mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Wed Oct 11, 2006 9:06 am Post subject: Early Westy interior panel restoration |
I've finished redoing all my interior panels in my 81 Westy except the one behind the stove/sink, so I figured I show everyone how I did mine.
One of the problems of the early Westy's is the thin vinyl that was used to cover the interior panels, It had a bad tendency of cracking and pealing with age.
I thought about a bunch of ways to cover them, and realized after reading a few things about people that had covered them, later to find they were now to thick to fit in the tracks, so I would have to use something thin. GoWesty sells vinyl like the original, but I wasn't going to spend all the time covering it only to have it do the same thing in a few years.
Then I read something about a person that had pealed all the vinyl off and painted the panels. That sounded good, and I could always cover them later if I thought of something better, well it worked out better then I thought.
So here's how I patched and painted my sliding door panel, the rest of them where done the same way.
Here's the before, with a nice hole and ratty vinyl
First I took the panel off, and then pealed the old cover off using an iron to heat it up. Heated the old brittle stuff will come right off, if you just try pealing it will take wood up with it.
Next I Cleaned the panel and cleaned up the rough edges on the hole with a sharp X-acto knife.
Then I took my iron and pealed off the thin vinyl on the other side of the panel around the hole, exposing the wood underneath, this gives the glue something good to bond to (the wood), vinyl isn't a good surface to glue to.
Before I started I went to Hobby Lobby and bought a sheet of heavy balsa wood that was the same thickness as my panel. I used my hole as a template and drew the shape of my hole on the balsa wood, since I had the room on the wood I traced out two in case I messed up the first. I then cut out the "hole" with my X-acto, sanded off the rough edges and set it aside.
I got some good old Elmer's Glue all and some poster board.
Cut out a square of board that covered the back of my hole well and glued it down.
I taped the edges and weighted it down to get a tight bond.
After the glue dried I took my "hole" and glued it to the poster board filling up the hole, I weighted that down and let it dry.
When it dried, I mixed up some Durham's Rock hard water putty (wood filler) and filled the gaps and any other holes in my panel.
After the filler dried I sanded it level and even.
Next was priming it for painting, since the panels were old and stained I sprung for some kilz, I knew that would give me an even base coat no matter what was on the panels.
The panels still had texture on it from the vinyl but where I patched them they were smooth so my patches would stand out.
I solved this by waiting till the Kilz was partially dried them using the fuzzy paint roller on it.
This gave it a soft texture over everything, just enough to cover the patches and even everything out. Once the Kilz dried I finished it off with a coat of washable latex paint.
I also took out the old insulation
And replaced it with B-quiet sound deadener, and insulation that is made for cars and RV's I also masked off the top track and repainted it.
And here it is finished, just have to ad the second handle, you can't see the patch even if you get close I didn't think it would turn out as well as it did.
I did all the rest like this, and it turned out real well, next came the window tint....
backcountrymedic Samba Member
Joined: February 17, 2006 Posts: 583 Location: Monterey, CA
Posted: Wed Oct 11, 2006 9:19 am Post subject: |
Beautiful work! _________________ No need to bear the weight of your worries, you let them all fall away...
Sector 9 longboard
Kona Kikapu Deluxe MTB
Novarra Big Buzz
Electra Cruiser
'01 Toyota Tacoma 4x4 |
kevinbassplayer Samba Member
Posted: Wed Oct 11, 2006 9:53 am Post subject: |
Looks good, I'm glad to know that there are other people out there who "get it" and like to work on their rigs as much as I do!  |
Posted: Wed Oct 11, 2006 10:03 am Post subject: |
If only my wife would "get it"... She is patient with me, and enjoys the use of the Westy. She sure as hell won't drive it though! And gets a bit frustrated with me when I'm outside all day, tinkering away... _________________ No need to bear the weight of your worries, you let them all fall away...
Sector 9 longboard
Novarra Big Buzz
Electra Cruiser
klucz Samba Member
Joined: February 14, 2006 Posts: 1062 Location: Chicago, IL
Posted: Wed Oct 11, 2006 10:08 am Post subject: |
ALL HAIL ART!
ALL HAIL ART! _________________ 84 Westy 4spd sold |
lovedavdubs Samba Member
Joined: April 30, 2004 Posts: 1597 Location: New York, NY.
Posted: Wed Oct 11, 2006 10:11 am Post subject: |
Nice work man. _________________ 82 Air-cooled Westy (Lola)...My other vehicle is a subway. |
MacGyver Samba Member
Joined: October 10, 2006 Posts: 100 Location: Ape City, Utah
Posted: Wed Oct 11, 2006 10:14 am Post subject: |
That's a pretty tight patch job, excellent. You do know you could have saved some time though... bullet hole stickers are in, these days. _________________ I specialize in fixing whatever I can using Q-tips, feathers, and ball point pens.
