Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Sun Mar 25, 2007 4:49 pm Post subject: Correct E-Brake cables for 59(60?) with Big Nut Transaxle |
I did a search but did not find an answer to this specific question.
I have a big nut transaxle to swap into my Sept 1 59 Mango.
Will the existing small nut park brake cables work with the big nut transaxle?
If not, which ones will work? _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin
Mikee Samba A.D.D. Boy
Joined: March 22, 2004 Posts: 3513 Location: Puyallup WA
Posted: Sun Mar 25, 2007 5:39 pm Post subject: |
yes they should work _________________
localboymark wrote: |
One man's "patina" is another man's cancer. |
bugnut68 wrote: |
I would have kicked the guy right in the dick, balls, ass and face and destroyed his weed. Hippies suck. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25972 Location: Olympia Wash Rinse & Repeat
Posted: Sun Mar 25, 2007 6:07 pm Post subject: |
Hi Riff Raff,
You need 1964-67 brake cables and look in yellow pages for "wire rope" for a shop that can swedge on new ends after you cut down the later cables to the earlier cable length. _________________ In Stereo, Where Available! |
Posted: Sun Mar 25, 2007 6:43 pm Post subject: |
Eric&Barb wrote: |
Hi Riff Raff,
You need 1964-67 brake cables and look in yellow pages for "wire rope" for a shop that can swedge on new ends after you cut down the later cables to the earlier cable length. |
why wont orig cables work, _________________
bugnut68 wrote: |
Lind Samba Member
Joined: November 06, 2000 Posts: 10221 Location: idaho
Posted: Sun Mar 25, 2007 7:22 pm Post subject: |
Mikee wrote: |
Eric&Barb wrote: |
Hi Riff Raff,
why wont orig cables work, |
the cables are shorter for early buses with the rearward e-brake location. _________________ .
Wanted:
Posted: Sun Mar 25, 2007 7:35 pm Post subject: |
The Mango has the forward e-brake handle (I think)as it is a tunnel trans and bent shifter, (VIN 503184) but the e-brake adjustment is under the front floor, not part way up the handle in the cab like the later models.
So there is not a stock cable that will work?
I will have to cut the 64-67 to length? _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Sun Mar 25, 2007 9:51 pm Post subject: |
Check out a thread that I did on this some time ago and don't splice your cables!
It's true that you can't use the later emergency brake cables in an older bus because they are longer but you can adapt the later model rear brake plates to accept the metal "stop" at the rear end of the cable housing of the earlier cable/housing. Make sure that you save the "stop" which the end of the cable casing rests against inside the old brake plate for use on the later brake plate.
I have done this many times. If you can't find the thread, let me know and I will explain it, again. |
Posted: Mon Mar 26, 2007 5:52 pm Post subject: |
I like camrods idea, here is the thread campy was talking about
http://www.thesamba.com/vw/forum/viewtopic.php?t=188724&highlight=brake _________________
bugnut68 wrote: |
Campy Samba Member
Posted: Mon Mar 26, 2007 10:09 pm Post subject: |
My mind must be tired but I'm not sure what camerod meant about extending the cables. In Riff Raff's case, the later emergency brake cables are too long because the threaded ends don't get poked up through the floor and the later rear brake plates have the external, spot welded on cable casing stop, which is wrong for the older style cable housing end.
For the 1958 bus body on a four-wheel drive jeep chassis that I was restoring, I mated the front part of the bus cables to the jeep cables at the rear by cutting the jeep and bus cables, and connecting the ends together with one of those over one inch long metal connectors, then crimping it twice on each end with a special, large crimping tool. It has worked fine.
By far the best way is to remove the spotwelded on cable casing stop on the outside of the later model brake plate and do what I suggested in my thread in the other post. You use the stock emergency cables (no splicing) and your later model rear brake plate will look like the original, but smaller, brake plate. I did it over twenty years ago to my 1957 bus and, more recently, to the 1958 walk-thru bus I was restoring when I put a big stub axle transaxle in it. |
Posted: Tue Mar 27, 2007 5:51 am Post subject: |
Thanks for all the suggestions!
