Narrowed Beam Tutorial (Super long post)
NAES
NAES is offline
PostPosted: Mon Jan 05, 2004 9:29 pm    Post subject: Narrowed Beam Tutorial (Super long post) Reply with quote
OK, here goes. I just got finished narrowing a beam and dropped spindles for "Bobby Hollywood" of the BDM and I'm going to attempt to give a step by step.
This beam is for stock wheels with lopro tires on it. We only narrowed 2" total, just enough to clear the step in the wheelwell. If you need a narrower beam then your better off going for one of those ones with the lasercut sideplates.
Anyway, you start by yanking your beam and disassembling everything. Remove the spindles, trailing arms, leaves and center steering link if the bushings are bad (these were not)
Next your going to inspect your Bakelite bushings and if they are not cracked or too worn your going to take a pipe or socket the same ID as the beam tubes and knock them in 1 1/8" in preparation for the cutting
Then you carefully measure 1" from the ends and mark and cut the inch off. A trick to use is to cut a little, measure and cut some more to ensure accuracy.
If you look at the pic, some of the shock tower has disengaged from the beam tubes. I/We welded a ring around the end and put the heat up as high as possible then ground it back down as extra insurance. Probably not necessary but done none the less.
Now reinstall the leaves and the trailing arms in preparation for offset measurements. A little trick I use is to grind off the edges of the leaves so they go in the trailing arms easier as seen in the pic. I clamp the exposed leaves w/ vise grips and then measure the offset (between 5 and 9mm). If you do not know what I'm talking about look it up in the Idiot Book.
Now you take a drill the same size as the hole in the trailing arms and dimple the leaves. Use a new bit as it tends to get wasted and use alot of oil. If your worried about the threads use some tape on the bit but it is not necessary to do. Then replace the Allen studs and recheck your measurements. The 5-9mm is critical for proper camber alignment. Once done you can cut off the excess leaves if you want and run a weld across them to keep em together
Now weld a shock mount tab 1" closer in and back a little bit to keep the shocks as vertical as possible. No need to get carried away though.
And heres the finished beam ready for disassembly and paint if desired.
I will continue to edit this post as needed to clarify anything. PM or post if you have any questions. Good luck.
Barndoor Mafia
Box On Wheels
SBS #00
MoneyMike
MoneyMike is offline
PostPosted: Mon Jan 05, 2004 10:44 pm    Post subject: Reply with quote
Kick Back Ferret!
Ferret Don't Flair It!
DubStyle
SBS Hit Squad
DubStyle is offline
PostPosted: Mon Jan 05, 2004 10:57 pm    Post subject: Reply with quote
Sean you rock brother! This has to be the best step by step I seen on narrowing a bus beam! I can't wait for my Bus to hit the island for some narrowing and spindle dropping. Got me some stock 15"s today. Hell yeah thanks for the pics and tutorial!
Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club"
NorCalNick
Ain't yo baby daddy
NorCalNick is offline
PostPosted: Mon Jan 05, 2004 11:11 pm    Post subject: Reply with quote
yeah bro, you gave me confidence i can do my own beam.
When I'm done punching the clock, I start punching the clown.
View user's profile Send private message Send e-mail Visit poster's website AIM Address MSN Messenger Gallery Classifieds Feedback
rizzag
Now Wut?
rizzag is offline
PostPosted: Tue Jan 06, 2004 10:02 am    Post subject: Reply with quote
******this only works this way on early beams with bakelite bushings(63 and earlier i believe) later beams(64 to 67) with needle bearings have a ledge behind them and can not be knocked in the beam******
just didnt want someone with a later beam getting into something they cant finish or worse.
jeff
flossin, tossin, dippin, and trippin
j.pickens
j.pickens is offline
PostPosted: Tue Jan 06, 2004 1:37 pm    Post subject: Reply with quote
Is there a quick way to identify which beam you have without dissassembly?
Many buses have been swapped around so much, you can't tell by just the year of the chassis.
BeaterBarndoor wrote:
Red Fau Veh wrote:
rizzag
Now Wut?
rizzag is offline
PostPosted: Tue Jan 06, 2004 2:10 pm    Post subject: Reply with quote
an easy way to tell is by looking at the center pin housing. early style is round and the late style is kind square with an indentation in the center where the greese zerk is.
campingbox Premium Member
campingbox is offline
PostPosted: Tue Jan 06, 2004 4:37 pm    Post subject: Reply with quote
See the two verticle pieces of metal between the two beams?
The early ones (shown) have these, later ones do not.
Peter - Belgium
Peter - Belgium is offline
PostPosted: Thu Jan 08, 2004 3:56 am    Post subject: narrowing the beam. Reply with quote
Very good and usefull post!!!
