Barndoor Factory Spotwelds (Exterior Bodywork)
RockStock
RockStock is offline
PostPosted: Tue Nov 07, 2006 1:53 pm    Post subject: Barndoor Factory Spotwelds (Exterior Bodywork) Reply with quote
what do people know about them?
how obvious were they when new? or weren't they?
for example - rear arch - is this typical of og?
would like to see more pics, if anyone has any....
my bodyman is gonna be made up!
-StockRocks-
Scotty
Scotty is offline
PostPosted: Tue Nov 07, 2006 2:34 pm    Post subject: Reply with quote
I suspect that the spot welds weren't visible from new, but once you add rust and the seam swells it obviously pulls the spot welds.
Anchovy
Anchovy is offline
PostPosted: Tue Nov 07, 2006 4:38 pm    Post subject: Reply with quote
I think the rust shows them more, but that they were slightly visible from new. The spot welds also become more pronounced when the body is bead blasted too hard from the inside. From the factory you could probably see traces of the spot welds, but nothing like in the photo above. The factory panels were far from perfect. On original paint buses you can often see a small divet or wave beneath the engine vents on the leading edge. This artifact looks like stress in the panel for the stamping process. The spot weld reminants and the divet are nearly always lost when the panels are blocked straight during a restoration.
PostPosted: Tue Nov 07, 2006 4:49 pm    Post subject: Reply with quote
Not visible:
Maybe if my Truck was shiny.
RockStock
PostPosted: Tue Nov 07, 2006 5:19 pm    Post subject: Reply with quote
thanks all
Not visible:
how come that curve can be seen though? you know, where the spot welds 'are'?
-StockRocks-
Anchovy
Anchovy is offline
PostPosted: Tue Nov 07, 2006 5:20 pm    Post subject: Reply with quote
Not visible:
Can you feel them? It looks like a different pattern of patina along the spot welds which would make me think that they are there.
PostPosted: Tue Nov 07, 2006 8:55 pm    Post subject: Reply with quote
"Not as visible" I guess would be better. I can feel a couple of them but not all. You can see the circle ridge more.
Here are 2 BIG photos if you want more detail:
http://www.thesamba.com/vw/scrapbook/54truck/20061107/DSC08892.JPG
http://www.thesamba.com/vw/scrapbook/54truck/20061107/DSC08893.JPG
BUCIOBATISTI
BUCIOBATISTI is offline
PostPosted: Tue Nov 07, 2006 11:31 pm    Post subject: Reply with quote
The spot weld divets on the doglegs on my '53 Panel are very very visible and I love how they look like that. I have seen a few other Barndoors that looked much the same in the dogleg area.
Please check us out on Instagram at @holygrailgarage
That's the best place to see the latest things we are up to as well as catch an occasional sneak peek of our latest car and parts listings!
RockStock
PostPosted: Wed Nov 08, 2006 1:07 am    Post subject: Reply with quote
brendan, can you throw up a couple of pictures?
thanks
-StockRocks-
BUCIOBATISTI
PostPosted: Wed Nov 08, 2006 1:13 am    Post subject: Reply with quote
thanks
Not a very good example but I think you can clearly see them in this pic. It is the middle of the night over here and my camera and computer are not communicating these days for some reason...
[email protected]
jmp@ncounty.net is offline
PostPosted: Wed Nov 08, 2006 8:28 am    Post subject: Reply with quote
I think when new they were not really visable. As time went buy and all the rain,mud, salt ect. got jamed up under the seems pulled apart some pulling on the welds.
campingbox Premium Member
campingbox is offline
PostPosted: Wed Nov 08, 2006 8:40 am    Post subject: Reply with quote
I agree 100%.
RockStock
PostPosted: Wed Nov 08, 2006 9:54 am    Post subject: Reply with quote
right, first reply Exclamation Question Embarassed
-StockRocks-
BUCIOBATISTI
PostPosted: Wed Nov 08, 2006 10:29 am    Post subject: Reply with quote
I'm not so sure myself. I remember seeing a really low mile original Barndoor Fire Kombi at Kelley Park many years ago and both doglegs had huge divets visible as clear as day. It was a low mile, unabused Bus and although it had been repainted they never did any body work to hide those body flaws.
Anchovy
Anchovy is offline
PostPosted: Wed Nov 08, 2006 12:04 pm    Post subject: Reply with quote
Freak!
Now where are my 29 part number lug nuts? I need to fondle them a bit.
Scotty
Scotty is offline
PostPosted: Wed Nov 08, 2006 12:47 pm    Post subject: Reply with quote
Did you cut the wheel arch apart and have a look at the seam where the spot welds were? How could you tell if it was rusty in that seam otherwise?
PostPosted: Thu Nov 09, 2006 10:36 am    Post subject: Reply with quote
Are you talking about divets on the exterior bodywork or inside the jamb?
I think divets are acceptable along the bottom of the nose and rockers.....but would expect that divets along the battery trays and wheel wells to be taken care of with lead prior to it's first paint.
BUCIOBATISTI
PostPosted: Thu Nov 09, 2006 10:52 am    Post subject: Reply with quote
I'm talking about on the visible exterior surfaces, particularly on the doglegs. I have seen more than a few original paint and otherwise Barndoors that have heavy dimpling and divets in body work all over them, seemingly more pronounced than on later model Buses.
Turbo Bug
Turbo Bug is offline
PostPosted: Wed Nov 29, 2006 1:54 am    Post subject: Reply with quote
Scotty is 100% right here. This is what happens with age and years of body/panel flex. I like to view it as lovely bit of genuine patina.
There are some pictures of body assembly at Wolfsburg where you see the guys spot weld this area then flat over the arch panel in the spot welded are with a large (about 10 inch) sander. They pretty much get the panel flat, but there are always some minor imperfections. Bear in mind that we are talking about a mass production vehicle here and not a coachbuilt.
j.pickens
j.pickens is offline
PostPosted: Wed Nov 29, 2006 10:13 am    Post subject: Reply with quote
I'd bet those dimples are stress related.
That low mileage fire bus Brendan mentioned might well have driven alot of those low miles over cobblestone streets. That will shake the bejesus out of the bus.
BeaterBarndoor wrote:
Red Fau Veh wrote:
