Brad Lee Samba Member
Posted: Thu Jan 04, 2007 4:44 pm Post subject: 25 HP engine? |
Greetings!
This is a pic of the engine in my '51. The ID numbers are really faint and hard to read.
Is this a 25HP? If so, does it look somewhat correct?
Thanks for your help!
53 0val Samba Professor
Joined: July 03, 2003 Posts: 11396 Location: Irvine, CA
Posted: Thu Jan 04, 2007 4:53 pm Post subject: |
| jmillers55 wrote: |
Here you go:
Look like a correct 25hp.  _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Thu Jan 04, 2007 4:57 pm Post subject: |
Thanks for the posting the pic and the reply
I think the ID says 1-6282275. That doesn't match with the charts on the site. Am I missing something?
Thanks |
kafer53 Samba Member
Joined: July 24, 2004 Posts: 904 Location: Ontario, Canada
Posted: Thu Jan 04, 2007 8:43 pm Post subject: |
| 13SPanel wrote: |
Thanks |
It must be a "0" like 1-0282275. That would be more correct for your 51 engine.
What month was your vin # from according to the production charts?
It looks like you might have the correct engine for your car and maybe even the matching one. _________________ 1953 Zwitter 11C (L73) |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Thu Jan 04, 2007 10:47 pm Post subject: |
| 53 0val wrote: |
| jmillers55 wrote: |
| Here you go: |
Look like a correct 25hp.  |
Wow, you don't see Bob saying this everyday!  _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71793 Location: Phoenix 602
lurkinstock Samba Member
Joined: September 04, 2006 Posts: 416 Location: n. ga.
Posted: Fri Jan 05, 2007 5:32 am Post subject: |
| Hold down clip is on 25 hp , I want to say that 36 hp is when VW went to a screw cap. I am just going off what I have seen. |
Posted: Fri Jan 05, 2007 7:35 am Post subject: |
| EverettB wrote: |
Does the 25hp acorn oil filler use the hold-down clip?
I thought that began with the 36hp style oil filler. |
Yes, only the single strap one. The 36hp ones used either two snap clips or a screw top style _________________ 1953 Zwitter 11C (L73) |
Posted: Fri Jan 05, 2007 8:45 am Post subject: |
Yes, that motor is correct as it is. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Fri Jan 05, 2007 8:54 am Post subject: |
| EverettB wrote: |
| 53 0val wrote: |
| Yes, that motor is correct as it is. |
Is the clip exactly the same for all years that it was used? |
That's a good question. I'll check out some sorces.  _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Joshua B Samba Member
Joined: January 03, 2004 Posts: 274 Location: Colorado
Posted: Fri Jan 05, 2007 9:25 am Post subject: |
It looks pretty correct, with most of the hard to find parts? But correct me if I am wrong. Shouldn't it have the round carb support and not the flat later style, and a Jacketed K manifold since it is a '51? (I don't even have the later on my car, or the no lip pulley ). About the crank pully? So are all split dash splits suppose to have the ones without the puller cutouts and no lip on them, and are the diameters different from the later in these as well? Also which you can't tell from these pictures, it should have the two piece cylinder head tin without the spark plug indention and seamed fan shrould, being a '51?
Just tryin to stay updated on my external engine year changes. Let me know if I am wrong.
Later
Josh |
Heb623 Samba Member
Posted: Fri Jan 05, 2007 10:02 am Post subject: |
ET says that on an early 1951 25hp was no hold on clip!!!
My technical English is not good enough to explain but believe it or not there is no clip!!!
ET |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9414 Location: Northwood, NH USA
Posted: Fri Jan 05, 2007 10:29 am Post subject: |
| Joshua B wrote: |
Later
Josh |
Carb support, yes, should be round. Good call.
Intake: Indeterminate. The end date of the jacketed K is unknown. Indications by original cars that still had them, and/or pictures are that it ended in late '51 or early '52. The pictured intake could be corret if it is the 25 "701" intake (not the 701E which has 36 hp endcastings). Interestingly, I just bought one of those and was examining it last night. If it is an early '51 engine, than it most probably had the jacketed K.
I can't tell from the pic, but it looks like it has a rolled lip 36hp crank pulley. It should have an edge lipped crank pulley, but it would have the puller holes (Sept '50 service manual shows this). Non pull hole pulleys ended sometime in the mid-late 40s. There is no difference in the diameters (some 356 pulleys look the same, fit the crank, but are slightly larger in dia.)
Not sure when the 2 piece cylinder head tin ended, but I am pretty sure it was before '51.
Yes, it should have the seamed fan shroud....
Also, can't tell by the pic, the ignition wire tube clamps should have welded M6 bores on the back sides and M6 (probably Kamax) bolts, not scres like the leter kind. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Heb623 Samba Member
Posted: Fri Jan 05, 2007 10:42 am Post subject: |
And no comment about the hold on clip ???
ET |
Posted: Fri Jan 05, 2007 10:46 am Post subject: |
| Heb623 wrote: |
ET |
Then how did the breather stay on? I think '51 did have the breather cap hold clip... I wil have to check some references on that. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Heb623 Samba Member
Posted: Fri Jan 05, 2007 11:11 am Post subject: |
My 1951 shows me that "pipe" (sorry dont know the exact word for it) that goes into the engine is cone shaped!
The top of my 1951 oil filling tube is completely flat!
A 1952 pipe isn't cone shaped so the top of later (1952) has a dimple in it.
In the hold on clip is also a opposite dimple and this secures holds the tube!
Tell me if I am wrong, OK?
ET |
Posted: Fri Jan 05, 2007 11:25 am Post subject: |
| Joshua B wrote: |
Later
Josh |
Good eyes on the carb support......It should be round. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Heb623 Samba Member
Posted: Fri Jan 05, 2007 11:33 am Post subject: |
OK, OK but how about the hold on clip now???
No news yet?
ET
