Safaris - installing and threaded plate?
Buba
Buba is offline
PostPosted: Thu Aug 17, 2006 2:40 pm    Post subject: Safaris - installing and threaded plate? Reply with quote
Hi, I'm installing a original safari on my westy, and I have the following problem.
I'm following the safari window's installation instructions on this link http://66.34.72.138/howto/safari.html and it talks about a "threaded plate", I made one, but is too wide, can someone send me plate's size?
I will appreciate any sugestion about installing safaris and especially installing the "threaded plate"
another question, how big and what's the correct position of the hole I must drill to insert the threaded plate?
Greeting from Argentina
Marcos
52 Ambulance
57 SC
57 Oval
60 SO23
60 Bug
2true
2true is offline
PostPosted: Thu Aug 17, 2006 5:15 pm    Post subject: Reply with quote
A modern day step-by-step installation would be nice.....
AKA Destroyer of the Rants......
View user's profile Send private message AIM Address Facebook Gallery Classifieds Feedback
Metalwizard
Metalwizard is offline
PostPosted: Thu Aug 17, 2006 6:05 pm    Post subject: Reply with quote
The plate is 1/2 wide and has a offset bend where every screw goes. the hole in the corner is aprox 1/2 as well, you put the right side in from the left and the left from the right. the holes in the windshield upper frame are 3/8 aprox. Here are 2 pics i just uploaded to the gallery under my name.
frig it look here http://www.thesamba.com/vw/forum/album_search.php?search_author=Metalwizard
I hope this helps later
http://s461.photobucket.com/albums/qq335/Metalwizard/
Kelly aka
"Bubble & Nut Buster for wannabe BadBoy's of Restoration"
"There is no cure for Stupid"
ITMC "Drill SGT"
View user's profile Send private message AIM Address Yahoo Messenger Facebook Gallery Classifieds Feedback
Flipseat
Flipseat is offline
PostPosted: Thu Aug 17, 2006 6:17 pm    Post subject: Reply with quote
Here is a pic from when I installed my nut plates... like Kelly said, put the left in from the right, and the right in from the left. I cut notches (see pic) in my upper center windshield pillar to slip them in. Use a pick, or tack a piece of wire to the end of the nut plate so you can move it into position. Original safari buses have a tang welded to the inside of the upper windshield frame to keep the nut plates from moving all over the place. So unless you cut apart the sheet metal, good luck getting them out.
Insert random important looking club initials here.
Metalwizard
PostPosted: Fri Aug 18, 2006 6:33 pm    Post subject: Reply with quote
I cked today for twin, from the center post below the radiused corner, measure over 2 7/8 for the first hole, from that point the holes are 2 3/4 on center. On an original bus frame the holes area aprox 3/8 dia. Hope this helps, i'll be out of town tomorrow picking up my 15 window deluxe from Danny's in Wrightsville Beach. Sunday i'll be at Piedmont for the show. Later
Kelly aka
ITMC "Drill SGT"
chazwood
chazwood is offline
PostPosted: Sat Aug 19, 2006 7:00 am    Post subject: Reply with quote
Metalwizard? are you posting pictures now? It's a new day folks! Very Happy
kind of fun isn't it Cool
Buba
Buba is offline
PostPosted: Sat Aug 19, 2006 6:21 pm    Post subject: Reply with quote
Hi, Thanks for all your information!!!
I allready install them, just need to weld the internal suports at the body shop next week.
First I put the plate onto position from outside and using it as a guide I drill little holes with a dremel at lowest speed.
After check if they are on the correct position I drill 8 mm holes, but not on the center, later after install the threaded plate and check again that all holes are right I drill a 6 mm hole in the center
I drill the holes to insert the threaded plates wich I made with out bends
I know I have to change the internal mirror Wink is on the way
Then I fix the threaded plate by the center screw
and install the safari window
Next week my westy is going to the body shop to paint them and to change and paint some non original parts, (tail lights, bumpers, etc).
Thanks!!!