The cable casing stop on my big nut transaxle is certainly different from the small nut. It looks as though someone welded on a small metal cylinder. Is that correct? _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Campy Samba Member
Posted: Tue Mar 27, 2007 10:59 am Post subject: |
That was what they changed: they went from the metal end of the cable casing going through a hole in the brake plate and being held on by a removable clamp, to an external spot welded on pedestal or stop to hold the end of the casing. That pedestal is what you remove by grinding off the four spot welds, leaving a hole, then enlarge the hole to make it look like the hole in the old brake plate. That includes not lengthening the hole too much at the front so you can bend the metal towards the brake drum, to act as a guide for the casing, just like on the older plate. Then, all you have to do is drill a hole in the plate so the clamp from the old plate can be mounted, with a small bolt and nut, to go over the metal end of the cable's casing to hold it in place, just like the old one.
After thinking about it, camerod's method must be to have something solid like a tube go over the end of the longer, later model cable to take up the extra length where it goes through the linkage below the emergency brake. Is that right? |
incynr8 Samba Member
Joined: September 23, 2003 Posts: 822 Location: Soylent Green is PEOPLE!
Posted: Tue Mar 27, 2007 11:04 am Post subject: |
note to self.......stick with crashbox small nut. _________________ ..........
Do it right, or don't bother. |
camerod Volksfab
Joined: October 01, 2002 Posts: 606 Location: washington state
Posted: Wed Sep 05, 2007 6:09 am Post subject: |
Campy wrote: |
nope.....I use the original cables to the bus, just extent the E-brake hande end of the cable with a coupler nut(long nut made to mechanically join 2 pieces of all thread together) and a 3" piece of all thread, the cable with then be long enough to get the original 6mm nuts on for adjustment. _________________ DON'T SHIT WHERE YOU EAT! |
Posted: Wed Sep 05, 2007 7:20 am Post subject: |
I still have not resolved this.
These cables are one year only (May 59 to May 60)and there seems to be little demand for them as WW has been out of stock forever and no one else has them that I have found.
The original park brake cables are still on the original transaxle, but I can't get one of the drums off to retrieve the cable on that side.
I have soaked the spline with penetrating oil regularly and occasionally whacked the drum with a hammer on my way by for the last few months. That drum is stubborn. Nobody has a wide 5 drum puller around here, so I suppose I will have to commision one of my buddies with a welder to build me one based on that design that has the puller sub as a shop stool when not in use. (Props to the designer)
I have not been doing any work on the Mango over the summer as my philosophy is that summer is for driving and winter is for wrenching.
I am going to have to address this problem soon though.
Camerod - do you have a couple of those extensions custom built that I can get from you? _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5928 Location: back to living where hell meets the suface
Posted: Wed Sep 05, 2007 7:29 am Post subject: |
Riff Raff wrote: |
Camerod - do you have a couple of those extensions custom built that I can get from you? |
Is there a place that works on old JEEPS around you. All the early JEEPS used a tapered axle and press fit drum on them. You have to use a drum puller to remove. Thats were I used to borrow one from till I found my own _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
Posted: Wed Sep 05, 2007 7:37 am Post subject: |
splitpile wrote: |
Is there a place that works on old JEEPS around you. All the early JEEPS used a tapered axle and press fit drum on them. You have to use a drum puller to remove. Thats were I used to borrow one from till I found my own |
My next door neighbour is parts manager for a Chrysler/Dodge dealership. I'll send him with a drum and see if one of his old school mechanics has a puller that will fit it.
Thanks for the tip  _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Wed Sep 05, 2007 11:29 am Post subject: |
Riff Raff wrote: |
splitpile wrote: |
Thanks for the tip  |
The same puller is used on models A's. I used to borrow one from the guy down the street too to repair my Willys Truck till I bought one. Have used it on a couple of stuck wide five VW bus drums.
Almost any shop that works on old cars will have this puller too. |
Posted: Wed Sep 05, 2007 11:30 am Post subject: |
Riff Raff wrote: |
bfy has the cables, I just bought some from them _________________
bugnut68 wrote: |
spiritwalker Samba Member
Posted: Mon Oct 11, 2010 4:43 pm Post subject: Ebrake Cable Lengths |
For the thread...
19??-1958 ????mm ( I measured 124.5" on a early model 59)
1959- 5/1960 3330mm (131.1")
5/1960-7/1963 3460mm (136.2")
8/1964-1967 3465mm (136.4)
1968-1969 3150mm
1970-Death 3440mm |
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Mon Aug 19, 2013 1:40 pm Post subject: |
Great thread and I like camerod's idea as well. Another option is a 64 - 67 cable cut to lenght with the set screw type ends that you can buy at CIP1. Thanks to widefive for this info!  _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