I still have some extra questions:
- You are only pushing in the bakelite parts 1 1/8 inch in order to cut off 1 inch. Will you not destroy the bakelite parts while welding since it is only 1/8 inch removed from the hot welding area?
- If I want to push it in further, how can I get it back out?
- How do you prefent the beamtube from distorsion so the arm would block instead of rotate freely?
- Do you happen to have a picture of the ring you welded on the cutted area?
Thanks,
Peter
Belgium.
diy570
diy570 is offline
PostPosted: Thu Jan 08, 2004 6:53 pm    Post subject: Reply with quote
also if you are gonna tear it this far down, you might want to consider making it an adjustable beam while you are at it. for an extra hour or so of work its well worth it.
NAES
NAES is offline
PostPosted: Sat Jan 10, 2004 1:53 am    Post subject: Reply with quote
Didn't think the weld heat would be an issue so I never considered it.
To get the bushings to come back out you would have to use some kind of puller that doesn't put a bunch of stress on one area of the bushing. I guess I wouldn't recommend a cotter pin puller as my tool of choice. I would probably remove the bakelite bushings If I was concerned with the heat in the first place
Distortion? From the weld? I'm unclear what you mean but since the bakelite bushing is keeping everything round there has never been any issue on the beams that I have done.
Sorry, I don't have a pic but all you need to know is that you send the welder up on a high heat to get the good penetration. You will be grinding the face down and only utilizing the benefit of the weld that has penetrated and formed a bead on the oter side of the shock tower. But in my opinion, this was an unnecessary step. I just wanted to do it as a measure of safety but still I'm not sold on the idea.
Good Luck on your beam. Don't worry about it, it''ll all work out fine as long as you take your time and do a little bit at a time.
Making it adjustable kinda went without saying. I was only addressing the narrowing part. Get to work on your dropped spindles while your at it. If you don't want to do it yourself, get em done and do it all at the same time. nothing more frustrating than pulling the front beam out or spindles off time after time.
Barndoor Mafia
Box On Wheels
SBS #00
MoneyMike
PostPosted: Sun Jan 11, 2004 7:55 pm    Post subject: Reply with quote
Ferret Dont Flair It!
DubStyle
SBS Hit Squad
DubStyle is offline
PostPosted: Tue Feb 10, 2004 5:02 am    Post subject: Reply with quote
Up for you Narrow'd Fanatics!
Anthony
SBS #1
SBS #1 on FB
Skim
Rants Master
Skim is offline
PostPosted: Tue Feb 10, 2004 6:25 pm    Post subject: Reply with quote
very informative. Im suprised I missed it. Now since a barndoor beam is alot different, Im wondering how difficult it would be to narrow one.
GFK
1953 Kabriolet
1959 Lowlight Ghia vert
Long-roofs
Long-roofs is offline
PostPosted: Tue Feb 10, 2004 6:39 pm    Post subject: Reply with quote
A barndoor beam would be the same depending how narrowed you go, like the later buses. The problem for me is I didn't get trailing arms or spindles with my 2/55 bus. All I have is a beam and torsions, only 4 bars for each tube. That's why my bus is getting a '67 beam.
Trying to keep poor cool
People are talking, the greatness is coming, going to be greater than great, so great, greater than anything ever.
15window
15window is offline
PostPosted: Thu Feb 12, 2004 1:28 am    Post subject: Reply with quote
NAES,
Great thread and really appreciated, I have an early beam that I wanted to narrow but my bakerlite outer bushes are shot, any idea where or if you can get new ones, can't seem to find any in the UK.
Many thanks
Alex
DubStyle
SBS Hit Squad
DubStyle is offline
PostPosted: Thu Feb 12, 2004 4:35 am    Post subject: Reply with quote
Buy the material and have a local Machine Shop cut you some new ones.
Anthony
SBS #1
SBS #1 on FB
The Milky Barndoor Kid
The Milky Barndoor Kid is offline
PostPosted: Sun Feb 15, 2004 10:07 am    Post subject: Reply with quote
Very good thread,thanks for taking the time to show us how to do this Very Happy
Q) I have a 67 bus but I can't push in the bakelite sleeves in because of the needle bearings,are there any other was of doing this narrowed beam to a 67 bus?
thanks
karl
NAES
NAES is offline
PostPosted: Sun Feb 15, 2004 4:42 pm    Post subject: Reply with quote
Theres a thread for a needlebearing beam out there. Way better than mine
Barndoor Mafia
Box On Wheels
SBS #00
cage66
cage66 is offline
PostPosted: Thu Jun 11, 2009 1:54 pm    Post subject: Re: Narrowed Beam Tutorial (Super long post) Reply with quote
Are you drilling the dimples with the arms in?
If so you can also get a bus lug nut and drill a hole in the middle them screw it in where the grub screw goes and use it as a guide. Then there is no way to distort the threads