I don't believe in guns.
westylife Samba Member
Joined: October 28, 2007 Posts: 409 Location: Anchorage, Alaska
Posted: Fri Dec 28, 2007 12:15 am Post subject: |
Nice work Art,
My Westy is the same color as yours. I just took everything out of mine and will be repairing my panels the same way as you did. Where did you get the insulation? Do you like the white color you picked? would you change it if you were to do it again? The PO tried to match the color of the van but didn't turn out well.
Thanks. _________________ 1983.5 Westfalia Bostig RG1 |
captainpartytime Samba Member
Joined: December 04, 2005 Posts: 721 Location: Mission Viejo, CA
Posted: Fri Dec 28, 2007 2:14 am Post subject: |
Just when you thought it couldn't get any worse....Asuan Brown panels! Please promise you WILL NOT post any before photos  _________________ -Kerry
1982 turbo diesel Westfalia |
Posted: Fri Dec 28, 2007 10:19 am Post subject: |
westylife wrote: |
Nice work Art,
Thanks. |
The insulation is "NASA Insulation" I bought a big roll of it from J.C. Whitney.
http://www.jcwhitney.com/autoparts/Product/tf-Brow...69/c-10101
It's made for installing in RVs and Vans. Won't contain water, won't mold or mildew, fire resitant, it's nice and tightly packed, I put B-quiet sound deadening matierial in first to cut down on the vibration,
http://www.b-quiet.com/vanagon2.html
Then I put in the insulation.
The paint color is a white satin washable latex, I stuck with white to keep the interior brighter inside, the less you have to use your interior lights when camping the better.
I'd do it the same way, I've even touched up the panels now and then with whilte paint, was easy to care for easy to do, and didn't have any reinstall issues.
Posted: Fri Dec 28, 2007 12:32 pm Post subject: |
Thanks Art,
I'm going to order some today. _________________ 1983.5 Westfalia Bostig RG1 |
Points Mean Prizes Samba Member
Posted: Fri May 29, 2009 1:41 pm Post subject: Where have the pics gone? |
I have this exact problem and have been trying to see what the options are to refinish the interior. My problem is that some panels are damaged. Does anyone know where there may be a post on how to remove the interior trim? |
Sheesh Samba Member
Joined: October 18, 2007 Posts: 394 Location: New Pine Creek, Orygun
Posted: Sun May 31, 2009 8:17 pm Post subject: |
I refinished some panels with removing the vinyl with a hair dryer, using acetone to remove glue (applied with brushes, scraped with putty knife, then brushed again and wiped off with paper towel), sanding, then painting with tinted floor and patio paint (hard / washable). Did the cabinetry this way, too.
A few others that were damaged, I cut new plywood that fit in the retaining slots. One, I finished with stain/urethane. I would have liked to do the same with all the others, but the glue residue would haven't produced good results. _________________ 1982 Westy, 2.0L AC CA emissions |
tam_shops Samba Member
Joined: November 15, 2012 Posts: 1531 Location: Vancouver BC
Posted: Wed Aug 14, 2013 8:33 pm Post subject: |
Nice job!
Is the handle on the right original? I think I read about that on the thread about things you didn't know your van had. LOL I've never even noticed a hole or anything over there, thought the missing handle was on the left over the thing that seems to be there for no purpose (back of exterior handle).
tam
_________________ 1987 Vanagon Westfalia GL Automatic
Making it special:
http://www.thesamba.com/vw/forum/viewtopic.php?t=545885 |
TequilaSunSet Samba Member
Joined: May 30, 2012 Posts: 2109 Location: Philippines
Posted: Wed Aug 14, 2013 10:14 pm Post subject: |
^^ 4 years ago... ya might be waiting a while on a response  _________________ Don't harsh my mellow...
1985 Hightower Vanagon 1.8T- Gone
1972 Panel Bus- Gone
1967 Bug- Gone
1964 Euro Sunroof Bug- Gone
1969/72/63 Sunroof Bug- Gone
1975 Brazilian Bug in the Philippines 🇵🇭- New to me |
Merian Samba Member
Posted: Tue Jan 13, 2015 11:52 pm Post subject: |
tam_shops wrote: |
Nice job!
tam
Yep that's the original stock location for the handle.
And it did take awhile (several years) for ya to get a response
sorry |
dobryan Samba Member
Joined: March 24, 2006 Posts: 17131 Location: Brookeville, MD
