Ellison Samba Member
Joined: October 16, 2006 Posts: 212 Location: Spokane, WA.
Posted: Tue Apr 03, 2007 2:41 am Post subject: White Krylon "Fusion" Paint Is The Poop!!! |
They might be a little white, but this was my first attemped at making these. They are 125 temp tires. Just wanted to see if it will work before I destroy a good set of 135's!! I ground off the letters, cleaned it w/ electrical cleaner (evaporates in 2 seconds and leaves no residue) And then I taped it off and spray the crap out of them.
Are they too white??
Never mind the vintage hubcaps, I needed to see what they were gonna look like with rims. They will be going on my square!! Thanks for checkin' it out!!! |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16825 Location: State College, PA
Posted: Tue Apr 03, 2007 4:16 am Post subject: |
Keep up posted how this works out - damn good idea! - Obviously if you scuff a curb, its gonna come off, but hey - saving big $$ on Cokers is a neat idea!!!! _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
fifty-five Samba Crash Test Dummy
Joined: August 27, 2004 Posts: 1188 Location: over by the Farm
Posted: Tue Apr 03, 2007 6:13 am Post subject: |
| I think whiter is better on wide whites. That's a good idea. I like it! |
luckystiff Samba Member
Joined: September 28, 2005 Posts: 2252 Location: hickory,nc
Posted: Tue Apr 03, 2007 2:44 pm Post subject: |
hot rod and custom people have been doing this for years. there's been multiple threads over on the hamb about it. with vinyl spray dye tend t work even better than the fusion. the fusion will crack over time but you just scuff and reshoot them. cheap and very effective for a driver...ken.... _________________ ITMC
Secret Service |
Crunky Samba Member
Posted: Tue Apr 03, 2007 9:25 pm Post subject: |
| Those look great! How did you mask off a circle that well? Special masking tape? This would be great for my rat project. |
Posted: Tue Apr 03, 2007 10:51 pm Post subject: |
| Crunky wrote: |
I used electrical tape out of all things. And the lines are on the tires. You just have to have to find ones with a line on the top. These were good year, from a mid 90's buick!!! After you are done, get a sharp razor or excacto knife and straighten and remove any over spray or leaking paint. |
Kubel Nick Samba Member
Joined: August 12, 2003 Posts: 1369 Location: Fort Worth, TX
Posted: Wed Apr 04, 2007 11:42 am Post subject: |
| they also sell tire paint made for this also. But as with all painted on paint on tires, you need to maintain/repray it often. Some also use tires with white letterings and grind off the layer of black until the entire white walls are exposed. Use caution when doing this as you are making the side walls thinner. But there is a white wall layer under there. |
Lee. Samba Animal Controller
Joined: December 22, 2003 Posts: 3079 Location: Denver, CO
Posted: Wed Apr 04, 2007 2:05 pm Post subject: |
Those look great. I wonder how long they will last until they need to be resprayed? _________________ www.DenverWildlifeControl.com |
Posted: Wed Apr 04, 2007 9:11 pm Post subject: |
| Lee. wrote: |
| Those look great. I wonder how long they will last until they need to be resprayed? |
They should last a while. I sanded a spot last night and it didn't even phase it. But as I said, I did spray the crap out of them. I won't be driving my sqback everday, so if it were a daily, I would guess they would have to be touched up every other month or so. |
crewlvw Samba Member
Joined: December 23, 2004 Posts: 384 Location: hemet. so. cal
Posted: Wed Apr 04, 2007 11:31 pm Post subject: |
| i have the same caps in my garage. are you on the hamb ? my old hot rod friends give me crap for loving vws because they want me to finish my 29 roadster owell. what did you use to grind the letters off? thanks billy |
Posted: Thu Apr 05, 2007 1:40 am Post subject: |
| crewlvw wrote: |
I used an 80 grit disk attachment for my grinder, I will use a 100grit next time. Then I used a 150 grit block to touch up. What is the hamb?? I know it has something to do w/ rods?? I'm not into hot rods, I do love them, but not as much as I love me some Volks!! I just roll the type 3's now. The real VW!!  |
krusher Samba Member
Joined: September 24, 2002 Posts: 7662 Location: europe
Posted: Thu Apr 05, 2007 12:57 pm Post subject: |
My guess is the paint will crack all over the place the first time you roll them  |
Posted: Thu Apr 05, 2007 1:32 pm Post subject: |
| krusher wrote: |
Bad guess. I just got back from driving to portland on them and they look the same as when I left!! Little dirty but washed right off. !60 miles round trip.  |
Long-roofs Samba Member
Joined: March 20, 2002 Posts: 2386 Location: Millwood, Wa
Posted: Mon Apr 09, 2007 4:10 pm Post subject: |
| Low down wrote: |
| crewlvw wrote: |
The H.A.M.B. Cool place to be for rods.
http://www.jalopyjournal.com/forum/ _________________ ---
Trying to keep poor cool
People are talking, the greatness is coming, going to be greater than great, so great, greater than anything ever.
Slowlow  Samba Member
Joined: March 17, 2004 Posts: 4121 Location: Northeast Tennessee
Posted: Fri Apr 13, 2007 9:18 pm Post subject: |
Ive used the fusion method too.
IT works GREAT! --- UNLESS your tire goes a little low and you dont realize... THEN you drive on it
but a quick re-coat and you are ready to ride again!  _________________ • Metal Fab & Quality Suspensions, Type I-II-III. Since 2004 • |
