Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80540 Location: Sneaking up behind you
Posted: Mon Aug 21, 2006 6:39 pm Post subject: This is a Beetle and that is a Super Beetle |
There's been alot of questions about how to tell a Beetle from a Super Beetle so this is to help.
The easiest way to tell is that the spare tire in a Super lays flat while a Beetle stands up.
Beetle
Super
Beetle
Beetle Convertible to 1970
Super 1971-1972
Super 1973-1977
Super Convertible 1971-1972
Super Convertible 1973-1979
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
hazedub Samba Member
Joined: July 25, 2006 Posts: 97 Location: Near Charlotte, NC
Posted: Mon Aug 21, 2006 7:25 pm Post subject: |
| To add onto this, you can also tell by the front air vents under the front bumbers.... Another way not easily seen by the non looker is the wider fenders, these are just two other ways of telling a Super from a Beetle |
Glenn  Mr. 010
Posted: Mon Aug 21, 2006 7:29 pm Post subject: |
| hazedub wrote: |
| To add onto this, you can also tell by the front air vents under the front bumbers.. |
Many Supers have replacement front aprons without the AC condenser vents. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Tue Aug 22, 2006 7:33 pm Post subject: |
| Glenn wrote: |
| hazedub wrote: |
Many Supers have replacement front aprons without the AC condenser vents. |
This is true, forgot about that. But the ones that dont you can recognize them by that way. |
jadvale Samba Member
Posted: Wed Aug 23, 2006 11:38 am Post subject: |
| I've always relied on the curved windshield and wider dash on Supers. |
ScottK Samba Member
Joined: August 28, 2004 Posts: 1748 Location: Avilla America
Posted: Wed Aug 23, 2006 11:50 am Post subject: |
| jadvale wrote: |
71 and 72 supers had a flat windshield.
Scott |
olde skool Samba Member
Posted: Wed Aug 23, 2006 1:25 pm Post subject: |
| Quote: |
Scott |
71 and 72 supers also had the same dash as a standard If i'm not mistaken |
Posted: Thu Aug 24, 2006 4:29 am Post subject: |
My bad. Thanks for clarifying.  |
choppachris Samba Member
Joined: May 15, 2006 Posts: 258 Location: Los Fresnos, TX
Posted: Thu Aug 24, 2006 12:48 pm Post subject: |
look for the long front hood, and the very bottom front of the car kinda rolls under the car.  _________________ dubless |
Pont Samba Member
Joined: December 29, 2005 Posts: 166 Location: Lexington, TN
Posted: Thu Aug 24, 2006 1:38 pm Post subject: |
| Someone should post up some good pics of the suspension upfront that is one of the top 3 ways of telling which is which |
Glenn  Mr. 010
Posted: Thu Aug 24, 2006 1:39 pm Post subject: |
| Pont wrote: |
The spare tire doesn't lie. If it's flat it's a Super, there's nothing else you need to look at. _________________ Glenn
Member #1009
#BlueSquare
Pont Samba Member
Posted: Fri Aug 25, 2006 12:34 am Post subject: |
| Glenn wrote: |
| Pont wrote: |
The spare tire doesn't lie. If it's flat it's a Super, there's nothing else you need to look at. |
True but your always gone have those peeps that disagree with you  |
Glenn  Mr. 010
Posted: Fri Aug 25, 2006 3:02 am Post subject: |
| Pont wrote: |
| Glenn wrote: |
| Pont wrote: |
It's a fact... there is nothing to disagree about.  _________________ Glenn
Member #1009
#BlueSquare
Beetspeed Samba Member
Joined: July 30, 2004 Posts: 434 Location: The Netherlands
Posted: Fri Aug 25, 2006 4:00 am Post subject: |
| choppachris wrote: |
look for the long front hood, and the very bottom front of the car kinda rolls under the car.  |
Yes, the down-curved, rounder front fenders are the easiest part if the car in question is parked and you cannot look under the front hood.
But you need to know what to look for in the fender form, thats true.
In Europe, the 70-72 cars are called 1302 (L/S/LS)model and the model '73 (as of august '72) is always called 1303, (L/S/LS).
Its easy for us, as they all have either 1302 or 1303 on the rear hood (if they still are original that is)  _________________ '75 SB 1303 2,4ltr T4 turbo: 10.58 @ 129.9mph
'65 Ruska buggy 1192cc EFI 90hp N/A |
Lbhat Samba Member
Joined: July 23, 2006 Posts: 4 Location: San Diego,CA
Posted: Wed Aug 30, 2006 5:47 am Post subject: Flat Super? |
so...? I could find a 71 or 72 flat windshield Super with the spare laying flat? with struts too? |
Glenn  Mr. 010
Posted: Wed Aug 30, 2006 5:48 am Post subject: Re: Flat Super? |
| Lbhat wrote: |
If the tire is laying down then it's a Super and has struts. 71-72 Supers had a flat windshield and 73-79 had a curved one.
It's that simple. _________________ Glenn
Member #1009
#BlueSquare
yaz731200 Samba Member
Posted: Wed Aug 30, 2006 1:21 pm Post subject: |
i no the difrences between the super and normal beetle im jsut wondering whyy they made the diferent kinds?
was it like a more expencive model when you bought the beetle or was it two difrent factories making two difrent beetleS? |
Buzzbug72 Samba Member
Joined: August 30, 2004 Posts: 73 Location: Houston TX
Posted: Thu Aug 31, 2006 1:58 pm Post subject: |
I have a 72 super. Flat windshield, lay-down spare, strut front-end.
They made the supers to update the suspension to modern type of supspension. Better handling and better ride quality. _________________ 1972 German Look Super (O\ | /O) |
Kelley Samba Member
Joined: April 03, 2003 Posts: 1432 Location: "Die Sonneküste" Crystal Beach, FL
Posted: Thu Aug 31, 2006 2:39 pm Post subject: |
| Buzzbug72 wrote: |
| They made the supers to update the suspension to modern type of supspension. Better handling and better ride quality. |
When it's maintained properly,,, one bad suspension component can make the others wear that much faster. 45-55 mph speed wobbles is one result. There are others. _________________ 74 rusto-custom type 1 Sedan - SOLD
ZRX1100c3, Mean Green - SOLD
| Growler wrote: |
| I hate people. Are you people? I hate you. |
Just trying to remember classic Samba quotes from the 'Days of Yore' |
Posted: Thu Aug 31, 2006 2:52 pm Post subject: |
Right, but that is the owners fault for neglecting it, not the engineering of it. _________________ 1972 German Look Super (O\ | /O) |
