vincentrc Samba Member
Joined: May 18, 2004 Posts: 237 Location: Fullerton, CA
Posted: Wed Aug 09, 2006 6:12 pm Post subject: T3 Wiring |
Well, I already did some research on a wiring harness for the T3, and am not sure what the best wiring harness kit out there is. I have a 1966 Fastback and I need to redo the wiring because mine is frayed, cut, and mickey moused beyond being fixed. ANy input on what harness anyone prefers would help me out alot, and I' am up for the challenge of installing harness.
-Thanks. _________________ loading... |
69sqbck Samba Member
Joined: August 12, 2004 Posts: 311 Location: Savannah, GA
Posted: Thu Aug 10, 2006 4:31 pm Post subject: harness |
I would go with the stock style replacement from ISP WEST
http://www.vwispwest.com/cgi-bin/perlshop.cgi?ACTI...=797859513 _________________ Don't think of yourself as an ugly person, think of yourself as a good looking Monkey!!!!!
1968 Ghia Vert
1969 Type 3 Squareback
1969 Type 3 Fastback
(o)\|/(o) Sole Designs, VW Restorations, Savannah, GA |
spoon Samba Penetrator
Joined: September 08, 2005 Posts: 1458 Location: Monterey, CA
Posted: Thu Aug 10, 2006 5:02 pm Post subject: |
HOw much of a bitch is it to replace a whole wiring loom anyway? Mine is all Mickey Mouse'd as well, causes me all sorts of issues! _________________ Pit Bull Myths, Busted!
http://www.badrap.org/monster-myths
| EverettB wrote: |
| Type 3 > Type 1 |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25186 Location: Central Iowa
Posted: Thu Aug 10, 2006 5:22 pm Post subject: |
| spoon wrote: |
| HOw much of a bitch is it to replace a whole wiring loom anyway? Mine is all Mickey Mouse'd as well, causes me all sorts of issues! |
Depends on the body style. If the harness runs along side the drivers seat under the carpet, it is not too bad. On some of the early ones, and the T-34's, the harness runs through a conduit in the rocker panel.
Anytime you pull it through a hole or a panel, tie a strong cord onto it to pull the new one back in. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
jimmynotch Samba Member
Joined: February 11, 2003 Posts: 2901 Location: sacramento
Posted: Fri Aug 11, 2006 2:18 am Post subject: |
| spoon wrote: |
I did mine in a weekend on my 65. The harness runs through rocker and I had to remove both the front and rear fender, but that gave me oppertunities to do other stuff under there at the same time. Its not hard at all, and you can pull some of your own wiring through with it for accessories later on (tach, other guages, etc) _________________ Jim in Sacto -
| my wonderful loving supportive wife wrote: |
| You guys are dorks. |
1965 1500-S Notchback --"Maggy"
1971 Type 2 Double Cab --"George"
TOOB member #2 |
localboy Samba Longboarder
Joined: December 06, 2003 Posts: 5153 Location: "Mainland", PNW
Posted: Sat Aug 12, 2006 7:07 pm Post subject: |
| Russ Wolfe wrote: |
The only real issue I had on the '65 was the old OG harness going thru the conduit. It was stuck...I mean stuck. I put a small rod down and pulled out a bunch of sand/dirt. We were finally forced to use a 5' long, bladed drill bit on a rechargeable drill. In-out-in-out...slowly until we broke past the blockage and were able to pull the remaining harness out of the back. By my estimate we got about 5-6 tablespoons of crap out of the tube. But the new harness went in like butter. Pulled about 6 extra wires thru with it. Some are to be used; two extra are just in case... _________________ One man's "patina" is another man's cancer...
Black '65 Resto-Custom S Notch 2110 cc powered
original paint Pearl White '66 Westy SO-42
Allstate single-wheel trailer project |
Posted: Sat Aug 12, 2006 8:41 pm Post subject: |
Speaking of butter, Get some wire pulling compound at your local electrical supply store. It will help greatly in pulling thru the tight places.
Don't just use oil or grease, and that can deteriorate the wires. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23603 Location: Kimball, Mi
Posted: Sun Aug 13, 2006 8:59 am Post subject: |
| spoon wrote: |
The only drawback to the new harnesses available is that they are for carbed cars. This means they don't have the couple of extra wires in them needed for the FI to run. Just something to think about. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
Posted: Mon Aug 14, 2006 11:51 am Post subject: |
| Bobnotch wrote: |
The only drawback to the new harnesses available is that they are for carbed cars. This means they don't have the couple of extra wires in them needed for the FI to run. Just something to think about. |
WTF? Well that's just perfect. What am po peepo like me s'pozadoo?  _________________ Pit Bull Myths, Busted!
| EverettB wrote: |
| Type 3 > Type 1 |
Posted: Mon Aug 14, 2006 11:54 am Post subject: |
I obviously don't do fuel injection, but can't you just add the required wires when pulling the new harness thru? Tram? Russ?  _________________ One man's "patina" is another man's cancer...
Posted: Mon Aug 14, 2006 12:22 pm Post subject: |
| localboymark wrote: |
I obviously don't do fuel injection, but can't you just add the required wires when pulling the new harness thru? Tram? Russ?  |
I am assuming so. All the wires do is transmit voltage where/when voltages is supposed to be transmitted right? Do any of you have a diagram for what wires need to be added? George? Russ?  _________________ Pit Bull Myths, Busted!
| EverettB wrote: |
| Type 3 > Type 1 |
Posted: Mon Aug 14, 2006 6:31 pm Post subject: |
Yeah, you could just pull the needed wires through with the new harness. Power wires from the relay under the rear seat, and the wires that go from the ECU to the fuel pump relay up front. There may be others that I am not thinking about. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
notcho64 Samba Member
Joined: April 08, 2006 Posts: 213 Location: Verdi, NV
Posted: Mon Aug 14, 2006 8:10 pm Post subject: |
I installed a new wire harness a few months ago and it went pretty smooth. I had to remove the left front/rear fenders of coarse but I failed to run extra cables for "other electrical stuff"...tach/temp/etc.
Is there a tube in the right passenger rocker panel as well for other cables? _________________ 1960 15 Window - Current Ride
1957 PGSG Kombi - Sold
1963 Ragtop/Air Ride/Turbo Bug ( I should have never bought it)
64 1500S Notchback (I should have never SOLD it)
www.norcalaircooledgroup.com
NAG#9 |
HenrikL Samba Member
Posted: Wed Dec 21, 2016 1:43 pm Post subject: |
| jimmynotch wrote: |
| I did mine in a weekend on my 65. The harness runs through rocker and I had to remove both the front and rear fender, but that gave me oppertunities to do other stuff under there at the same time. Its not hard at all, and you can pull some of your own wiring through with it for accessories later on (tach, other guages, etc) |
I realise that the rear fender must be removed, but is there any change changing the wiring loom without removing the front fender? |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 5328 Location: Southern AB
Posted: Wed Dec 21, 2016 3:02 pm Post subject: Re: T3 Wiring |
it has to come out of the cabin, then down, and back in the channel, not much chance of doing that with the fender on.
_________________ 1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap |
