Any machinists out there.....delrin?
jspbtown
jspbtown is offline
PostPosted: Tue Apr 03, 2007 12:29 pm    Post subject: Any machinists out there.....delrin? Reply with quote
I need a bushing for a project that I am doing. I can't seem to find a bearing that will go into the stock steering tube (bushing would need to be 1.5" OD), and have a 7/8" ID hole in the middle for a steering shaft. Anybody have the tools to make me one? Maybe 2-3" long?
bob cook
bob cook is offline
PostPosted: Tue Apr 03, 2007 3:35 pm    Post subject: Reply with quote
I made mine using hole saws I may have an extra one if your interested I'll check email me if your interested
bob cook
bob cook is offline
PostPosted: Tue Apr 03, 2007 3:48 pm    Post subject: Reply with quote
I checked I do have an extra one it is made out of UHMW wich is just like delrin self lubricating it is white it is 1.5 dia 7/8" hole 1 " thick this is what I'm using in mine and know of others that are using the same thing if you want it I need a mailing address and it is your no charge just let me know !!!!
darrenma
darrenma is offline
PostPosted: Tue Apr 03, 2007 5:04 pm    Post subject: Reply with quote
Delrin is not as slippery as UHMW ,but is really nice to machine and harder than UHMW.Because UHMW is more slippery it will last longer than delrin,but either will work fine.
lostinbaja
lostinbaja is offline
PostPosted: Tue Apr 03, 2007 5:33 pm    Post subject: Reply with quote
Delrin is actually DuPont's name for UHMW (ultra high molecular weight)Nylon.
Granted there are various types of Delrin.
* Standard Delrin (Homopolymer)
* Delrin AF- Contains Teflon fibers and works very well for bushings but is a bit softer due to the TFE Teflon fibers.
* Delrin, Glass filled- Low deformation under load and good impact resistance. No creep under load.
There are more type but these are the most popular.
Jerry...
desertwrx
desertwrx is offline
PostPosted: Tue Apr 03, 2007 7:41 pm    Post subject: Reply with quote
Hate to be picky, but Delrin is actually Acetal. UHMW is something completly different. Much cheaper than Acetal and works good. Delrin/Acetal is used a lot for suspension bushings in race cars.
lostinbaja
PostPosted: Wed Apr 04, 2007 3:34 am    Post subject: Reply with quote
How picky do you want to be? Delrin is actually an Acetal Homopolymer which all shares the same basic molecular chain with what DuPont calls "Nylon".
Jerry...
jspbtown
jspbtown is offline
PostPosted: Wed Apr 04, 2007 6:28 am    Post subject: Reply with quote
Bob,
I sent you a PM. Thank you, thank you, thank you!
Jeff
bob cook
bob cook is offline
PostPosted: Wed Apr 04, 2007 7:10 am    Post subject: Reply with quote
put it in the mail this morning you should get it in a couple of days glad to help
jspbtown
jspbtown is offline
PostPosted: Mon Apr 09, 2007 8:16 am    Post subject: Reply with quote
Got it over the weekend Bob. It looks like it will work perfectly! Thank you!
