jbow1076 Samba Member
Posted: Sat Aug 19, 2006 11:47 am Post subject: SCAT shifter installation |
I am tyring to install a SCAT shifter in my 1970 fastback and am have a little bit of a problem. After trying to install in numerous times I keep getting the same result, I can't get 3rd and 4th gear and when I put it in reverse I don't need to pull up on the release lever to do it. What am I doing wrong? Should it be this hard or am I riding the short bus today? Thanks for the help! |
Ace Samba Member
Posted: Sat Aug 19, 2006 11:57 am Post subject: |
loosen the 2 bolts and move it over to the right as far as possible and tighten. See if that works. |
Posted: Sat Aug 19, 2006 12:07 pm Post subject: |
I've tried moving it in that direction and I still can't get in those gears. The metal plate off the original stick shift I have been leaving off, but I have tried it with it on and I get the same result. Does it matter if it is on or off though? thanks |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Sat Aug 19, 2006 12:10 pm Post subject: |
I know when I installed my EMPI (crap) shifter, I had to clearance the bolts holes a smidge, because of the same issue....
I just took a drill bit and drilled the holes larger in that direction about 3, maybe 5 mm....
reinstalled it and tadaa! I had all four gears...
then I installed my Hurst and dumped the EMPI.... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Posted: Sat Aug 19, 2006 1:31 pm Post subject: |
I've made the holes large now and when I go in first gear and then shift into second it grinds the gears because it is trying to go into reverse. What am I doing wrong. I am about to throw this stick shift down the street. Please help me before I do something I am going to regret! Help!!!! |
djporsche Samba Member
Posted: Sat Aug 19, 2006 1:40 pm Post subject: |
Tap it to the right (pass side) a hair. Try to meet it in the middle. |
