edgruberman Samba Member
Joined: July 08, 2005 Posts: 69 Location: Carlsbad (San Diego)
Posted: Thu Aug 10, 2006 8:35 pm Post subject: 2 heater knobs? |
My '66 deluxe has two holes under the drivers seat for heater knobs, one of which is occupied. It looks like the empty hole has wear around it -- like it had a knob at one point possibly? My m-code says something about a delete plate and I think it means the plugged heater branch near the back where one tube goes to the back seat. So, should I have another heater knob hooked up to the left heater box to control the heat in back? _________________ Looking for...
- fuse cover (8-fuse for my '66 bus) |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71584 Location: Phoenix 602
Posted: Fri Aug 11, 2006 8:32 am Post subject: |
The single heat knob controls both cables.
I think the other hole is either something someon added or possibly for a gas heater. Does it appear to have had a gas heater installed?
The "plugged tube" is normal for a Standard or Deluxe Bus as one heater box goes directly to the back seat outlet and one comes up front instead of both heading up front.
What does your M-code plate say? _________________ How to Post Photos
Posted: Fri Aug 11, 2006 9:04 am Post subject: |
The code I was referring to:
002 - USA sealed beam headlights, Pre-heat flap delete
As for the other hole...it looks pretty stock. I will take a picture when I get home. I also have the full m-code at home so I'll post that. These pics are some I found in the gallery of my bus before I bought it. What might be evidence of a gas heater? Is this where it would have been?
Here's a pic -- there is some sort of knob but it isn't there anymore.
_monkey_ Samba Monkey
Joined: April 11, 2005 Posts: 1584 Location: New England
Posted: Fri Aug 11, 2006 9:15 am Post subject: |
edgruberman wrote: |
That is where the gas heater would go. What's that cable that seems to be just hanging right there? Maybe that is the no longer connected gas heater control cable? |
Posted: Fri Aug 11, 2006 9:59 am Post subject: |
Okay, so I think I can be sure it had a gas heater. It looks like there could be some aftermarket ones and some dealer installed ones. Is there any way to tell? The engine compartment pic shows a delete plate in the tire well and maybe the knob is a giveaway. Any clues? I am so excited...there is ANOTHER thing I can try to find for my bus. _________________ Looking for...
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9016 Location: Portland, OR
Posted: Fri Aug 11, 2006 2:31 pm Post subject: |
Those are controls for an Eberspacher BN4 6-volt gas heater.
That big wad of fiberglass is covering a rectangular hole next to your wheelwell. The heater duct passes through that. Do a gallery search for "BN4" so you know what you are looking for.
That switch lights up when turned on. |
Tim Samba Member
Joined: September 04, 2003 Posts: 170 Location: Texas
Posted: Fri Aug 11, 2006 4:38 pm Post subject: |
Here is a picture that shows the BN4 installed:
_________________ How we spend our days is, of course, how we spend our lives.
Annie Dillard
55 Rag Top
67 Westy |
arthurnugen Samba Member
Joined: January 11, 2005 Posts: 3081 Location: The PNW, where "going green" means rolling with moss.
Posted: Fri Aug 11, 2006 4:50 pm Post subject: |
Major Woody wrote: |
I have the same ivory switch for my Stewart-Warner heater, except it is to the right of the regular heater knob. Did SW and Eberspacher use the same switch? Mine doesn't light up and I doubt that one does, but I could be wrong. Could have had an SW in there. _________________
cdennisg wrote: |
Lawyers don't deserve buses. |
zozo wrote: |
Don't worry too much. You can always trust a lawyer. |
ALWAYS WEAR STEEL-TOE BOOTS IN THE GARAGE!
1965 Bus (Riviera camper)
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
1957 DKW 3=6: 3 cylinder 2 stroke! |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19836 Location: Land of Whine and Phonies
Posted: Sat Aug 12, 2006 3:28 pm Post subject: |
arthurnugen wrote: |
I have the same ivory switch for my Stewart-Warner heater, except it is to the right of the regular heater knob. Did SW and Eberspacher use the same switch? Mine doesn't light up and I doubt that one does, but I could be wrong. Could have had an SW in there. |
They used different switches. that picture doesn't look like a German switch to me. If you pull the switch out and can turn it to click it on it isn't a BN4 switch.
BN4 switch-
it lights up and this is the correct cover-
_________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sat Aug 12, 2006 7:37 pm Post subject: |
Here are the manuals for both the Eberspacher and the Southwind heaters.
http://classicvw.org/eberspacher/
Both put the switch below the drivers seat, except for a few special heaters. These were mounted under the dash, on the passengers side, and were very rare. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Sat Aug 12, 2006 8:50 pm Post subject: |
So both heaters would have needed to remove the spare tire well? It would seem at first glance that the SW did and the Eberspacher didn't. _________________ Looking for...
Posted: Sat Aug 12, 2006 10:49 pm Post subject: |
All I know is my switch is under the passenger seat in what looks like a stock switch area. Go figure. _________________
cdennisg wrote: |
zozo wrote: |
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
Posted: Sat Aug 12, 2006 10:56 pm Post subject: |
With the Southwind, you had to remove the spare tire well on a walkthru.
With the Eberspacher, you did not.
I don't know about the switches. |
Posted: Sat Aug 12, 2006 11:03 pm Post subject: |
So both heaters would have needed to remove the spare tire well? It would seem at first glance that the SW did and the Eberspacher didn't. |
My SW is pretty bulky compared to the Eber, which is pretty streamlined. Of course, my camper was built from a panel (no rear vents) so the spare tire well was not an issue with the bench seat arrangement. _________________
cdennisg wrote: |
zozo wrote: |
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
Lind Samba Member
Joined: November 06, 2000 Posts: 10225 Location: idaho
Posted: Sat Aug 12, 2006 11:34 pm Post subject: |
Okay, so I think I can be sure it had a gas heater. It looks like there could be some aftermarket ones and some dealer installed ones. Is there any way to tell? The engine compartment pic shows a delete plate in the tire well and maybe the knob is a giveaway. Any clues? I am so excited...there is ANOTHER thing I can try to find for my bus. |
I used to own that bus.
it had a stewart warner southwind gas heater that was removed before I got the bus.
there are very few things that the bus is missing. _________________ .
Wanted:
Posted: Sun Aug 13, 2006 9:00 am Post subject: |
Cool! I'm glad to hear a little history about my bus. I am not going to try to find a heater to put in it after all...I like the spare tire well where it is. I might make an effort to block off the hole between the cabin and the engine compartment a little better to keep any fumes out. For what it is worth, I am taking good care of it and keeping it original with only old stock repairs here and there. _________________ Looking for...
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26036 Location: Olympia Wash Rinse & Repeat
Posted: Sun Aug 13, 2006 9:49 am Post subject: |
Hi edgruberman,
Get rid of the loose fiberglass in the engine compartment. Seal off the hole with sheetmetal instead. Even if the fiberglass main body stayed where it is. Bits of it will come off and clog off cooling slots on the engine under the cooling tins. _________________ In Stereo, Where Available! |
derv Samba Member
Joined: October 12, 2005 Posts: 2601 Location: Oak Park (Chicago), IL
Posted: Sun Aug 13, 2006 11:11 am Post subject: |
Here is the heater knob in the Casino Kombi - which is the first bus I have owned that is plumbed for a gas heater (besides a fatchick)...
And here is the ductwork with the control cable and elec wire still in place...
_________________ Jack
Quote: |
Mr. Hido: To post your bare ass to virtually all hardened bus enthusiasts casts thick, a slag not easily ground smooth. |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Sun Aug 13, 2006 11:53 am Post subject: |
