Mr. Loaf Samba Member
Joined: March 30, 2005 Posts: 2098 Location: Okra, Oklahoma
Posted: Thu Jul 20, 2006 9:51 am Post subject: Vertex Magneto |
Not sure if I am asking this question in the correct forum but thought I would try it here. I obtained a brand new Vertex Magneto for a VW at an estate sale. $25.00 seemed well worth it to me although I didn't know what I was going to do with it. The magneto is still in it's original box and is clearly for VW applications. Since I know nothing about the affect of magnetos when used in VW's could some one here please tell me what to expect or not to expect from using one. Is your coil eliminated from you ignition system. Will my engine run hotter if I use the magneto? What about starting? Is there a problem with this? Are there any gains to be made with using one? I do not race this car, it is my daily driver. Thank you for your replies. _________________ Never drive faster than your Angel can fly
$24,100 was too hard to resist................. |
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9757 Location: Elizabeth, NJ & La Isla Del Encanto
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9016 Location: Portland, OR
Posted: Thu Jul 20, 2006 10:45 am Post subject: |
| I remember back in the 80s it seemed as though they were fitted to all the drag cars. They need a support bracket--heavy. |
RIS Samba Member
Joined: December 18, 2003 Posts: 3044 Location: Youngstown, Ohio
Posted: Thu Jul 20, 2006 12:46 pm Post subject: Re: Vertex Magneto |
Good deal for $25.00!
First thing I'd do is make sure it works, and then find out if it has an advance mechanism or if it's locked out. Alot of these units are locked out for racing reliabilty and/or turbo use. If it's locked out starting can get interesting...
The magneto is completely self contained, it has it own coil and produces its spark without an outside 12V source. The faster it spins the more powerful the spark. What it does need is a kill switch so you can shut the engine off.
Depending on your engine combination it may be beneficial, but alot of people dig them just for looks... _________________ Richard Sedoris - VW Performance & Machine - Youngstown, OH
http://rismachine.tumblr.com/
YouTube: https://m.youtube.com/channel/UCfTBCG4I61iVm_ROc8OAuOQ
Instagram: @rismachine |
sprbxr Samba Member
Joined: October 04, 2004 Posts: 108 Location: Sleepy Hollow
Posted: Thu Jul 20, 2006 3:50 pm Post subject: |
If it has no advance mechanism it is most likely a magneto from an Industrial engine. These engines were mostly used in constant RPM applications. _________________ 1957 Oval Ragtop
1974 Thing
1966 Deluxe
1959 Panel
1967 Vert
1959 Semaphore Ragtop |
Posted: Thu Jul 20, 2006 8:11 pm Post subject: Advance |
It does have an advance mechanism. 11 1/2 degrees. _________________ Never drive faster than your Angel can fly
oc63rag Samba Member
Joined: June 03, 2003 Posts: 2663 Location: Huntington Beach, CA
turboblue Samba Member
Joined: October 09, 2003 Posts: 4216 Location: Central Indiana
Posted: Fri Jul 21, 2006 7:58 am Post subject: Re: Advance |
| mkkraemer wrote: |
| It does have an advance mechanism. 11 1/2 degrees. |
Wanna double your money??
There is a screw on the side that you have to wire thru a switch to shut it off.
One side of the switch is wired to that screw, the other to a good ground.
On a normal switch, you have to turn it off to make the engine run, circuit is interrupted.
Turn the switch on to kill the engine, circuit closed.
Bad part is one can steal your car if they know how mags work by taking that wire off the mag then push starting it. _________________ Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!" |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80617 Location: Sneaking up behind you
Posted: Fri Jul 21, 2006 8:00 am Post subject: Re: Advance |
| turboblue wrote: |
| Bad part is one can steal your car if they know how mags work by taking that wire off the mag then push starting it. |
Thanks for the tip
Other than being "self contained" is there a performance improvement say over a Mallory Unilite?
I'd imagine that spinning a magneto will cause alot more wear on the brass crank drive gear than a standard distributor. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Fri Jul 21, 2006 8:21 am Post subject: Re: Advance |
| Glenn wrote: |
| turboblue wrote: |
Thanks for the tip
I'd imagine that spinning a magneto will cause alot more wear on the brass crank drive gear than a standard distributor. |
I don't like them much other than they look cool.
Don't know anout the wear on the gear other than it about has to be tougher on them than a regular dizzy.
I ran one and didn't care much for it, parts are expensive too.
MSD, Mallory or about any other modern distributor are as good or better than decades old magneto technology IMHO.
Yeah that "tip" wasn't meant to be theft instructions but a warning for the street mag guys.......  _________________ Gary
Sacr32 Samba Member
Posted: Fri Jul 21, 2006 2:22 pm Post subject: Re: Advance |
| turboblue wrote: |
| mkkraemer wrote: |
Not like it's hard to run a wire from the starter to the coil either for the same effect.
Oh and don't spin it in your hand or you may get a new hair style. |
Posted: Fri Jul 21, 2006 2:46 pm Post subject: Re: Advance |
| Sacr32 wrote: |
| turboblue wrote: |
| mkkraemer wrote: |
Actually easier from the alt/gen B+ post to the coil + but I didn't say that out loud.
Yeah a mag will bite pretty hard if you mess with it...........  _________________ Gary
Calisupastarz Samba Member
Joined: January 25, 2005 Posts: 610 Location: Sylmar, California
flatfour Samba Member
Posted: Fri Jul 21, 2006 3:40 pm Post subject: |
I used to run one a dedicated drag race car and they worked ok, but they are heavy, and can wear the gear out. I ended up switching to MSD much more options as far a rev limiting and other bell and whistles.
There are a few companies that make two stage rev limiters for Mags such as Wyotech and a single stage limiter by Autometer. For a street the only reason I could see anyone having one is for the look. Just my opinion. |
