What is that next to the MC?
abed
abed is offline
PostPosted: Sat May 05, 2007 9:38 pm    Post subject: What is that next to the MC? Reply with quote
I was wodering what is that next to the MC with the break lines in and out? http://www.thesamba.com/vw/classifieds/detail.php?id=441930
Thanks,
Looking for a 2004 vw sedan Ultima Edition
John M.
John M. is offline
PostPosted: Sat May 05, 2007 10:07 pm    Post subject: Reply with quote
Proportioning valve or a line lock maybe?
Current: 1972 Beetle - 96V EV
Previous:
1966 Beetle - Sea Blue - 1300SP
1966 Beetle - Sea Blue - 1600SP
1974 Beetle - African Red - 1914CC
67texan
67texan is offline
PostPosted: Sat May 05, 2007 10:44 pm    Post subject: Reply with quote
I'd hate to check the fluid level in one of those.
abed
abed is offline
PostPosted: Sat May 05, 2007 11:00 pm    Post subject: Reply with quote
I have never seen this before, is it an upgrade for the breaks? It is dual circuit MC so what is it for?
67texan
67texan is offline
PostPosted: Sat May 05, 2007 11:07 pm    Post subject: Reply with quote
That's only a reservoir for a dual circuit master cylinder. Up to '66, Beetles only had single circuit brake systems. If you lost one wheel cylinder, you essentially lost your whole brake system. In '67 they upgraded to a dual circuit system (front brakes are one circuit, rear are the other), so that if something went wrong on one end, the other end could get you stopped.
You can upgrade an older bug to dual circuit, and this is just a reservoir that will mount on top of the mc to hold the fluid.
abed
abed is offline
PostPosted: Sat May 05, 2007 11:14 pm    Post subject: Reply with quote
I am not talking about the reservoir, the other polished part below left on the photo
bugntjw
Rants Lurker
bugntjw is offline
PostPosted: Sat May 05, 2007 11:26 pm    Post subject: Reply with quote
It's got to be a line lock. Contact the person with the ad? Bet he knows.
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Wow...that was fun!"
Duct tape is like 'The Force'. It has a light side and a dark side, and it holds the universe together.
67texan
67texan is offline
PostPosted: Sat May 05, 2007 11:45 pm    Post subject: Reply with quote
Ok - yeah, that's probably a line lock. Looks like some wires running to a solenoid there on the backside of it.
Hotrodvw
Hotrodvw is offline
PostPosted: Mon May 07, 2007 7:20 am    Post subject: Reply with quote
Little black thing is a proportioning valve, shiny thing is a line lock, blue thing is a residual valve.
'67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings
Gary
Person of Interest
Gary is offline
PostPosted: Mon May 07, 2007 7:27 am    Post subject: Reply with quote
This sentence from the ad just makes me chuckle:
Items are USED and must be completely cleaned before use for best results.
West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943)
dog_jr911
Swamp Donkey Assistant
dog_jr911 is offline
PostPosted: Tue May 08, 2007 1:18 pm    Post subject: Reply with quote
its for doing sick burnouts. just hit a button on the dash, and it locks the front wheels.....
draggers use it. looks likt that one may be set up for the rears as well.
AKA Chris™
ROCKIN a ESP LTD F2E
ivsamhell
ivsamhell is offline
PostPosted: Tue May 08, 2007 1:29 pm    Post subject: Reply with quote
pull the wheel, do routine maintenace maybe some cleaning while its off....if you've got a leak you'd know it.
krlang
krlang is offline
PostPosted: Wed May 09, 2007 10:28 am    Post subject: Reply with quote
The black piece with the knob is a Wilwood brake proportioning valve.
It reduces the amout of fluid sent to the rear wheels
The blue part installed into it is a check valve
It slows return fliud to the MC
The part on the firewall is the line lock solenoid mounted into the line that tees into the two front brakes.
Burnout stuff!
67 Type I in Harley turquoise(1914CC)
"Then I landed on the water, Just about my favorite thrill....." -JB