Greetings from Argentina
52 Ambulance
57 SC
57 Oval
60 SO23
60 Bug
twinwindows
Samba Pimp
twinwindows is offline
PostPosted: Sat Aug 19, 2006 11:58 pm    Post subject: Reply with quote
Funny this came up, My body guy and I were just having this conversation on putting a set of safari windows on my bus, lucky for me I was able to find a complete set of NOS safari windows from campingbox complete with NOS rubber seals and the mounting plate that the safari windows get attached to. On my bus someone had a set of safari windows already installed in it but they just drilled into the upper part of the window frames to mount the safari frames. Met Wiz sent me some specs on where the holes go and I also had other people on samba send me pictures of the exact place to make the holes. I am going to remove the plate just above the windows from the inside of the cab so that I can mount the safari brackets and also the metal tang to hold them in place afterwards weld the plate back on. I will post pictures of the step by step soon.
CRG
My builds
BAD TEMPER 11
CHRISTINE
GFK LIFER!
myzamboni wrote:
Yeah, everyone's now doing it GFK style . . . everythinig is covert until the finished product is revealed.
vdubinit
vdubinit is offline
PostPosted: Mon Apr 16, 2007 12:10 am    Post subject: Reply with quote
So what's the step by step process anyone anyone Very Happy
**WANTED** ONE 4 1/2 EARLY FUCH
JET-A
JET-A is offline
PostPosted: Sun May 25, 2008 9:10 pm    Post subject: Reply with quote
Is anyone making/selling the safari nut plates? I'd like to get my hands on a pair.
Split 1
Split 1 is offline
PostPosted: Mon May 26, 2008 12:27 am    Post subject: Reply with quote
Yep, Creative Engineering in the UK make them, I have fitted a set to mine.
Made from stainless as well.
Dave
JET-A
JET-A is offline
PostPosted: Mon May 26, 2008 8:47 am    Post subject: Reply with quote
Thank you Dave, I'll look into it.
Can anyone help with a N. American supplier?
Clara Premium Member
Clara is offline
PostPosted: Mon May 26, 2008 9:20 pm    Post subject: Reply with quote
original in a '61:
original in a '65:
Split Box
Split Box is offline
PostPosted: Wed Aug 27, 2008 6:41 am    Post subject: Reply with quote
Who has these threaded plates in N. America...or just make my own ?
I have searched several web sites/ F/S samba with no luck.
npbusguy
npbusguy is offline
PostPosted: Wed Aug 27, 2008 6:54 am    Post subject: Reply with quote
PM the Wiz or contact him through www.metwiz.com, he will make a set for you.
twinwindows
Samba Pimp
PostPosted: Wed Aug 27, 2008 10:33 am    Post subject: Reply with quote
MetWiz will just about make anything you need. Ask me how I know? Cool
CRG
My builds
BAD TEMPER 11
CHRISTINE
GFK LIFER!
DaveB
DaveB is offline
PostPosted: Wed Aug 27, 2008 3:40 pm    Post subject: Reply with quote
What's the advantage of having the plates over using a Rivetnut? I guess with the plate (over than looking original) you have adjustablility there?
Dave Brooks
USAF Retired
1966 Custom Camper
Split Box
PostPosted: Wed Aug 27, 2008 4:02 pm    Post subject: Reply with quote
My thinking is durability more of a solid mount
then again this will be my first set of safaris.
Aaron
Samba Luddite
Aaron is offline
PostPosted: Wed Aug 27, 2008 6:22 pm    Post subject: Reply with quote
Adjustability= bucks, strength= extra bucks, and the ability to install, remove and re-install as you please without the screw holes getting all sloppy=mega extra buck.... knowing that you installed them the way the factory would have= priceless.
Split Box
PostPosted: Mon Sep 29, 2008 4:49 pm    Post subject: Reply with quote
PM were sent off to Metwiz also an e-mail with no response
I still need a pair of plates for a set of Izzy's safaris...Hello Metwiz ???
