale??
